HELP! Locked my keys inside my car. It has keyless entry
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Diane Terry, Jan 31, 2016.
  1. Diane Terry
    Diane Terry New Member
    Huntsville, MO
    Is there a remote way to unlock my car that has keyless entry? The key is locked inside.
  2. Dion Kraft
    Dion Kraft Member
    290
    86
    Washington, UT
    Is your 2nd key at home but too far away?
  3. bisco
    51,058
    what happen when you put your hand on the handle? how did you lock the car?
    rifis likes this.
  4. xliderider
    xliderider Senior Member
    8,041
    3,213
    Honolulu, HI
    Congratulations!
    It's very, very difficult to lock your keys in the car. The car makes it nearly impossible to do it accidentally, so there must be more to your tale of woe. Maybe a detail such as ignored a low key fob battery warning message for days/weeks, then the battery died, etc.
    sfv41901 likes this.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I was going to say, if the key fob is in the car, depending on the year of his/her car, shouldn't you be able to grab the drivers door handle to open it? Sorry to hear about this. No fun indeed. I don't have an answer.
  6. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Call a locksmith they will help you
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U can keep the fob inside, roll a window down, reach in to power down, relock the already closed door & roll up the window. This will get ur key locked inside. Don't worry......I've never locked my key inside but I know this route will work :D
    My suggestion Is to get ur 2nd fob. If this is not an option then a call to AAA is in need
    iPhone ?
    xliderider likes this.
  8. bisco
    51,058
    anyone else picturing diane sitting on the hood for the last 21 hours, puzzling over this?
  9. xliderider
    8,041
    3,213
    Honolulu, HI
    LOL, like I said, you have to really make an effort to bypass all the built in guards to lock your keyfob in the car. :D
    Good on you to figure out how it's possible. (y)
    scona and sfv41901 like this.
  10. lizardskin
    lizardskin Junior Member
    26
    Northeast USA
    How do you roll down/up a window from outside the car? I would only be able to do this from inside the car.
    Anyway, this is why we replaced our 2nd FOB immediately when DH lost it (about $200). I did not want to get into a situation like this.
  11. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Without a locksmith, the old, coathanger method is about the only way.
    Make a hook shape and catch the window button or lock button.
    I bought a lockout kit just for these situations.
    Basically is some semi-ridgid coated metal rods and plastic wedges.
    For the future, would be worth buying a metal key
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Easy:
    Keep Prii on & fob on dash
    Roll window down
    Get out & close door
    Reach in, power dwn & lock doors
    Now while reaching in, close window.......Tada......u just lock ur fob inside.
    iPhone ?
  13. namastaywithme
    namastaywithme New Member
    Centerville, NJ
    If the keys are in the door, whether in the top handle part or the cup holder, you can lock the keys in the car. When people are driving, if the keys are on the seat and you take a hard turn (like I did today :( ) they fall into the door cup holder, it somehow disables the system from sensing the key in the car?! I called AAA and he broke into my car to open the door and find the keys right in the door.
  14. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    I find that just having my key fob in my left pants pocket versus my right can rarely trigger “key not detected” warning light. But just shifting around in the seat and it will go away.
    On another note, since it was spelled out “how” to lock my key in the car, I must do this myself. I’ll just make sure I have the mechanical key in my pocket when I do it.
  15. wr69
    wr69 Member
    141
    77
    portland, or
    Aaron Eiben likes this.
