Need help installing my body kit
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Escalade_on_22s, May 9, 2006.
  1. Escalade_on_22s
    Escalade_on_22s New Member
    70
    Las Vegas, NV
    I just got my painted JDM ver A body kit today. It looks like it will be an excellent fit/finish, but apparently you have to disassemble the front and rear end of the car to put it all together. It's probably pretty simple, but the instructions came in Japanese, and I'm not too sure that I want to just start winging it (I'll probably end up deploying and air bag or something) Has anyone done this install, and if so do you have any advice? Thanks,
    Bryan
  2. NuShrike
    NuShrike Active Member
    1,378
    <div class='quotetop'>QUOTE(Escalade_on_22s @ May 9 2006, 04:35 PM) [snapback]252436[/snapback]</div>
    Maybe you can scan it in and put it online? My SO can probably translate it for you.
    The other way is to OCR it and push it through something like Google/Yahoo Translate.
  3. Escalade_on_22s
    70
    Las Vegas, NV
    <div class='quotetop'>QUOTE(NuShrike @ May 9 2006, 06:56 PM) [snapback]252445[/snapback]</div>
    No need, but thanks for the advice. It was very easy to install, and I finished it in less than three hours without reading a thing. I'm very happy I went with this kit because it comes with factory mounting hardware and fits like stock bodywork (which I guess it is). Now for the TRD suspension...
  4. JosephF
    JosephF Junior Member
    17
    Reading, PA
    2025 Prius
    <div class='quotetop'>QUOTE(Escalade_on_22s @ May 10 2006, 03:27 AM) [snapback]252659[/snapback]</div>
    How about posting some photos. I'd like to see the end product.
    Thanks,
    Joe
  5. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(JosephF @ May 10 2006, 07:05 AM) [snapback]252668[/snapback]</div>
    Ditto.
  6. Escalade_on_22s
    70
    Las Vegas, NV
    <div class='quotetop'>QUOTE(DocVijay @ May 10 2006, 07:39 AM) [snapback]252686[/snapback]</div>
    My camera's back in Vegas, so when I go home this weekend I'll snap a few shots and post them. Interestingly, the rocker panels act as insulation and road-noise is reduced a few dB. The kit is VERY light and added less than 14 pounds to the vehicle. (You remove the crappy stock rear spoiler and black rocker protectors). The only added weight is 4 lb for the front spoiler and 5 lb for each side skirt. I got over 60 mpg on my 10 mile highway trip to work this morning, but I had a slight tailwind instead of a 30 + knot crosswind like usual.
  7. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Escalade_on_22s @ May 10 2006, 02:43 PM) [snapback]252964[/snapback]</div>
    Hmm. Very interesting about the mileage. I wonder how much the body kit helped... As far as the weight is concerned, adding weight to the body has a minimal effect. You have to add something like 100 pounds to the car to be hte equivalent of adding 10 pounds to a wheel. It's a huge difference. So for me, my wheels is the equivalent of having two football players in the back seat!
    Anyway, the strut and suspension braces had instrutions in Japanese too. Like you, I just figured it out and did it.
    And for the Sportivo kit, you have to wait till I get mine!
  8. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Do you have mud guards installed? Do you think the kit will effect the mudguards at all? Just wondering because i'm thinking about getting the kit but it looks like it might interfear with the mudguards.
  9. Escalade_on_22s
    70
    Las Vegas, NV
    <div class='quotetop'>QUOTE(theforce @ May 10 2006, 03:18 PM) [snapback]253037[/snapback]</div>
    There is no interference with the stock mud-guards, the side-skirts are molded to conform with them. Enjoy the pics.
    [attachmentid=3369]
    [attachmentid=3370]
    [attachmentid=3371]
  10. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Looks GREAT! I have the mudguards that come from Canada. From the looks of it the front mudguards would have a problem. The rear looks just like the black stock spoiler but painted so the rear mudguards should fit. Can anyone with the mudguards from Canada confirm this?
  11. Drift Motion
    Drift Motion RMS13
    178
    Pasadena/Riverside, CA
    oo
    very nice
    i love lip kits
  12. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    Nice looking car. Not too ricey, but different from most of the others. Now you need a shark fin to top it off. White is right!
    Does the front spoiler help with high speed stability, or is it "looks" only? If I had that it would scrape on my driveway. The baby sized stock one scrapes now! :(
  13. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(subarutoo @ May 11 2006, 03:46 PM) [snapback]253670[/snapback]</div>
    Agreed. That would certainly complete the exterior!
  14. Escalade_on_22s
    70
    Las Vegas, NV
    <div class='quotetop'>QUOTE(DocVijay @ May 11 2006, 04:30 PM) [snapback]253722[/snapback]</div>
    I think a shark-fin would look real nice, but I work way out in the middle of BFE and I need all the antenna I can get. The only good FM station I can tune is already weak, so I think a shark fin would leave me with some polka and mexican party music, although I guess I should learn Spanish sooner or later anyway. Maybe I'll pull a 10 ft whip off a military Humvee instead.
  15. Escalade_on_22s
    70
    Las Vegas, NV
    <div class='quotetop'>QUOTE(subarutoo @ May 11 2006, 02:46 PM) [snapback]253670[/snapback]</div>
    I imagine you're actually scraping the black protector that hangs below the radiator. Scraping the actual bumper would really screw up the front of you car and probably break the black plastic mesh that houses the fog lamps.
    Although I haven't had a long enough trip to assess the new handling characterics at high speed, I'm fairly confident that it'll provide some added stability at highway speeds, where the car suffers from incredible handling woes. It may actually do more for high speed handling than the Sportivo suspension itself (I'll know in about a week or two). I've also noted a decrease in road noise at high speed, although the car was nearly silent to begin with (once I removed the scion rims).
  16. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    I would like to hear from someone that has installed the KenStyle areo kit w/pics... ;)
    But your car looks great :lol:
  17. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Escalade_on_22s @ May 11 2006, 06:39 PM) [snapback]253785[/snapback]</div>
    Then you simply need to order the integrated XM unit an a micro antenna to mount under the shark-fin so you'll have good music!! See, there's always a better way and a good excuse for a new/expensive toy!! :)
  18. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Escalade_on_22s @ May 11 2006, 07:39 PM) [snapback]253785[/snapback]</div>
    Just get an iPod and the VAIS or other unit to integrate. I only listen to the radio on occasion, and that's for NPR. I use my iPod almost exclusively! Who needs radio?
  19. Escalade_on_22s
    70
    Las Vegas, NV
    <div class='quotetop'>QUOTE(DocVijay @ May 11 2006, 10:24 PM) [snapback]253916[/snapback]</div>
    I thought about getting an IPod about a month ago when my entire CD collection (of 15 years) was stolen. I want it to integrate fully (the ability to select music from the MFD), but I don't have enough experience yet with CAN interfaces to have faith in the end product. Is there a product out there that displays track information and allows you to select music lists directly from the MFD?? Also, I wouldn't mind getting Sirius, but I want it done the same way with no botched-up, jerry-rigged pieces inside my car. Any guidance and personal experience would be appreciated.
  20. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Escalade_on_22s @ May 11 2006, 11:37 PM) [snapback]253928[/snapback]</div>
    I'm actually beta testing a new unit for VAIS that does show all the track info on the MFD. It works just like the radio's mp3 player works. It's new, as the 2006 Prius has a few changes.
    Watch their website for updates.
