What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. yOsHi LiN
    yOsHi LiN Active Member
    215
    138
    los angeles
    2014 Prius c
    what u mean
  2. xliderider
    xliderider Senior Member
    8,041
    3,213
    Honolulu, HI
    I think he was asking what are your gauges setup to display.
    Looks like coolant temp and voltage to me.
  3. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
  4. robbm3
    robbm3 Junior Member
    Georgetown, DE USA
    They stay very well on the roof... Very pleased. Also, very easy to remove in the winter when Im not using.
  5. mrpinkie
    mrpinkie Junior Member
    31
    North Carolina
    2015 Prius c
    I installed a new high performance shift knob. It feel like it adds at least 5 HP with out affecting MPG at all. I'm debating putting the sticker that came with it on. I dont know if can handle the additional HP that would give me.:whistle:
    Mo G and djdawn like this.
  6. djdawn
    djdawn Active Member
    256
    116
    Escondido, CA
    2014 Prius c
    I demand pics, or all you did was the stickers.
  7. mrpinkie
    31
    North Carolina
    2015 Prius c
    Here is the go fast shift knob. If you look next to the Start button you can see where I mounted my Nite Ize Steelie for holding my phone.
    djdawn likes this.
  8. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    just install a sickspeed tow hook !!
    amerc001, orenji and mrpinkie like this.
  9. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    [​IMG][​IMG][​IMG]
    SM-N920T ?
    Blindhopes and amerc001 like this.
  10. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    i been waitin for this sway bar for a very very long time. i dont like chrome so i webt gold. what u think !!!
    SM-N920T ?
    robbm3, amerc001 and xliderider like this.
  11. djdawn
    256
    116
    Escondido, CA
    2014 Prius c
    Put in aluminum brake and gas pedals. Still have to put in the deadpedal/footrest on the left side. I had to get creative on the gas pedal because I could only find 1 good drill point that didn't cut into any of the plastic cross members, so I used the one bottom screw to hold the pedal down and 3m VHB tape to stop any left/right rotation.
    Blindhopes, amerc001 and yOsHi LiN like this.
  12. amerc001
    amerc001 Junior Member
    Riverside
    Can you link your rear sway?
  13. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    what u mean link ??
    amerc001 likes this.
  14. djdawn
    256
    116
    Escondido, CA
    2014 Prius c
    He's asking if you bought it online, where did you buy it.
  15. orenji
    orenji Senior Member
    5,886
    3,487
    Is this made for the Prius C? Where did you find it?
  16. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    they do not sell online, i got it from thailand
  17. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    no it not it made for a yaris hatch and i got it from thailand
    orenji likes this.
  18. amerc001
    Riverside
    Lower Support Bar, Sorry.
  19. djdawn
    256
    116
    Escondido, CA
    2014 Prius c
    Installed a 2nd hand Bazooka BTA6100. Fills out the deep bass that was normally missing on my PC2 default setup.
    The red cable is tapping power from the battery, the blue cable is tapping audio from the headunit.
    I ended up moving that basket to the right, anchoring the sub between it and the wall to keep the sub from moving around.
    yOsHi LiN and amerc001 like this.
  20. djdawn
    256
    116
    Escondido, CA
    2014 Prius c
    Finally got around to installing that dead pedal, also installed some solars on the backside of the rearview and on the visor.
    [​IMG]Dead pedal finally in.
    [​IMG] Solars on the backside of the Broadway rearview. Still have room for 2 more on the backside of the normal rearview to collect more power, I'll get around to doing that another time.
    [​IMG]A bit hard to see, but solars on the backside that can collect when the visor is down. A diode is inline to make sure they don't sap any energy while folded up.
    yOsHi LiN likes this.
