FuelEconomy.gov official ratings posted - 58 City/53 Hwy Prius Eco - 54 City / 50 Hwy for Prius
Discussion in 'Gen 4 Prius Main Forum' started by Paradox, Dec 18, 2015.
  1. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    With my old 2013 Prius three and my 2015 persona (both obviously liftbacks) I would shift to neutral on most extended downhills.... I do believe it aided in mpg...
    With my v I don't tend to do so as I find it more difficult to P&G as the regen display is diff and is not linear as compared to the liftback. Personally I dislike the display on the v and much prefer the linear regen display on the liftback. So much easier to regulate..
  2. bwilson4web
    16,195
  3. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    I didn't read the whole post but you are wrong, under 46 mph engine pistons are not moving, MG1, MG2 and PSD (transaxle) are all spinning, but engine is not moving one bit. There are probably more losses in this kind of simulated "Neutral" than a regular declutched transmission, but difference is definitely not that big.
  4. run2w8s
    run2w8s Junior Member
    I'm pretty sure that Wayne Gerdes was having them shift to neutral because he had not taught the driver another advanced technique. That technique is holding the accelerator in a position where you're not creating any regen to the battery nor using any battery power. He mentioned several times that the driver would use this other technique very soon.
  5. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    Thats called the Pulse and Glide method (P&G)
  6. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I referred to it as "the sweet spot."
  7. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    Question- Do we know CAFE MPG assigned to Gen4?
    I estimated >80 on a different web site but I wonder if that's true?
    Slightly off topic, but also how would an BEV like Nissan Leaf compare on CAFE?
  8. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    Not sure about the Leaf, but Tesla scored 277 in 2014.
    I would guess the Leaf would score higher as it is more efficient, but I could only find breakdown by company.
    http://www.nhtsa.gov/staticfiles/rulemaking/pdf/cafe/Performance-summary-report-12152014-v2.pdf
    wjtracy likes this.
  9. bwilson4web
    16,195
    energyandair, wjtracy and Zythryn like this.
  10. Zythryn
    6,408
    4,407
    That is a ton of data!
    I couldn't parse out CAFE values though, unless the mpg are CAFE. They seem too low though.
  11. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    Help us with the data Bob. Seems like only Gen4 2eco is tested. Could that possibly explain why 2eco has 58 MPG? The others simply not tested. Which cycle is CAFE.
  12. bwilson4web
    16,195
    Source: Fuel Economy | US EPA
    My understanding is the 'ftp' test, MPG number is the one used per vehicle: http://www3.epa.gov/fueleconomy/documents/420f14015.pdf
    10. Why are CAFE values different than the mpg estimates given on a car’s window sticker?
    Will consumers achieve 54.5 mpg with new cars in 2025?
    The Corporate Average Fuel Economy (CAFE) program has a different purpose than the EPA/DOT Fuel Economy and Environment Label (or window sticker) and the mpg estimates used for each program differ accordingly. CAFE is the required average fuel economy that individual manufacturers must meet for their fleets of passenger cars and light trucks manufactured for sale in the United States for each model year. The National Highway Traffic Safety Administration (NHTSA), within the Department of Transportation, establishes and enforces the CAFE stan dards, while EPA performs vehicle testing and CAFE calculations.
    CAFE values are calculated from the EPA vehicle fuel economy database (based on testing at both EPA and automakers, including the test data used to determine the fuel economy estimates for the labels.) However, the law requires that the methodology used to calculate fuel economy for CAFE compliance be consistent with the 1975 test methods so, unlike the label values, CAFE mpg estimates are not adjusted to reflect real-world driving conditions. As a general rule of thumb, the combined mpg estimate on a vehicle’s window sticker is about 20% lower than its combined mpg estimate for CAFE, though the actual difference depends on the particular vehicle. For consumers, the label value provides the best estimate of the fuel economy they are likely to experience in real world driving.
    Top 1% of the ~2,000 FTP test entries:
    model FTP test MPG
    1 IMPALA 10000
    2 Audi A6 10000
    3 Audi A6 10000
    4 Audi A6 10000
    5 Audi A6 10000
    6 MIRAI 94.1
    7 PRIUS Eco 84.1
    8 PRIUS Eco 84.1
    9 PRIUS Eco 82.5
    10 PRIUS 78.0
    11 PRIUS 77.3
    12 PRIUS c 75.0
    13 PRIUS c 71.4
    14 PRIUS 71.1
    15 PRIUS c 69.0
    16 Tucson Fuel Cell 68.0
    17 PRIUS c 65.9
    18 PRIUS 64.9
    19 PRIUS v 61.5
    20 Fusion (HEV) 60.6
    I am expecting some 'adjustments' of the Impala and A6 numbers. It looks like GM has borrowed the same German translators that VW/Audi used for the diesel NOx testing.
    Where are the Leaf and Tesla numbers?
    #112 bwilson4web, Jan 31, 2016
  13. Zythryn
    6,408
    4,407
    Those are not CAFE numbers.
    Various adjustments are made to attain the CAFE numbers.
    As for the FTP numbers, I am not sure how those are attained. The ones for Tesla (23 - 30mpg) don't even make sense.
  14. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    We need model year for the above table...I am thinking eco is only 2016 Prius model, but not sure.
    The 54.5 MPG target is really hard to understand...it's really 40 EPA MPG but then automakers get all kinds of credits, and 54.5 MPG may go down if more F150's lower the average...gets to the point where I think we're really talking 30-35 MPG vs. 25-26 today.
  15. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
  16. bwilson4web
    16,195
    Technically you are correct. Following the baseline, 1975 testing protocol:
    • 55% * FTP ## urban cycle
    • 45% * HWFET ## highway cycle
    Poor urban performance has been the biggest driver because the highway cycle is so much easier. Being a Prius owner, I simplify the calculations by using just the FTP MPG. Regardless, the raw data is available in the source file and can be easily enough calculated:
    1. Extract the FTP cycle MPG for each model into a table, keep the best
    2. Extract the HWFET cycle MPG for each model into a table, keep the best
    3. Combine the two and use 55% and 45%
  17. Zythryn
    6,408
    4,407
    Thanks Bob.
    Shame, I was hoping there was the actual CAFE numbers somewhere in there.
    It seems there is a lot more going into the new CAFE ratings. I found some details here, Corporate Average Fuel Economy - Wikipedia, the free encyclopedia
    Specifically
    This also has some interesting info: The CAFE Numbers Game: Making Sense of the New Fuel-Economy Regulations - Feature - Car and Driver
    I'd really like to figure how this is all calculated on a vehicle, not fleet, basis. It is very convoluted though.
  18. bwilson4web
    16,195
    Careful what you ask for:
    make-model-id FTP HWY CARB MPG
    1 CHEVROLET-IMPALA-361EGP4200 10000.0 10000.0 10000.0
    2 AUDI-Audi A6-GAAC-CAF 10000.0 10000.0 10000.0
    3 AUDI-Audi A6-GAAC-CAQ 10000.0 10000.0 10000.0
    4 CHEVROLET-IMPALA-361EGP4200 10000.0 39.3 5517.7
    5 TOYOTA-MIRAI-16-JD1F 94.1 94.1 94.1
    6 TOYOTA-PRIUS Eco-16-ZV2H 84.1 78.2 81.4
    7 TOYOTA-PRIUS Eco-16-ZV2H 84.1 76.9 80.9
    8 TOYOTA-PRIUS Eco-16-ZV2H 82.5 78.2 80.6
    9 TOYOTA-PRIUS-16-ZV3H 77.3 76.1 76.8
    10 TOYOTA-PRIUS-16-ZV1H 78.0 71.2 74.9
    11 TOYOTA-PRIUS c-12-NP2H 75.0 71.4 73.4
    12 Hyundai-Tucson Fuel Cell-LMFCTV000098 68.0 71.9 69.8
    13 TOYOTA-PRIUS c-12-NP1H 71.4 66.6 69.2
    14 TOYOTA-PRIUS-16-ZV1H 71.1 66.0 68.8
    15 TOYOTA-PRIUS c-12-NP2H 69.0 68.0 68.6
    16 TOYOTA-PRIUS Eco-16-ZV2H 56.3 76.9 65.6
    17
    18 Pagani Automobili-PT4-EDV14PAG01 12.9 20.4 16.3
    19 Ferrari-F12 Special Series-180311_F152VS 13.0 20.1 16.2
    20 LAMBORGHINI-AVENTADOR-LB83-DSSCD 11.5 21.2 15.9
    21 Mercedes-Benz-AMG G65-G463E60TC-Z6021 13.0 18.6 15.5
    22 Ford-F150 FFV 4X4-FFA00014 12.8 18.8 15.5
    23 TOYOTA-TUNDRA 2WD FFV-16-SK1A 12.0 18.1 14.7
    24 TOYOTA-TUNDRA 4WD FFV-12-SK4A 11.9 17.3 14.3
    25 TOYOTA-TUNDRA 2WD FFV-16-SK1A 11.5 17.7 14.3
    26 TOYOTA-SEQUOIA 4WD FFV-12-SK4A 11.4 17.5 14.1
    27 TOYOTA-TUNDRA 4WD FFV-12-SK4A 11.6 17.2 14.1
    28 TOYOTA-SEQUOIA 4WD FFV-12-SK4A 11.1 17.2 13.8
    Zythryn and wjtracy like this.
  19. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Don't forget EPA test are conducted with 100% pure gasoliine, no Ethanol, unless of course for E-85. So from the start, results will be 3-5 % lower when you use E-10 gasoline.
  20. Blizzard_Persona
    1,787
    947
    Pa.
    2023 Prius Prime
    XSE
    Really? I did not know this..
    If true that's kinda screwed as pure gas is next to impossible to find most anywhere that I know of?
