2010-2015 or 3rd Generation Prius Brake Flush Video
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NutzAboutBolts, Jan 9, 2016.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,739
    Bay Area
    We just did a 3rd Generation Prius brake flush, I will be uploading the video here once it's done being edited. Thank you for your patience...Video is up! Enjoy :)
  2. mrbigh
    3,686
    699
    Long Island, NY
    Kudos for U
  3. frodoz737
    frodoz737 Top Wrench
    4,695
    2,495
    33
    Nice!
    #3 frodoz737, Jan 9, 2016
  4. Mendel Leisk
    41,402
    How many bottles of fluid would you advise to have on hand? Say 8 oz bottles, is that still the common size?
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Well done, very interesting! (y)
  6. NutzAboutBolts
    1,693
    1,739
    Bay Area
    We used 2 8oz bottle to do the flush.
  7. gliderman
    gliderman Active Member
    751
    225
    Any brand recommendations for the brake fluid?
  8. NutzAboutBolts
    1,693
    1,739
    Bay Area
    Any DOT 3 brake fluid works.
  9. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    In your video, you referred to a vacuum tool that sucks up the brake fluid. What is this device, and is it affordable for a home mechanic?
  10. NutzAboutBolts
    1,693
    1,739
    Bay Area
    I bought it from MatcoTools along time ago, its called MightyVac. It's a great brake flush kit to have since they have 2 attachments, one is to suck out the excess fluids in the brake reservoir deep down there, and the other is to be used on the bleeder valve. The kit is pretty expensive for the average person and require's an air compressor for it to work. I'm a DIYer so I think it was a great investment, but if you rather have the shop work on your car, then I wouldn't bother investing into tools.
    Other than using it on the brake flush, I use it to suck out the power steering fluids when doing a flush on my other car as well.
  11. kanota
    kanota Junior Member
    Wish you could just flush it like a regular car. I have a motive pressure flusher that I use on all my cars and trucks
    Fone ?
  12. Rebound
    3,996
    2,644
    Portland, OR
    Why wouldn't your Motive pressure flusher work? It looks like it would work fine.
  13. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    While Toyota does provide a service method for replacing the fluid w/o Techstream (or equivalent), it is easy to cause faults to be set during this process that would require a scan tool to clear. If you accidentally caused a fault code to be stored, the brake system will not function properly and you will need to see the dealer (or a shop) anyway - which can turn expensive.
    I copied the info below from the repair manual:
    • So yes - it can be done without Techstream. But if things go wrong, you can have a problem on your hands that you may not be able to solve. I still think it's best to pay the dealer or someone else with the correct tooling to handle this job when the time comes.
    Assenmacher makes a Toyota-specific cap that works great with the Motive. I have used it on my Prius with success.
    VW, Mercedes, BMW, Volvo, Volkswagen, Audi, Ford, Dodge and other Tools for Specialty Applications
  14. Rebound
    3,996
    2,644
    Portland, OR
    I respect what you're saying, but it's very easy to buy an ODB-II cable and software from eBay for under $20. I realize that anyone with a Toyota affiliation cannot recommend using software that's not sold directly by Toyota. However, I think this cable/software should be in the garage of any Prius home mechanic.
  15. Mendel Leisk
    41,402
    If Invalid Mode get's switched off, by one of the listed methods, while you're in mid-bleeding, will that cause a code? It wasn't clear to me from the video. I gather that's what @The Critic is saying.
  16. Rebound
    3,996
    2,644
    Portland, OR
    Yes, but you can easily clear these codes using a laptop and the $18 cable/software bundle from eBay.
    Although, if you follow the video, you won't need the OBD cable and software.
