Aftermarket Hatch Struts
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Den49, Mar 18, 2012.
  1. bhargett71
    bhargett71 Junior Member
    I just called Toyota on my 2012 supports and they want $142 each!!!
    NAPA has the Strong Arm next day for $63 a pair!!!!
    HELLO NAPA!!!!!
  2. mbtans
    mbtans Junior Member
    Jacksonville, FL
    I just did this 'installation' and it took about five minutes. If anyone is considering attempting this, do it! It was really easy and affordable. You only need a small flat screw driver to pop off some clips. Very easy.
  3. Mendel Leisk
    40,509
    I've stuck with our stock struts (that's a mouthful), but they definitely went "off" a bit, within maybe 18 months of purchase. They raise the hatch 'till it's about 6" short of the full raise, then either need a nudge, or slowly creep up the rest of the way, depending on weather maybe. Every so often I bonk my head on the hatch, thinking it's totally up when it ain't.
  4. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Was just quoted $166.30 each for my 2010 struts at the dealer, so I'll be getting the 6244's.
    Thanks to all for posting the info in this thread.
  5. JoInAZ
    JoInAZ Junior Member
    Arizona
    Looking for some advice. I bought Strongarm 6244s to replace the original struts on my 2010 Prius. They really aren't as good. They barely help lift the hatch, and the thing comes down swiftly with force. I've had it come down on my head before. Plus, when the weather got colder in Phoenix AZ, the hatch won't even stay in the up position. It fell on my back Saturday and left a nasty bruise. I'm afraid of what it might do to my 12-year-old son. I can't find a U.S. support number for Strongarm; would like to so I could give them a piece of my mind.
    Question is what to do next? I really don't want to purchase from the dealer, as they cost too much. What do you recommend? Keep it simple; I'm a smart single mom but you can stump me if you get too technical.
    :) Thanks.
  6. xliderider
    xliderider Senior Member
    8,041
    3,213
    Honolulu, HI
    #26 xliderider, Jan 11, 2016
  7. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I would argue that you have at least one defective strut if not both. Even in 30F weather my 6244's won't "fall" down unless I pull the hatch closed.
  8. xliderider
    8,041
    3,213
    Honolulu, HI
    Yes, our hatch fell down if not supported when one strut failed.
  9. JoInAZ
    Arizona
  10. JoInAZ
    Arizona
    Per the advice I saw on this forum, I purchased the StrongArm 6244 struts. At temperatures lower than 50 degrees, the hatch falls on me. And lately -- I'm in Arizona in high heat -- the hatch falls. I'm really frustrated and concerned that my son is going to get crunched. Any other solutions out there?
  11. bisco
    51,058
    no warranty or company support?
  12. xliderider
    8,041
    3,213
    Honolulu, HI
    Should have gone with struts with stronger lift force. Like bisco said, there should be some warranty on them. Did you save your receipt, sounds like one of the struts failed.
  13. Mendel Leisk
    40,509
    Our (2010) OEM strut performance went from perfect to so-so, but at least stabilized there. They need a bit of a push to get from 3/4 to full raise, just sorta sticking a bit. But at least they continue to be functional. For anyone who's replaced theirs, if you've retained the oem might be worthwhile trying them again.
  14. xliderider
    8,041
    3,213
    Honolulu, HI
    Nope, our 2011 had one strut totally fail, where you can push the strut down to the compressed position with no effort at all. Makes a good steel baton:
  15. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    Being the plan ahead kind of guy that I am, if anyone confirms Gen 4 hatch lifts that work from Strong please post here. Amazon says that the existing options will not work on 2016 models.
  16. xliderider
    8,041
    3,213
    Honolulu, HI
    All you need is some measurements of opened length vs closed length and what kind of fittings are on each end. Then if you can find out what the lift force is on the oem struts, you can go shopping.
  17. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    I believe Stabilus was the OES for our liftgate shocks. You can get the Sachs branded ones from RockAuto for about $20/ea- this may be worth a try.
  18. pdean
    pdean New Member
    tennessee
    Problem...
    Advance Auto said that the StrongArm 4247 fit my 2013 Prius, and the length seemed right. I replaced both...and they don't hold the hatch up, at all. Thoughts, suggestions?
    Thanks!
    CR94 likes this.
  19. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    maybe they're just old/
    bring 'em back to advance & exchange them for a different pair/
    don't they have a lifetime warranty neway?
  20. pdean
    pdean New Member
    tennessee
    Second set of 4247s doesn't work either. WTH? Should I just order the others, either 6244 or 4686? Is it possible that by turning one of the end pieces to fit I've messed them up somehow?
