Toyota Super Long Life Coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Erik K, Jan 3, 2016.
  1. yeldogt
    yeldogt Active Member
    810
    313
    NE
    The older red Toyota coolant is full strength -- I still use it in my older Lexus. The new stuff is pinkish and premixed. I never mix different fluids .. ever. You can actually purchase the OE coolant (Aisin) in the USA now -- from Autohause -- I think it is $18.00.
    The maintenance is just a dump and refill .... this is not a place to try and save a few dollars with a spec fluid.
  2. working1
    working1 Active Member
    121
    111
    I did not remove the engine block drain bolt. I've seen post of the 2010's with a drain bolt that connects to a drain hose (maybe a carry over from Gen2's?). The 2011's and after don't have this. The ones that have removed it state a very small amount was drained. Not worth the effort.
  3. Erik K
    Erik K New Member
    Southern CA
    I have gone to Toyota Nation before here and have found in several different topics that Peak Global Lifetime has been used with good results. See post #2 here .... written by one of the moderators: Toyota Genuine Long Life Coolant or equivalent? - Toyota Nation Forum : Toyota Car and Truck Forums It also states that the pink SLLC comes only in 50-50 premix.
    Also post #17, 77 & 78 here: DIY: 2003-2008 Corolla, Matrix, Pontiac Vibe Coolant Flush w/Pics - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums explains low silicate HOAT, the type of coolant that is being used. Peak Global Lifetime is a low silicate HOAT without 2EHA (what the dexcool has and never to be used in a Prius) and is an extended life coolant (although I don't believe the "lifetime" but would keep it on the same change intervals as usual).
    This one is also good to read through all the posts: Why is Peak Global Lifetime so special? | Cooling System Fluids & Additives | Bob Is The Oil Guy
    Anyways, what the mfg wants you to believe .... that "you must buy our super special Toyota SLLC", never sits right with me. With a little science and research you can figure out what is compatible and what is intended by the engineer's. In some cases other products can be superior to what is used OEM.
    I am comfortable using Peak Global Lifetime in my engine, what my biggest unknown is, is the inverter coolant. I am guessing it works pretty much like the engine coolant system but I wanted to check with those who have used it. I have found those who have used the coolant in toyotas even with the 1.8L. I have also found reviews on amazon like sites with those who have used it in a prius but not much information. I figured here would be the best place to find those who might have tried something else in a prius.
    j12piprius and Tideland Prius like this.
  4. JC91006
    JC91006 Senior Member
    16,659
    8,507
    I guess it's your comfort call on this one, it is your own car. You keep going back to the quote "what my biggest unknown is", so you obviously have a concern. It's not like you're saving $100, you are merely saving $10....possibly. The damage it could cause if you were given the wrong information? Last I remember, these run thousands of dollars at the dealership. But still your call.
  5. Mendel Leisk
    40,493
    Just a FYI, in Canada the Toyo premix is 55%.
    I agree with JC, no upside to saving a few $, so infrequently, weighed against the possible problems.
  6. working1
    121
    111
    Toyota SLLC2 is a "Phosphated HOAT" which is typical for Asian vehicles. Peak Global Lifetime is not a "Phosphated HOAT". Not worth saving a few dollars to find out which one is better at preventing corrosion or maintaining the integrity of gaskets.
    The closest equivalent appears to be the Zerex Asian Vehicle Coolant which states it is a "Phosphated HOAT".
    j12piprius and CR94 like this.
  7. Erik K
    Erik K New Member
    Southern CA
    Like I said before, I came here to find if anyone has tried PGL in their Prius, not to have a debate on whether or not to stick with OEM. I have no issues using it in the engine, I just didn't know enough about the inverter. If no one has tried it, I will do more research before I try it in the inverter. I don't just blindly throw something in the car and hope for the best, nor do I think if you add it, your car will blow up.
    Being an aerospace engineer, I know that OEM's will try to make you think that you can only buy their "special fluid" etc. then mark it up and charge you an arm and a leg. They do their best to make you think you can't use anything else and apparently it has worked here. As I said before, that doesn't sit right with me and I don't like it as a matter of principle. Plus I do prefer the 70-30 mix. Working in the hydraulics side, I know if you do some research you can find out compatibility with different fluids, materials and seals. Its not too hard but can take some time (which is why I came here first), nor is there anything to fear if you do your research right. If no one here knows, then just say so.
    j12piprius likes this.
  8. Erik K
    Erik K New Member
    Southern CA
    jzchen likes this.
  9. JC91006
    16,659
    8,507
    the red coolant is not labeled as "super long life" because it's good for 30k miles. The pink super long life coolant is good for 100k, after that, every 50k miles. Yes they are compatible but you still shouldn't mix them. $18 a gallon for super long life coolant compared to maybe $10 for Peak generic fluid....is hardly "an arm and a leg" difference.
    There is a debate about transaxle fluids here regarding using Toyota WS fluid and some alternative substitute. Yes they probably both will work, but the cost is quite similar, so why use something that's an "alternative"? Using OEM fluid doesn't require research and the time saved researching should be worth more than money saved by using an alternative.
  10. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Whatever fluid (coolant, transaxle, oil) you choose should be backed up with receipts if there is ever any problem that could conceivably be traced back to using a particular fluid, especially if the car (or hybrid system) is still under warranty. For piece of mind, I always use the OEM fluids, since the cost difference is negligible. Running trouble-free since July 2009 (currently at 92K.)
    Good luck with your research.
    jzchen likes this.
  11. CR94
    CR94 Senior Member
    2,662
    1,150
    Northwestern S.C.
    Times two = $36, because it's pre-diluted to 50% strength (in the US), and that's an uncommonly low price for the stuff.
  12. JC91006
    16,659
    8,507
    You can get the red coolant for $21 and that's full strength, not diluted. Although it only lasts about half as long.
  13. jtuchol
    jtuchol Member
    141
    whitehouse,ohio 43571
    I am going to throw my 2 cents in I have a 2013 Prius V that I bought at a salvage auction with 4k on the speed o all of the cooling was gone I replaced with auto zone super long life coolant I now have 35k on clock now, the way I was told about coolant was to do a alkalinity tests strips to see how it's doing as far as making sure it's not eating gaskets or aluminum basically keeping it nutrial on the pH scale.
    douglasjre and j12piprius like this.
  14. working1
    121
    111
    To clarify your original claims/questions/statements:
    1. People say Peak Global Lifetime coolant can be used to top off the Toyota SLLC. NO! They are not equivalent due to the SLLC2 being a Phosphated HOAT. Your research is wrong.
    2. Manufacturer guarantees if you do a flush and fill. YES. They will only guarantee it if a flush and fill is done. This adds additional cost over the Toyota SLLC2 which is only a drain and fill.
    3. Peak Global Lifetime coolant only cost $5.50 gallon. YES, but, how much did you add in for the required flush? Shop rates around $80/hour? Even if you're doing it yourself, your time is worth something.
  15. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
  16. yeldogt
    810
    313
    NE
    Car manufacturers purchase coolant from others ... but they use different additive packs. So the base fluid from one may be the same as the base in another -- but the additives are different. This is done for a variety of reasons -- longevity -- metal content and seal construction.
    When you mix the two types of Toyota coolant -- the newer coolant no longer can be kept in the engine as long. Anyone giving advise on this topic is doing so blindly (unless they have direct knowledge on the Toyota fluid). While some incompatible fluids will Gell in short order the normal consequence is reduced internal corrosion protection and the evidence of this takes years.
    Again -- why use something that is going to reduce the change interval (shorten)
  17. eunique
    eunique Member
    66
    89
    US
    Also...since you are an aerospace engineer, maybe you can ask both manufacturers for their MSDS sheets and then you can compare for yourself the facts and content differences and decide whether you should even try another brand or stick with the stock recommended fluid.
    A0001 ?
  18. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    On the pink SLLC, why does it drop to 50k miles after the first change?
  19. Mendel Leisk
    40,493
    Most manufacturers have intervals like that: longer first interval, then shorter for subsequent.
    One reason to stick with original coolant: there could be differences that cause some sorta conflict. Just what I've read.
  20. CR94
    CR94 Senior Member
    2,662
    1,150
    Northwestern S.C.
    Probably to allow for the fact that you won't end up with 100% new fluid in the system, unlike the factory fill.
