Outside Mirror Disassembly ?
Discussion in 'Prius c Accessories and Modifications' started by WD0AFQ, Jul 25, 2013.
  1. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I hear ya. Now to decide which ones to order.
    Thanks for the help.
    Dan
  2. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :) Do a You Tube search for installation of the LEDs behind the mirrors. I checked out two yesterday. Fairly simple procedure. I have the LED mirror cover on order as well as the LEDs for the mirrors. I'll install both at the same time.
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i would love to see somebody install the arrows in the mirror. because i would love to do it too
  4. kingnba6
    1,018
    242
    NY
  5. WD0AFQ
    619
    152
    Dexter, Mo.
    I have been busy with other projects and have done nothing on the arrows in the mirrors. Will get fired up when I see someone get theirs done.
    Dan
  6. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    Sorry I don't have a C, just the Hatchback, pretty much the same since the OEM blinker wiring is there after I added the 3-in-1 led combo with my Power folding mirrors. I have installed on my '12Odyssey & '13Prius both looks great!
    I suggest polish out the of the led arrow shape for way better visibility in Day time.
    Here is short clips of led arrow with the mirror polished out.
    Dylan Doxey and OldNo7 like this.
  7. WD0AFQ
    619
    152
    Dexter, Mo.
    Thanks NoMoreNow. As I have been noticing "factory" setups, they too have that area polished out. Looks like that's the way to do it.
    Dan
    NoMoreNow likes this.
  8. kingnba6
    1,018
    242
    NY
    very nice setup nomore!
  9. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    How do you get the mirror cover off?
  10. navyjoe1987
    navyjoe1987 Junior Member
    25
    17
    The back of the mirror back can be removed once you remove the mirror glass assembly. I believe there are four tabs, the hardest one is on the inside right where the mirror folds in. Just push them out gently with a small screwdriver to pop off the back. Take your time and be gentle. If it doesn't come off easily then you most likely missed a tab. Good luck.
  11. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I installed the LED arrows when I installed the LED mirror kit. No need to polish out the inside of the mirrors. The LED arrow shows up fine day or night.
    OldNo7 likes this.
  12. Dinesh Jayasinghe
    Dinesh Jayasinghe New Member
    Colombo
    Hi Guys, I am new to the forum. Just joined actually. I have a Prius C 2013 Four. I have a small problem with the side mirrors. They tend to fold halfway sometimes when i lock the car. This happen more often when the car is used in Direct Sunlight (basically when its hot). My concerns are:
    Is there a way to disable the auto folding mechanism? So that I can fold them when ever I need, not automatically...
    How to you lubricate the motor mechanism if required to by opening the mirror and what sort of fluid required?
    Any way that I can fix this by opening and what could possibly be the cause of the problem?
  13. Dinesh Jayasinghe
    Colombo
    Well I already ordered mine, waiting to do the modification.
    Cant post the link as I am new to the forum: Search following on ebay:
    2 Amber 33-SMD Sequential LED Arrows Panel for Car Side Mirror Turn Signal Light
    They seems nice, but getting the mirror assembly in to parts is kind of hard i think. I am at risk of Rs 35,000/- a piece (1 USD is RS145 in Sri Lanka). Even a re conditioned part is damn expensive in this part of the world.:(
    Fingers crossed, will let you know how it goes.
    Anyone tried lubricating the retracting mirror hinge? My one stops halfway sometimes hope if i grease the hinges it will sort the issue, I want to fix this. And also need a solution to disable the auto folding mechanism when the car is locked with key. I wont mind folding with the on board switch on the dash.
  14. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    EDIT: Gave the mirror a strong tug and it came out and was able to replace it. Dealership quoted me $120 in labor. Part was $36 (dealership sold it to me for $25). Thanks again!
    #34 PriusC_Commuter, Dec 29, 2015
