Need some advice after breakdown and what the dealer says is wrong
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Maveric169, Jan 16, 2016.
  1. Maveric169
    Maveric169 Junior Member
    I have 2007 prius with 230K miles on it. On my way to work the other day I started to hear a banging sound that I could feel though out the car. I noticed that my battery indicator showed only 2 bars and the car was not charging. I pulled over, and let the car idle and it charged the battery to 3 bars and then stopped charging, the entire time the banging was still happening. I drove another 3 miles, trying to get off the interstate, when I got a flashing transmission light, and the traction control light intermittently flashed. A few seconds after that, it was like the car was in neutral, no acceleration, but I can hear the engine rev when pressing on the gas peddle. next I got the triangle of death. I shut down the car, waited a few mins, and restarted it. still had the banging sound, flashing engine or trans light (not sure which it is off hand) and I was able to drive again at least long enough to get off the interstate. I had the car towed to the nearest dealership.
    The dealerships report was that they experienced everything I told them about and that their findings are as follows:
    1) There is "a lot" of oil in the intake manifold and that the intake manifold need to be removed and cleaned and a new gasket put on. (I know they have to replace the gasket if they remove the intake)
    2) All spark plugs are heavily worn and or fouled and need to be replaced. (pretty standard maintenance item and they haven't' been changed in at least 3 years)
    3) Computer codes show rich condition and that fuel injectors 3 and 4 are stuck in open position and must be replaced, Other 2 injectors may need to be replaced but unable to determine at this time.
    4) a Compression Performance restoration is required to correct the oil consumption issue of approx 1 quart of oil per 600- 800 miles driven.
    5) One belt needs to be replaced as it shows signs of serious deterioration and could break any time.
    6) Engine air filter needs replaced.
    Grand total for this plus the $100 diagnostics is $1100
    Looking at the estimate they sent me, the parts pricing is about what I would pay from the auto parts store, so I don't think their ripping me off there, but of course the $95/hr labor rate costs as much as the parts total.
    My Questions are these:
    Has anyone had similar issues and had the stated repairs made and did it fix the problem.
    How difficult is it to change the fuel injectors, and spark plugs and remove the intake manifold? I am mechanically inclined, I usually do the work on most of my cars.
    my concerns are that this does not solve the problem and then they will come back with another $1000 worth of repairs that the car needs. So If the repairs are fairly simple and straight forward, I would tow the car home, spend the $400 in parts and do the work myself, or if their are things like the injectors that are a pain in arse to replace, pay the dealer to do that and do the rest myself, etc.
    Any advice or input or links to other posts like my issues are welcome.
    51,525
    welcome! what kind of regular maintenance have you done to the car? please ask them for the codes and post them here.
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I'd be interested to know exactly what this step entails. Normally this would require reboring the engine and fitting oversized pistons and rings, so it's generally cheaper to just replace the entire engine with a secondhand unit. For the price you've been quoted they're definitely doing neither of the above.
    #3 uart, Jan 17, 2016
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Yeah, me too. I'm wondering if it's this--good old tune-up-in-a-can. I'm not knocking BG products--I've had pretty good luck with them with older cars.
    Changing the belt and filter on a car that appears to have a major mechanical problem doesn't sound like the best place to put your money right now. Spark plugs and fuel injectors might be a good path to follow, and why not--a can of BG too. I haven't done anything with the injectors, but I think there are some threads here about it. If the miracle happens and that fixes it, go ahead with the other maintenance stuff.
    But first, get the entire list of diagnostic codes you paid for and research them. Definitely look for hybrid system codes, not just the engine.
    Oil in the intake manifold is a well-known, common condition in these cars. Mine runs perfectly and has a puddle of oil visible through the throttle body. That alone makes me question this whole diagnosis.
    uart likes this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Sounds like the motor lost a bottom end bearing. This is a very common scenario on a high mileage poorly maintained G2 motor.
    The motor eats oil. Alot of oil because somewhere in its life it ran so low on oil it threw a dashboard code and damaged the motor. So now its eating so much oil hard to keep up with it and was driven with very low oil alot and that usually smokes either the main bearing and or connecting rod.
    The interior bottom end of this motor is splash lubricated. Main bearing section and upper cylinder & piston. Low oil no splash.
    Your post is quite odd. How did the dealer know all the plugs were fouled? They took them all out to check? That's alot of time.
    Anyway none of the things you listed would cause a banging noise. Start looking for a new used motor in a boneyard.
    Btw, search you tube for "Prius Inspection mode". That allows the engine to run continuously. Start the motor if you can and get under the front of the car ad listen to the bottom end the motor.
    uart likes this.
  6. Mendel Leisk
    40,975
    Our 3rd gen with relatively low kms has a shallow pool of some sorta oil showing in the intake manifold floor, when I look through the throttle body, suspect it's normal.
    uart likes this.
  7. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yeah that was exactly what I was thinking too Andrew. It's just pretty deceptive the way they listed this item. It should read something more like:
    4. Add a can of snake oil and hope for the best.
    I agree with both of the above. If the "banging" is as bad as what it seems from the op's description then this engine has a major failure that nothing on that dealership report would address.
    It would probably be worth ruling out that it wasn't just running rough due to misfire on one or more cylinders though. This might make the engine run rough and vibrate, though I don't think it would normally cause "banging".
    Yes, a lot of people have reported seeing this on the gen2 as well. As long as the oil isn't routinely overfilled I think any oily looking traces in the manifold are probably harmless.
    #7 uart, Jan 17, 2016
  8. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    The banging must have been backfiring. I hope you didn't toast the catalytic converter. Maybe you start with the two bad injectors.
  9. edthefox5
    10,096
    4,833
    Clearwater, Florida
    230,000 miles and a quart of oil every 600-800 miles. Move on don't spend a dime on it.
  10. 48mpg
    48mpg Member
    193
    47
    florida
    I
    with the age and miles id be looking for a used motor on ebay or junk yards, changing things like air filters and belt and fuel injectors is basic any shop can do , no need for the dealer
  11. 48mpg
    48mpg Member
    193
    47
    florida
    I
    my 05 was going through a qt every 1000 miles, changed the pvc valve and now it uses next to none
    Dino33ca likes this.
  12. Maveric169
    ok a little follow up to the posts, the Compression Performance Restoration is basically just a cleaner they put in the motor to remove carbon deposits. Snake oil in a can. I did this with a previous car and never had so many problems. Too a month of running the car to get it to run right afterwards.
    I have to wait till Monday to call and get the codes as the estimate they emailed me doesn't have them on it.
    Has anyone here changed their injectors and or spark plugs themselves? If so, are their any guides or links to guides you know of that describes the process. I would like to investigate changing the bad injectors and plugs first and see what happens from there. As I posted i just don't think that these two items are the fix to the problems, but only way to know is to get the fix the main issues. If it is a simple enough job, I will pay the $100 for the diagnostics and do the work myself and see what happens.
  13. Mendel Leisk
    40,975
    Changing spark plugs is pretty routine, and I believe with second gen you don't have to take the car half apart for access. Fuel injectors sounds a little more advanced. If you elect to have them do the injectors, I'd be inclined to have them do the plugs at the same time.
    Also, completely out of my depth, but would it be a good idea to replace all four injectors? How much are they? Just pre-emptively.
  14. Maveric169
    the fuel injectors parts costs for 2 is $323.42 so about $160/ea
  15. Patrick Wong
    18,200
    6,499
    That is MSRP. You can buy the correct fuel injectors for $117 each plus shipping here:
    FUEL SYSTEM COMPONENTS for 2007 Toyota Prius
    And of course if you are willing to use aftermarket then you can pay even less.
    When you replace the injectors, the main issue is not to damage the rubber O-rings when installing the new injectors. Use the correct lubricant.
    For the service procedure, consult techinfo.toyota.com
  16. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    Ask them for the exact computer codes. The tech who looks at your car sounds like he doesn't have a clue what is wrong with it.
    He may as well have suggested a tarot card reading, voodoo and an Ouija board at least if you spend your money on those things you may get some entertainment value out of it.
  17. 48mpg
    48mpg Member
    193
    47
    florida
    I
    look at youtube for plug changing videos ...pretty basic
  18. Maveric169
    ok, had the dealer email me a printout of the trouble codes, it is quite a list so here goes:
    P0301 CURRENT, PENDING, HISTORY
    P0A0F CURRENT, HISTORY
    P0304 CURRENT, HISTORY
    P0302 CURRENT, PENDING, HISTORY
    P3190 CURRENT, HISTORY
    P0172 CURRENT, PENDING, HISTORY
    P0300 CURRENT, PENDING, HISTORY
    P3190 CURRENT
    B1271 HISTORY
    P0304 CURRENT
    C2142 CURRENT
    B1421 CURRENT
    I haven't had time to look up the codes yet but wanted to update the post here asap.
    tpenny67 likes this.
  19. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    On a Gen2 plugs are easy via YouTube. I just used my Sears ratchet wrench with an spark attachment. The plugs are special iridium and last up to 150k miles, so about now you need a second set depending on if they were changed at 125K once already. I don't plan to do it until 250k miles if I still have the car (doubt it).
  20. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    I looked up a few on Google. The P030x are "universal" (not just Toyota/Prius) codes for misfires on cylinder x. P0172 is "too rich". P3190 is poor engine performance. This would all be consistent with bad plugs and fuel injectors. However, you also have some strange codes such as B1271, which is some communication problem I don't understand. So is it a computer problem causing the engine to run poorly? Or is the poorly running engine causing communication codes?
    This is well outside my expertise, but I can't help playing armchair mechanic :)
    BTW, my 2014 sometimes makes a "banging" noise for a second or two when first started, and apparently is related to the engine running rough when it sucks in condensation from the intake manifold. It sounds awful, but I wonder if it's actually the motors and gears making the noise as they rapidly speed up and slow down when the engine isn't running smooth.
