Intermittent power failure problems.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Julien, Dec 8, 2015.
  1. Julien
    Julien Junior Member
    San Diego
    2013 Prius v wagon
    I have a 2013 prius v 5. I bought it new from the dealer, and it has now 40,000 miles.
    Lately, I've been having intermittent power failure problems.
    They happen when I try to turn off the power. The panel lights star acting up, and a buzzing noise is heard by the driver's side of the engine compartment.
    Then, it seems that the power drains, until there is no power at all. Everything I'm not able to power the car I jump it and it works.
    I doubt that it is the 12v battery, because when I jump it then it works for the whole day. But then the problem arises randomly. When the power drains there is a buzzing noise.
    Could it be a rely or some other electronic device failure?
    I have to keep a battery jumper with me, so that I can power the car when it fails.
    If anyone had a similar problem and was able to troubleshoot and fix it, please let me know.
    I've tried to talk to a service advisor at the Toyota dealer where I bought it but they are always too busy and don't return my calls, so far. I need the car to work, and it's a hassle to do with out it while they fix it. But I certainly can afford to have the car several times at the shop if they fail to find the issue.
    #1 Julien, Dec 8, 2015
  2. xliderider
    xliderider Senior Member
    8,041
    3,213
    Honolulu, HI
    Still sounds like the 12v battery is weak/bad. Get a volt meter or multimeter and measure the battery voltage when the car is off.
    The buzzing sound by the driver's side is the brake booster accumulating pressure, it's normal.
    Julien and bisco like this.
  3. rjparker
    9,550
    5,853
    Are you saying the buzzing continues for more than a few minutes? Sometimes the brake booster is more obvious in a garage than when you shutdown outside. Lights on (map lights and trunk lights especially) will drain a battery overnight. A replacement 12v battery will be around $300 at the dealer or perhaps $175 online, but if you need it you need it.
    Here's a link on how to check the 12v voltage that might work if the car will go into accessory mode.
    Prius v Display Audio Service Menu w Battery Check | PriusChat
  4. Car Donation
    Car Donation New Member
    New York City,NY USA
    Julien likes this.
  5. bisco
    51,060
    welcome! possibly, you 12v battery is still under warranty. if you don't want to buy a 10 dollar meter and check the 12 volt battery yourself, make an appointment with toyota, or any auto parts store can test it and replace it if necessary. 'assuming', is a bad look for the prius. all the best!(y)
    Julien likes this.
  6. Mendel Leisk
    40,511
    As I read your post I kept thinking that it should be a warranty item. Then reading your last paragraph, I'd say: email the dealership's service manager, outlining the problem and your difficulty getting attention. If nothing comes of that, contact corporate Toyota. Maybe drop a hint with the service manager that that's your next course, say ask if he can suggest a contact email.
    Julien likes this.
  7. loudes13
    loudes13 Junior Member
    chicago
    I have the same issue. It acts like a loose battery cable but both are tight. I had his issue with an aftermarket battery so I replaced it with a new dealer battery and the problem is back 10
    Months later. I have to ask the dealer parts department.
  8. Xterra72
    Xterra72 Senior Member
    1,427
    1,669
    Same problem on my Toyota Prius 2013. Granted it’s over 1 years old. It just started happening.
  9. Air_Boss
    Air_Boss Senior Member
    4,134
    1,152
    New Yawk
    I would not dismiss the possibility of a hung relay. The (audible) shutdown sequence does involve a sequential opening of power relays.
  10. Brian1954
    Brian1954 Senior Member
    1,740
    678
    South Central PA, USA
    Start a new thread and describe the symptoms that you are having and if the 12v battery has been checked and how old the 12v battery is.
