Clicking while backing when brakes applied
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by eeek, Dec 21, 2015.
  1. eeek
    eeek Junior Member
    My 2015 gen 3 trim 4 loudly clicks when I am backing and apply brakes. Seems to come from under the car. Anyone know if this is a normal, expected sound? Thank!
  2. frodoz737
    frodoz737 Top Wrench
    4,693
    2,493
    33
    This is not normal. Go see the man.
  3. Mendel Leisk
    41,355
    The rear caliper/piston has an integrated parking brake mechanism; methinks something's messing up with it. If you can, get a look at the inside pads: they have a pin on the back that locks the caliper piston, prevents it from rotating. If it looks chewed up it's not working properly. Also check conditions of the pads and disc: are they wearing uniformily, no scoring on disc? Or?
  4. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    If it's just one click or thunk it's normal. Both of my cars do it when reversing, then when brakes applied for the first time.
  5. eeek
    eeek Junior Member
    I made an appointment for later today. Then, of course, it stopped last. I decided I better capture the sound while I could- maybe it only does it when cold. Attached is what it sounds like. It's much louder than what it sounds like here.
    To add- I had my back up beep changed to one beep. You can hear the beep, followed by the click and instantly the engine kicks in. Then there are two more clicks.
  6. Mendel Leisk
    41,355
    There's a problem for me, playing the video:
  7. BZzap!
    BZzap! Senior Member
    1,607
    878
    Since my Prius has been brand new, I have complained about brake pad and/or caliper rattle. While my brakes don't click when braking in reverse, there is a consistent and annoying snap and popping sound when driving over Botts dots or any sharp irregularity in the road. It is so loud that you can hear it resonating off buildings as you pass by. Toyota is well aware of the problem and has published a TSB regarding this condition. The latest publication consists of a suggestion that the caliper pins and brake pad ears be lubricated with a special grease. I can tell you that this is an exercise in futility. After many visits to different dealers in the area they have failed to eliminate the problem and Toyota has shunned it off as a normal condition. Basically, the problem has been engineered into the braking system with excessive clearances in the brake pads and calipers.
