1. Diane Ahmed
    Diane Ahmed New Member
    101 elm street #2
    What does the P button blinking mean?
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    Hmm, I would say it's time to check the condition of the 12V auxiliary battery. Might turn out to be something else, but check that first.
  3. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    From the 2010 Owner's manual:
  4. bisco
    51,840
    wow, so nothing if it's just a flashing p. i guess the 12 volt like azwxguy said.
  5. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    A 2 amp charge of the 12v for 12+ hours then a disconnect of the 12v from the system and reconnect would top it off and reset the system, if it still blinked "P" I'd get it to the dealer.
  6. Mendel Leisk
    41,310
    That instruction from the Owners Manual is clear as mud. :confused:
  7. bisco
    51,840
    ya, so if p flashes with no message, no problem?(n)
  8. RRxing
    2,545
    1,821
    NEPA
    It says that a "problem" is not a "malfunction." But then you still have a "problem", so go see your friendly neighborhood Toyota dealer, who will run some diagnostics and charge you $$$$ to do so and then tell you they couldn't find a "problem." Problem solved!
    Like you said - clear as mud... o_O
    bisco and Mendel Leisk like this.
  9. RRxing
    2,545
    1,821
    NEPA
    Is the OP ever going to come back?
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    I can hear the Jeopardy music softly playing somewhere ...
