AUX plug
Discussion in 'Gen 2 Prius Main Forum' started by davidtoo, May 7, 2006.
  1. davidtoo
    davidtoo Junior Member
    Sacramento, California
    Alhtough I have a Monster adapter/FM transmitter for my MiniPod, since the radio is so sensitive most of the FM stations are not available. I would like to plug my MiniPod into the AUX adapter, but haven't been able to locate an iPod to mini-plug cable for the AUX adapter. Does anyone know where I can get one? Thanks.
    0emissions
  2. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    About $3.00 at Radio Shack, Best Buys, Circuit City. You need a double ended male earphone mini-jack. I got one about 12" long. It will plug into the earphone or the dock. If you want the ipod on the dash or somewhere else, longer cables are available, 3' and 6' long.
  3. darelldd
    6,059
    389
    Northern CA
    I bought a nice long one from RS the other day to finally try my iPod with the Prius. There is some TERRIBLE feedback from somewhere! Yikes.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(darelldd @ May 6 2006, 10:54 PM) [snapback]251007[/snapback]</div>
    Is the feedback only happening when the iPod is being powered by the power outlet? If so, you need a ground loop isolator. See http://priuschat.com/index.php?s=&showtopi...ndpost&p=228364.
    This NEEDS to be in a FAQ somewhere. John1701a, you gonna add it?
  5. davidtoo
    <div class='quotetop'>QUOTE(0 emissions @ May 6 2006, 10:46 PM) [snapback]251002[/snapback]</div>
    Wow! That was a qauick response. Thanks to all for the great info. I'll stop by Radio Shack tomorrow. Has anyone tried the Dension ice>Link Plus iPod integration product?
    2006 Silver Prius, Pkg. #6
    (ordered on Friday, arrived on Saturday - went through an auto broker)
  6. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(cwerdna @ May 6 2006, 10:57 PM) [snapback]251010[/snapback]</div>
    Thanks cwerdna. I am pretty sure I was just playing the iPod off of batteries - but I'm not sure. I'll give it a shot. Thanks for the info. If nothing else, I'll put it in my pathetic little FAQ.
    Yup. That's it of course. I could plug and unplug the power adapter, and make the hum come and go. Sure sounds great without the power adapter! So RS sells a ground loop isolator here. And it says it has a 1/8" plug adapter??? Does this work with the ipods?
    Off to edit my FAQ.
  7. samkusnetz
    samkusnetz New Member
    85
    Portland, OR
    not to nitpick, but what you're hearing isn't feedback. you're hearing noise. feedback is a sound being continuously re-amplified, like if you point a microphone at the speaker that's playing the sound coming from the microphone.
    the noise stems from the fact that audio system of the car connot be electrically isolated from the rest of the car, since the car is self-contained. the radio shack filter creates isolation between the *power* going into your ipod and the *audio* coming out, which achieves the same effect.
    the real questions is, why didn't toyota build an isolater into the jack in the first place?
    sounds like a good mod to me!
  8. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(samkusnetz @ May 7 2006, 10:44 AM) [snapback]251105[/snapback]</div>
    Don't apologize for nit-picking! That's what I do best, and of course you are correct. :) OK... info added to my FAQ with a link to the RS product. I'll see if I can integrate it into the outlet in the console the next time I have the console out.
