Really Stupid Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kathleen2, May 10, 2006.
  1. Kathleen2
    Kathleen2 New Member
    77
    I have a really stupid question? Can you switch back and forth from regular oil to synthetic? I’m just wondering if there would be any harm to go back and forth. The reason I’m asking is that I have a case of Castrol GTX but there is a terrific sale for Castrol Synthetic.
    Kathleen
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    In today's cars with today's oils it's OK to switch back and forth. In the past there were issues with doing that, but as I understand it those issues have been resolved.
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :mellow: Hmmm... Just an abstract question...
    Why would someone WANT to switch back & forth from dino oil to synthetic?
  4. john1701a
    john1701a Prius Guru
    12,794
    5,275
    57
    <div class='quotetop'>QUOTE(Charles Suitt @ May 10 2006, 10:55 AM) [snapback]252800[/snapback]</div>
    That is an excellent question. Synthetic oil is a pretty darn cheap preventative maintenance thing you can do for your car, to the point of being trivial compared to most expenses. And it does provide a tiny MPG improvement anyway.
    In other words, is saving that $12 to $15 really worth it?
  5. Walker1
    Walker1 Empire
    911
    FL
  6. aaf709
    3,862
    2022 Prius Prime
    I can think of one reason. I have synthetic in now, but if I discovered a case of dino oil in my garage (which I had gotten for my last car), I would want to use it up.
  7. Charles Suitt
    1,637
    17
    Dallas TX
    <_< Howdy aaf709
    That case of oil... does it "happen" to be the correct viscosity? Seems unwise to risk an engine if it's not the recommended viscosity.
  8. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Charles Suitt @ May 10 2006, 10:25 AM) [snapback]252881[/snapback]</div>
    For the sake of this discussion, let's say yes. That would make it a valid reason to go back to dino (and then back to synthetic when the case is used up), although that wouldn't happen all the time.
    In my case, I did find a case, but as my wife's car uses that same viscosity, I'll use it there. Good thing to remember, though. I also found a case of straight 30W, which I gave to my father to take to the local Aerospace Museum where he volunteers. Someone there might need it.
  9. benighted
    benighted New Member
    530
    Westport, WA
    I've heard that you aren't supposed to use synthetic if you have a higher mileage car that has only used dyno. Synthetic is thinner and won't protect as well in a worn motor (save maybe for high-mile formulations). In other words if you switch to dyno for a significant amount of time you might not want to switch back to synthetic but if you've only use synthetic in the car theres nothing to worry about because there is no extra wear caused by and requiring the thicker dyno oil.
  10. john1701a
    12,794
    5,275
    57
    <div class='quotetop'>QUOTE(benighted @ May 10 2006, 12:40 PM) [snapback]252895[/snapback]</div>
    It will actually protect just fine.
    The problem with a well worn engine late in life that has never used synthetic is the seals aren't that good anymore. So the thinner oil will leak out. That's bad (obviously).
  11. richard schumacher
    7,664
    1,042
    United States
    The 2004 manual advises against switching back and forth between fossil and synthetic but does not say why. Does the 2006 manual not give the same advice?
  12. ralphbongo
    ralphbongo New Member
    83
    Here in Florida full syn. oil is the way to go. It does not attract or hold water like organic oil does. Also with the warmer temps much better engine protection with NO sludge build up. I have been using it in all gas engines (Harley,Truck,Lawn mower, since 1988 and have had 0 oil related trouble. Walmart has mobile 1 for under $20. for a 5qt. jug. And sometimes as low as $16. when they want a lost leader.
  13. Kathleen2
    77
    I looked all over the Owner's Manual and found nothing about not switching back and forth. As for the Great Sale - it was a sham! So no sale.
    If you want to read about my oil changing experience see: Having Fun Changing Oil.
    Kathleen
