Front Fog Lamps
Discussion in 'Gen 4 Prius Main Forum' started by Mark A. Cooper, Feb 10, 2016.
  1. Mark A. Cooper
    Mark A. Cooper Junior Member
    Sarasota Fl
    I have just got a new 2016 Four Prius. Previously a BMW driver. I love it, I like the Four package and thought the Touring was not worth the extra cost. (Of course I am frugal one reason I got a Prius)
    Is it possible to buy a set of Genuine Prius 2016 Front Fog lamps and if so do I need an extra switch and wiring?
    (As a first time Prius driver and owner, I am stunned how nice it drives)
    bisco and krmcg like this.
  2. krmcg
    2,592
    2,391
    Whittier, CA
    Plus One
  3. Mark A. Cooper
    Sarasota Fl
  4. krmcg
    2,592
    2,391
    Whittier, CA
    It means "me too". As in I would be interested in fog lamps for my 2016 Four...
    By replying within the thread, I keep updated.
    Mark A. Cooper likes this.
  5. cjecpa
    cjecpa Member
    160
    58
    I was wondering this the other day. Does anyone know if the Prius comes from the factory already wired for the fog lights? My Subaru was all I had to do is was buy the OEM lights to install be interesting if you brought an ECO that you could install them.
  6. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    I'd be surprised if they come with the switch and harness installed. The gen 3/3.5 don't.
    sfv41901 likes this.
  7. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    The reports I've read are that these are cosmetic lamps rather than lamps that help you see in foggy conditions.
    If this is so, how important is it that they be wired?
  8. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    FWIW, the physical switch is an extra ring on the light stalk-- inside the ring for high beams, auto, DTRL, etc.
  9. bisco
    51,028
    congrats on your purchase mark, all the best!(y)
  10. cjecpa
    cjecpa Member
    160
    58
    On my Subaru the stalk was already set up they sent you a switch and a lower dash cover for the new switch and you had to install a new relay behind the glove box. . Took about a hour at tops to install everything.
  11. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    That's a bit disappointing, I thought they would be better this time beeing LED !
  12. ATHiker
    644
    560
    Massachusetts
    Four Touring
    Not sure if there has even been one report from an individual who has tried to use the in the fog. If so, perhaps someone could provide a link.
    They did help (at least in my imagination) me spot the tail end of a very brave raccoon, though.
  13. Tideland Prius
    16,429
    For the Gen 3, the kit came with a foglight switch that you added to one of the blanks on the driver's side. You had to wire the entire set so I don't see why the Gen 4 will have all the wires (saves weight if you don't include it).
    Hopefully Danny can offer a set on PriusChat Shop.
  14. Mendel Leisk
    40,472
    A test you could do with 4th gen OEM fog lights: away from street lights, with low beams on, switch the fog lights on/off. Is it a "Whoa!" moment, or an "I think I see a difference" moment? The latter is the case with 3rd gen.
  15. energyandair
    905
    339
    Victoria BC Canada
    I had a quick look on the net to refresh what I remembered about fog lamps and learn a bit more. I'm no expert but this is what I came up with.
    Fog lamps are intended for use in extreme conditions when high beam or low beam or driving lights are useless because so much glare bounces back into your eyes from falling snow, fog or heavy rain that you cannot see the road. (e.g. White-out conditions)
    They are intended to provide a good enough view of the road immediately in front and to the side of the car to permit you to drive forward slowly in reasonable safety when visibility is so bad that otherwise you should stop.
    For fog lights to be effective, the other lighting systems need to be off. In some cars this may not be possible and in some jurisdictions it may be illegal.
    In less extreme conditions when its possible to drive at more normal speeds the other lights should be used and the fog lights should be off as they will not help and they will add somewhat to glare and distraction thus reducing net safety.
    They should be mounted low and have a cutoff to minimize glare and so that they can penetrate below fog hanging just above the road surface.
    I found this link useful. Daniel Stern Lighting Consultancy and Supply
    EDIT: Underlines added for emphasis and because final wording had not initially displayed
    #15 energyandair, Feb 12, 2016
    KrPtNk and Mendel Leisk like this.
  16. Mark A. Cooper
    Sarasota Fl
    I suspected I would need a new switch, If the wiring is there, then it could be a simple job for under $300.
    Thanks for the update
  17. civicdriver06
    797
    324
    Germany
    I guess I allready said this,but fog lamps in Germany are only allowed to be activated if visibility in front of my vehicle goes down to under 50 meters !
    This can happen if thick fog appears,its raining or snowing heavily.
    They are ment to illuminate the sides of the road alongside the headlights .
    At the same time a very bright red light must be activated on the rear of the vehicle, so drivers behind me know there's a vehicle travelling ahead of them !
    If you drive around with fog lights switched on for no reason,especially the one in the rear you will get a fine ,because the rear fog light is so bright it can dazzle other drivers .
    it's designed to cut through thick fog .
    Unfortunately it makes absolutely no difference or at least it's very hard to see if the front fog lights are activated on my gen.3 Prius,so I am hoping for improvement !
    Really they should be better now beeing LED or aren't they LED ?
    #17 civicdriver06, Feb 12, 2016
  18. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    Holy mackerel, that is HYSTERICAL :ROFLMAO:
    Seriously though, while cosmetic, I'd say only 30% of the cosmetic benefit (e.g., replacing the gray plastic plug with something that looks better) is achieved with a dead fixture (and quite expensively!), since its main appeal is the spiffy row of LEDs glowing and lined up below your headlights or DRLs. Along the lines you're suggesting, though, I'd give serious consideration to a reasonably priced reflector or dummy lamp to replace the gray sludge they stuck in the corners of my bright red bumper. Failing that, maybe it would be worth having a shop remove it and paint it with a durable black or silver finish, but I'd have to think that one through.
    Honestly, it's annoying to have to do ANYTHING. An enhancement for Touring buyers is one thing; punishing everyone else is just lame.
    Merged.
    Judge for yourself:
    LED headlight performance | PriusChat
    #18 Vike, Feb 12, 2016
  19. civicdriver06
    797
    324
    Germany
    Thanks !
    Well they do seem to put out more light than my gen. 3 fog lights !
  20. Vike
    Vike Active Member
    379
    303
    Albuquerque NM
    You need to look more closely at those pictures. Note that they're not to the same scale; taking that into account, there's hardly any difference at all.
