Worst Model Year: 2010; Worst Complaint: excessive oil use
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Former Member 68813, Jan 28, 2016.
  1. luckyboy
    luckyboy Member
    204
    29
    There are often suttle changes from year to year or even within a year that are not apparent to the consumer
  2. CR94
    CR94 Senior Member
    2,662
    1,149
    Northwestern S.C.
    Yes, exactly. Another missing critical detail is the ratio of oil-guzzlers to non-guzzlers at various mileages. Nobody seems to know exactly how prevalent the problem is.
  3. bisco
    51,032
    no and there's probably no way to find out. smartest thing to do is keep an eye on it between changes, especially after 75k or so.
  4. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    Here's a data point: 2014 Prius with 18k miles, and about 8.5k miles since last (first, only) oil change. The oil level has dropped not quite a quarter of a quart, so estimated consumption when "almost new" is about 1 quart in 40k miles.
    Can other low mileage owners respond and answer with either a) how much the level on the dipstick drops between oil changes, or b) what's a dipstick? It would help answer the question of whether oil consumption comes on suddenly, or whether people suddenly notice the consumption because they weren't paying attention.
  5. CR94
    CR94 Senior Member
    2,662
    1,149
    Northwestern S.C.
    Thanks for the data point, tpenney67. Very low oil consumption when these engines are "almost new" seems to be typical. Mine has used very little, between 41,100 miles (when I acquired it) and 55,706 (now). Things seem to get more interesting around roughly 100K miles, plus or minus, depending on unknown factors, when something clogs or wears out, even on some allegedly well-maintained examples.
  6. tv4fish
    tv4fish Member
    202
    46
    Just my $0.02 worth - 2010 with 118,000 miles on it. 0 oil use and I use 020W Mobil one and change at every 10,000 miles. I'm a happy camper.
  7. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    I have a 2010 and mine started consuming at about 100k miles. I'm the second owner, but the car had been serviced regularly by the original owner at Toyota. I'm at 135k miles now and probably uses about 1qt/10k miles. I'm sure it needs a new PCV valve, but it's too cold and I've been too lazy to fool with it.
  8. ebenke
    ebenke Eco Member
    Where it warm and sunny
    Original owner here who is diligent with service intervals. My wife's Prius has nearly 80k miles and uses several quarts between oil changes. It's very frustrating. That type of consumption is inexcusable and not normal wear & tear. Heck my old Porsche C2 that had oil leaks, used less oil than her Prius. The next time she goes in for maintenance, we'll need a diagnosis.
    EBenke
  9. tpenny67
    464
    403
    Massachusetts, USA
    Yes that does sound excessive. Is there anything notable in your wife's driving patterns? Specifically, does it get regularly highway mileage where the engine gets fully warmed up? Or is it a lot of city driving with the engine cycling on and off?
    I have noticed that during the winter, the only time the engine gets fully up to temperature is on the highway. Otherwise, the temperature is all over the place as the engine cycles on and off, and I have to wonder what effect all that expansion and contraction has on the engine. Of course, is that was THE cause of problems then we'd never see high-mileage Prius taxis.
  10. Former Member 68813
    3,524
    983
    US
    not sure what the question is. mine ate 0.5 qt in the very first 10,000 miles and nothing measurable after that. i'm at 72,000 miles now.
    we do know the answer, it comes suddenly and surprises people, especially if they are used to no consumption and stopped checking.
    also, this is what happened with my old corolla. one OCI no oil consumption, next OCI, oil consumption (at 70,000 -75,000 miles IIRC).
  11. ATlam
    ATlam Member
    64
    57
    San jose
    this is a new account but I frequent this forum and this is my experience
    I recently bought a 2010 prius ( I was looking for a high mileage prius with good record because of my limited budget and wanting the latest model). The car has 170k miles (now 180k ) and I have put 10k miles on it with no noticable oil burning. Everything runs like new so if anyone is thinking of avoiding high mileage prius i recommend giving it a shot as long as it is taken care of.
    I took it on a few 850 miles nonstop trips at roughly 80mph the whole way on interstate 5 and the oil level remain steady on this 2010 model.
    CR94 and bisco like this.
  12. bisco
    51,032
    congrats and welcome! thank you for the data points, all the best.(y)
    ATlam likes this.
  13. Mendel Leisk
    40,482
    Original owner, around 58,000 kms, no noticeable drop in the dipstick level between (shortish by US std's) oil changes.
  14. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    Im at 50k miles and I have no noticeable oil consumption. I hope it stays that way.
  15. stephane
    stephane Prius v owner
    120
    64
    Quebec Canada
    2013 Prius v wagon
    would be nice to see if Canadian Prius have same problem over here oil change is 8000 kilometre (5000 miles)
  16. frodoz737
    frodoz737 Top Wrench
    4,506
    2,427
    33
    Even with sleeved aluminum motors, extra care should be given with oil maintenance...and one oops is all it takes.
  17. ebenke
    ebenke Eco Member
    She does a lot of stop and go driving. Short trips around town. She had to add two quarts last time. I'm guilty f not checking it regularly, and shouldn't have to. Really ridiculous at this amount of miles.
    My '07 Tundra is has 87k miles and doesn't use a drop of oil, no matter how it's driven, or how far or how long...
    EBenke
  18. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Most manufacturers say 800 - 1000 is still ok per quart. I think that excessive.
    Our older Prius the 2011 has 135k -- I add maybe 1/2 quart over the 10k. With only a little over 4 quarts I keep them topped up.
    I normally get the oil deals that come with 5 quarts -- so my local indie give me back the 1/2 quart and i keep that in the car.
  19. tpenny67
    464
    403
    Massachusetts, USA
    Interesting. For comparison, we recently inherited an '07 F150 which at the time had 26k miles and had been used for the very occasional trip to the grocery store and back, and was driven only 1k miles in all of 2013 based on the service records. When we first started driving it, I had to top up the oil a couple times and estimated the consumption rate at about a quart every 4k miles. After a year or so of steady 100+ mile highway trips as we clean out the estate, it appears to have stopped all consumption, and hasn't used a drop since the last oil change 2500 miles ago.
    Also interesting to note, the F150 hold 7 quarts of oil and has a 5k OCI, which means buying 14 quarts of oil every 10k miles even with zero consumption. That's comparable to a Prius with a 10k OCI that burns a quart every 1k miles.
    And at the risk of really going off on a tangent, I recently heard about the million mile van (Home) which used so much oil the owner didn't feel the need to change it as frequently:
    "I used Valvoline 10W-40 motor oil and change it every 10,000 to 20,000 miles. The longest I’ve went between oil changes is 55,000 miles. It used a quart of oil or more every tank of gas. I usually waited for the oil to turn black before changing it."​
  20. Former Member 68813
    3,524
    983
    US
    if i ever reached those "normal" levels of oil consumption, i would stop oil change and only do oil filter change.
