Cannot re-assemble key fob
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Brittany182, Dec 25, 2015.
  1. Brittany182
    Brittany182 New Member
    Massachusetts
    Merry Christmas! For some reason I thought tonight would be a good night to try to replace key fob battery. Turns out we didn't have the right size ones, then when my dad tried to put it back together after opening up, he cannot get the pieces to fit back together. They stack up too thick to pop the plastic back together. This rubber piece seems to be the culprit. It doesn't fit in to the grooves and doesn't match up with the little plastic nubs. Anyone else have trouble with this before? Or any advice on how I can get to work on Christmas Day? Of course my spare fob is at my apartment and I'm home with my family for the holiday. Thanks in advance!
  2. xliderider
    xliderider Senior Member
    8,041
    3,213
    Honolulu, HI
    I've replaced the batteries on both fobs for my 2 Toyota vehicles and didn't run into much difficulty getting it back together.
    Have you tried searching for a video on YouTube that details disassembly and reassembly of the key fob?
  3. Brittany182
    Massachusetts
    Yup been watching every video and none show anything like the problem we're having :(
  4. Brittany182
    Massachusetts
    The plastic spikes on the middle piece do not have any corresponding holes on the rubber piece, which seems to be the problem. Not sure if poking holes into the rubber would solve the problem.
  5. xliderider
    8,041
    3,213
    Honolulu, HI
    OK, this is my Camry fob, but if your prius fob is similar it might help.
    Look for the corner on the back of the front piece with the small hole. Now, insert the clear rubber piece with the small rubber nub in the underside of the corner in the hole.
    Then insert the circuit board piece in the rubber tray with the battery side facing away from the nub/hole corner.
    Hope that helps!
    #5 xliderider, Dec 25, 2015
    Brittany182 likes this.
  6. Brittany182
    Massachusetts
    Disregard!!! We've been placing it on the wrong side this whole time, of course. Holiday stress! Maybe someone will make this silly mistake in the future and come across this thread :)
  7. xliderider
    8,041
    3,213
    Honolulu, HI
    So it's all together now? :D
  8. mrbigh
    3,686
    699
    Long Island, NY
    lesson: do not full around with something you can't handle
    The best full proof learning guide is, take pictures with a phone or camera as you go along with an unfamiliar task.
  9. bisco
    51,061
    welcome! i tried to change my battery and ended up with pieces all over the floor. it kind of explodes when you open it up. not the best design in the world. glad it all came together for you! happy Christmas!(y)
  10. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    And the lesson luckily not learned, is DO NOT modify a perfectly designed FOB just to get it back together!
  11. 48mpg
    48mpg Member
    193
    47
    florida
    I
    Lesson ..its spelled "FOOL" not full :D
    full is when the gas tank cant hold anymore gas
  12. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Always be careful to observe how something comes apart in order to put it back together correctly. Be slow and methodical. No modifications (e.g. "holes") are necessary.
  13. Mendel Leisk
    40,513
    My impression too, when I changed fob batteries: very fragile, finicky device.
  14. bisco
    51,061
    the biggest problem with the fob is when your prying it apart. i think i will put an elastic around it next time.
    also, when you go to snap it back together, it feels like something is binding, and you're afraid you're going to break it. but there's really nothing wrong.
  15. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    wrong side or upside down rubber is easy to do.
  16. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Just so long as it's only on your fob...:eek:
    RRxing and Mendel Leisk like this.
