Any idea what could've caused this?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by insaner, Dec 2, 2015.
  1. insaner
    insaner Junior Member
    96
    Atlanta, GA and Huntsville, AL
    The car did overheat recently and hasn't done it since.
    51,495
    how many miles on her?
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Well that's the rubber strip right above the radiator right? Between it and the hood? I would say overheating plus soft rubber equal deformity. It's not a big deal though, just cosmetic if that's the piece I'm thinking of.
    uart likes this.
  4. valde3
    valde3 Senior Member
    2,002
    747
    Finland
    It might just have happened regardless of overheating. From the pictures it doesn’t even look like a problem.
    Just out of curiosity:
    What did overheat?
    Inverter? Cause of faulty inverter coolant pump?
    Engine? Cause of faulty thermostat or air in cooling system?
    uart likes this.
  5. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    Just make sure the coolant is full
  6. insaner
    96
    Coolant never even leaked. The dealer couldn't recreate the issue and it's never overheated since. The inverter pump is operating properly. They diagnosed a problem with the throttle body which I replaced myself. The problem never repeated. Car hasnt run the same since. It is relatively sluggish now and getting about 5 less mpg. Oil is at proper level. I'm not sure that burn even happened at the same time. I don't think the coolant ever overheated. I'm pretty stuck on all of this. I bought the throttle body at a junkyard so that could have something to do with the mpg. It's possible I guess that the inverter pump is bad and I've mistaken that. Hard to see the fluid moving but I can feel the big hide vibrating well at the pump and the reservoir. Clueless. The 12v is also brand new. 175k. Car also makes a strange chirping noise at full speed that only happens with light acceleration that goes away instantly if I coast. Brakes were done recently by the dealer also but I think that's irrelevant.I wonder if the ECU could stand to be reset? I put the throttle body on after the battery was replaced.
  7. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    What did the dealer say was wrong with the ThrottIe body which you replaced from the wrecking yard?
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Mothra.
    insaner likes this.
  9. insaner
    96
    They said a bunch of stuff I didn't understand until I researched it about the resistance. I tired testing the junkyard one with my multimeter and it seemed ok but I really couldn't tell. I took the old one back to have them show me on their tool how it was out of range. I was not satisfied that it was malfunctioning or that I even new if the used one was either but i already had it on so...
    I also took the used and mine to a couple of shops but everyone was pretty clueless. I used the Toyota shop manual to see the proper ranges but I'm not great with electrician stuff. Not sure if anyone got the proper reading. I still have the original one.
    Any thoughts on unhooking the battery to reset the ECU?I guess I could just live with the mileage and learn to live with the noise.
  10. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    put the old one back on and see if the mileage and power improve back to normal.
    before you put it back on, get some throttle cleaner and lint free rags. hose the rags with throttle cleaner spray and wipe off any crud in the throttle body, and on the blade. make sure the blade moves freely.
    if it runs normal, the dealers full of ___
  11. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    Check this article and how to out: also I think Shovelhead has the right idea.
    TB cleaning
  12. insaner
    96
    I cleaned it before I replaced it.
  13. trungdok
    trungdok Junior Member
    45
    Boston, MA
    Mileage drop:
    I recently cleaned my throttle body. Instantly mpg dropped from 52 to 49, then 47. After that I disconnected the 12v battery, let it sits for a good 30 minutes (just happen since I was cleaning the battery fan, does not need to be that long) to reset the ECU, then after couple of tanks of gas it's now back to 51 mpg ... in 30F temperature. So, you can try it and wait for a few hundred miles.
    Chirp:
    Where does it seems to be coming from?
    Sluggish:
    Could be because the ECU is not used to the new throttle body. Do the suggestion above.
    Also could be because the new throttle body is sticking and not open as wide as the system thinks it should. Could be the tb is not put on properly causing air leak (not likely, but there's a chance). Just do a thorough double check. Clean the spring on the tb with brake cleaner.
    Could it possibly because the new brake job somehow slowing the car down? Possibly sticky caliber? Sounds like you could coast with no problem so that might not be it.
    Good luck.
  14. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    While you are playing with the TB, clean the MAF. That is often overlooked.
  15. insaner
    96
    I cleaned the maf when I switched out the tb. Thanks trungdok I was hoping this worked for someone. I'm going to give that a try.
    The chirping seems like it's coming from the drivers side underneath the hood but it's hard to say. It's making what sounds like 2 chirps sometimes lol. I'd need someone that had the exact same problem to ever figure this one out I bet.
  16. valde3
    2,002
    747
    Finland
    What does the water pump belt look like? Don’t overtighten it! Overtightening will shorten the life of the pump.
  17. insaner
    96
    I finally got a decent video where you can hear the noise my car has been making. If I had to narrow it down I would say it seems to be coming from under the hood, drivers side. It happens when I lightly press the pedal. When I take my foot off the pedal, it goes away. In the video you should be able to hear it as I'm taking my foot on and off the pedal.
  18. insaner
    96
    I would really like to post this in its own thread so people with a similar problem would see it. Sorry if that's out of line.
