intermitten connection problems in the fob
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Former Member 68813, Feb 22, 2016.
  1. Former Member 68813
    3,524
    983
    US
    the OEM battery lasted near 4 years IIRC. the replacement one started giving me problems (low battery) after 1 year. i replaced it again, but realized it was a battery connection problem as the new battery would work intermittently. i greased the battery connections with dielectric grease and everything was fine till now (6 month later).
    now, the fob sometimes works and sometimes it doesn't (dead like a stone). i know it's not a low battery because i can wiggle the fob plastic body in my hands and it will work again fine.
    i'll take it apart for cleaning, but is there something else i should be doing with it (like the full machine wash/dry cycle like some the PC members do)?
  2. JC91006
    JC91006 Senior Member
    16,656
    8,504
    sounds like a bad battery. Maybe you should get it from a different vendor?
  3. Former Member 68813
    3,524
    983
    US
    I'll take it apart and measure the voltage tonight.
    any other ideas?
  4. JC91006
    16,656
    8,504
    I've experienced those symptoms you're describing, it always ends up being a bad battery
  5. Former Member 68813
    3,524
    983
    US
    exactly the same symptoms? with the wiggling/banding the fob temporarily fixing the issue?
  6. JC91006
    16,656
    8,504
    Well, I do that wiggling/banging thing to my garage door openers that don't respond. That always ends up being a battery problem.
  7. Former Member 68813
    3,524
    983
    US
    you are probably right. the old came out with 3.0V. the new one was 3.3V. this was from a batch of cheap, no brand batteries that apparently had expiration date 12/2015. knowing this won't last long, i'm ordering fresh ones, a major brand.
  8. Former Member 68813
    3,524
    983
    US
    the "new" (Chinese, no brand) battery lasted almost 3 months. put new 3.3V, major brand (Maxwell) batteries in in both fobs (the spare was dead like stone). will see how long it will last.
