Hybrid System Failure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Suhkoi2, Dec 31, 2015.
  1. Suhkoi2
    Suhkoi2 New Member
    Ireland
    So this Prius is for sale for quite a cheap price. But I'm wondering is it worth the hassle and the problems. I should be going to check the car out this Saturday. So I'm thinking is this a good idea? What are the main problems for this?
    I called the guy and he told me that it's a hybrid system failure. Can't exactly trust him as he doesn't seem knowledgeable... He did put in 4k into the car for bodywork...
    2012 Toyota Prius got a hybrid system failure after a crash what would the problem of this be? Car won't start either.
    "i imporeted this car from uk i used it as a taxi, i had an accident so they replace the front sterring racks, front wings, pumper, and pianted from silver to white only out side, but now it wont change the gear i think it need to replace suspension so i do not have money, i be happy if any onewill buy it let it take it on his cost to toyota service and they give you an estimation.
    but i think first need suspenstion to be replaced as it is bend.
    i am selling it as it is so it is up to you if you can checked here in my place i have jack to rised or you take it to toyota service on your cost.
    but toyota told me it need the suspension to be replaced by body shop before we work on it and they say it may not be the problem of gear box that is all i know otherwise its great car."
    "No warranty as it was crashed"
    Is there much difference between the dealer diagnostic tools compared to ones that ordinary mechanics use?
    #1 Suhkoi2, Dec 31, 2015
  2. Mendel Leisk
    40,513
    Should be warrantied? Give dealership a call?
    should have thought more, maybe the crash will make for some "debate" re warranty eligibility? Still, diagnostic from the dealership should not cost much, will give you some idea. Don't volunteer any more info about the accident then necessary.
  3. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Moved to the Gen 3 sub forums from the Prius v sub forums...
  4. xliderider
    xliderider Senior Member
    8,041
    3,213
    Honolulu, HI
    Could be many things, you need to have DTC error codes read. Unexpected grounding detected, etc to much more serious problems.
    Was the inverter coolant radiator up front damaged in the "crash"? If you lost inverter coolant and the inverter overheated, that would certainly cause problems.
    Suhkoi2 likes this.
  5. Suhkoi2
    Suhkoi2 New Member
    Ireland
    Nope no warranty left.
    Yeah I'm going to try that this week just need to move it there...
    What in your opinion would the most serious problems?
    #5 Suhkoi2, Dec 31, 2015
  6. bisco
    51,062
    welcome! sounds like a potential headache. all the best!(y)
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    "Quite a Cheap Price"
    When low buy in becomes the cost of a huge headache?
    I'd pass.
    There is absolutely NOTHING in the description of that situation that would make me want to invest into ownership. In fact? I'd pay to stay away from it.
  8. Suhkoi2
    Suhkoi2 New Member
    Ireland
    It makes you think doesn't it.
  9. xliderider
    8,041
    3,213
    Honolulu, HI
    OP has edited first post extensively. :confused:
  10. Suhkoi2
    Suhkoi2 New Member
    Ireland
    Yeah,felt a bit plain.
    Is the inverter this [​IMG]
    Thanks :p
