Checking battery health?
Discussion in 'Newbie Forum' started by Ewing, Feb 27, 2016.
  1. Ewing
    Ewing New Member
    Vancouver
    Very strongly considering buying a very high mileage ex-taxi Prius (or ideally Prius v) as my next vehicle.
    From what I've read, the biggest potential issue is a worn our battery pack that requires an expensive replacement.
    Is there a "how to" thread or YouTube video that shows how to navigate the menu system and determine if the battery is accepting and holding a charge? I'd like to know enough about it so that when I go test drive some in a month or two that I can just click through the menu and pull up whatever screen I need to look at to see if the battery is still good. Thanks!
    51,812
    welcome! no. you would have to take it to the dealer, or get toyota software and do it yourself. you can only test the 12 volt battery through the multi function display. all the best!(y)
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Welcome to PriusChat! You've come to the right place to learn all you're ever likely to need to know about Prii. You would do well to use the "search" feature with "Prolong Battery Charger Grid Charging" as the search-terms, and also:
    Prolong Battery Systems. Extending the life of your hybrid. – Hybrid Automotive
    might also be of some use! (I don't work for Hybrid Automotive, nor do I have any interest in their company, although I must admit that I have purchased a "Prolong Reconditioning Package", purely as a preventative maintenance action - hope this helps - (at least it might save you the search!) - Wil ;)
    #3 WilDavis, Feb 27, 2016
  4. Ewing
    Ewing New Member
    Vancouver
    Hm. Any idea if checking/testing batteries is something that dealerships charge for? I'd imagine there'd be a diagnostic fee of some sort & just curious what it might cost. I suppose the only way to get a real answer on that is to call a local dealership and ask them.
  5. Ewing
    Ewing New Member
    Vancouver
    I thought I remembered reading a thread on here about navigating the on screen menu system over to some screen that would indicate whether the car is switching over to electric drive and using the stored energy from the batteries vs. staying on ICE because the batteries are crapped out and not holding a charge?
    I know that's different from checking the health of the batteries, but, is that a thing that can be checked on a test drive?
  6. bisco
    51,812
    yes, if the battery is weak, the hybrid batter icon which shows a simple state of charge , may fluctuate from low to high to low fairly rapidly. but it's no indicator of a battery that's almost at that point.
    even going through a health check at the dealer can only tell if the battery is within parameters when they test it. when you drive away, one cell can go bad, and your out $3-4,000.
  7. WilDavis
    2,493
    2,155
    49
    I remember reading somewhere about an indication might be if you notice any alteration in the way state of the hybrid battery indicator changes, i.e. how long it takes to go from purple to blue, then blue to green, then all green - I have a ScanGauge-II set to show me the SoC (%) of the hybrid-battery, and over the 2 years I've had the car, I'm now fairly familiar with the correlation between the MFD and the SG-II. As mentioned above, I have a Prolong Grid Charger, and although I think my battery is still OK, I'm taking Jeff's (Hybrid Automotive) advice, and starting to charge/discharge the battery as part of the car's regular preventative maintenance. (…and by the way, if there are any other Prius owners local to me who would like to get and install a harness, I will offer them use of my charge/discharger kit so they might do the same! (…well, we Prius owners must stick together! ;))) - Wil
  8. Ewing
    Ewing New Member
    Vancouver
    $3-4K? I've read on some for sale ads for priuses with bad batteries that the replacement quote is $1800cdn. Hmm
  9. bisco
    51,812
    that is an aftermarket refurb and can be problematic. plenty of threads here for you to judge the goodness of an aftermarket option. a new battery from toyota is $2,000.+ and labor on top unless you diy.
  10. Skeletor916
    Skeletor916 New Member
    Sacramento, CA
    Sorry if this should be in it's own thread but along these lines... I have a question.
    I'm sure we have all read the Art's Automotive predictive failure analysis page Predictive battery failure analysis for the Prius Hybrid
    But I've been trying to use the search function here for explicit directions to get to set up that test, but am having no luck.
    I test drove a Prius yesterday and hooked up my OBD tool really quick to get some readings. It threw a transmission code so I lost interest pretty quickly. I figured what the heck, might as well try to run the predictive failure test to get some practice at it for future test drives. I clicked around for a while and couldn't find what it was. Does someone mind posting (or directing me to a post, most likely) to those directions?
  11. Ewing
    Ewing New Member
    Vancouver
    ^ That's an interesting write up on the predictive failure test. Googled and the scan tool cable and software is only about $60, however, then I'd have to have a windows based laptop with working optical drive to use it. :/ So not exactly a cheap test tool if I have to buy a new computer. Hmm, I wonder if dealerships run a similar diagnostic?
    Also, here's a thought on a zero dollar test - not as accurate I'm sure, but.. the write up describes how with a bad battery it drains in 1min 45sec before the ICE comes back on and a good new one takes 4 1/2 mins to drain. One could use that duration to determine battery health.. under 2mins, bad, over 4mins, good..
    The test procedures say to "press the trigger button" while pressing the gas/brake simultaneously. What is the "trigger" button? Do you hold it in during the whole test?
  12. Skeletor916
    Sacramento, CA
    I had that same question for a while. While I obviously haven't ran the test yet.... I believe that it is referring to a "trigger" button that initiates the test within the Techstream software. So you're clicking the button to tell it to start recording.
    So I believe that it's more like
    1) Hit the trigger button in Techstream (which tells it to start recording)
    2) Hit the gas/brake simultaneously.
    As written, it sounds like DO ALL THREE AT ONCE, at least to me.
    For what it's worth, I bought a ~$12 OBD from amazon and installed 32-bit Windows 7 (and loaded up a 32-bit Windows XP virtual machine on it, just in case) onto an old Dell laptop I had laying around to make it work. So far I've been able to scan codes from two different cars before (not) buying.
  13. Skeletor916
    Sacramento, CA
    Alright, well I'll answer my own question here... I got a chance to "test drive" another car. The lady was kind enough to humor me while I ran many tests on her car and fumbled through the Techstream software. .
    The steps I took in really prescriptive order for future use:
    1) Drove it around a bit to get the engine warmed up.
    2) Parked the car
    3) Turned my Techstream laptop on.
    4) Opened Techstream.
    5) Connected my VCI to my laptop
    6) Connected the VCI to the OBD2 port on the Prius
    7) Turned Prius to IG-ON by hitting the power button until it was amber-colored
    8) Hit the Connect button on the Techstream application to connect the computer with the Prius
    9) Selected the Smart Key option once the vehicle was recognized and hit the next button
    10) The system select screen comes up in Techstream, I had all systems selected and clicked the "health check" button
    11) Waited patiently while it checked everything
    12) Health check screen popped up. I double clicked the HV battery system under the list of systems
    (I THINK this is what happened next)
    13) Set Prius into READY mode
    14) Fumbled around like a doofus trying to get Prius into reverse
    15) Waited for internal combustion engine to stop running
    16) Pressed record/trigger button in Techstream on laptop
    17) Applied brake and gas simultaneously for about 6-7 minutes, ignoring the repeated beeping.
    18) At the end of five minutes, ICE had yet to turn on, so I saved that information and quickly pressed record again. Once the ICE kicked on, I stopped the second recording.
  14. ericbecky
    ericbecky Hybrid Battery Hero
    4,418
    3,293
    Madison, Wisconsin
    Dealers will not do this test.
    Some specialized independent hybrid mechanics like me will provide this type of service.
    Generally is about 1hr of labor.
  15. Robertto09
    Robertto09 Junior Member
    51
    Costa Rica
    How I check the hv battery with the techstream program? The car would be in ready or in ig-on? Somebody can explain the procedure?
  16. Skeletor916
    Sacramento, CA
    Again, I'm no expert... but my instructions in post #13 are what I believe to be the procedure, if I am not mistaken.
    And I really, really could be ;)
    Robertto09 likes this.
  17. Robertto09
    51
    Costa Rica
    Thanks you, today I can did it
  18. Skeletor916
    Sacramento, CA
    Great! Does that mean you successfully did it with those instructions?
  19. Robertto09
    51
    Costa Rica
    Exactly!!
  20. Skeletor916
    Sacramento, CA
    Nice. Can I see your results? Basically so I can compare my recent results with yours.
