i ran out of gas
Discussion in 'Gen 3 Prius Fuel Economy' started by eliotb, Feb 27, 2016.
  1. eliotb
    eliotb Junior Member
    64
    Northern Virginia
    I do not as a rule wait until the last minute to fill up, but I just managed to run out of gas. I put 12.896 gallons of gas into my 2013 Prius Five after running out. Last I checked these things had an 11.9 gallon capacity, at least in the book. Downside of running out was I had to spend $17 for a two-gallon plastic gas can (no one seems to keep loaner cans anymore) and the 1.75 gallons i poured into the car plus the 11.146 I put in at a whopping $1.099 a gallon with a grocery store discount, added up to more than the car is said to hold. I will definitely pay more attention to the flashing fuel light. The light never turned off to indicate I was on fumes, though I should have known it. Anyway, it appears the car will take about a gallon more than what is advertised.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    When you run out, you then have no fuel in the fuel lines or over the pump. So yes it will take more than advertised.
    When the car says it is hungry, fill it up. The flashing pip was your warning that you are running on anything between 2 gallons and fumes
  3. wjtracy
    wjtracy Senior Member
    11,358
    3,606
    Northern VA (NoVA)
    OK Eliot I did not see you on the side of the road, so you could have kept it a secret.
    Seems to me this is the second report in the last 2 weeks of >12 gal to refill.
  4. fuzzy1
    10,332
    Did the blinking bottom pip of the fuel gauge never actually go into blinking mode?
    Or were you expecting an additional warning light? There isn't another, that blinking pip is the final warning.
    #4 fuzzy1, Feb 27, 2016
    kenoarto likes this.
  5. bisco
    50,815
    it's not the end of the world. no harm, no fowl.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    You also get a beep at the moment the last pip starts blinking. You get a visual and an audio low fuel indicator.
  7. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    This will go on your permanent record you know. ;)
    Jon Senum and m.wynn like this.
  8. bwilson4web
    15,934
  9. Former Member 68813
    3,524
    983
    US
    i never ran out of gas and never managed to pump more than 10 gals in mine, but the low gas level warning is too subtle IMHO. the lone quiet beep can be missed if it happens on start as it could be masked by seat belt or reverse buzzer. The orange low gas lamp in my other toyotas is much better.
  10. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    There have been people claiming that the blinking PIP will turn off alltoghether (or turn amber or do something else) to indicate that the tank is really, really, REALLY empty.
    No one has ever seen that happen and this is confirmation that it does not happen.
    fuzzy1 likes this.
  11. fuzzy1
    10,332
    Bob Wilson (Post #6 above, follow link to his test report) has intentionally run his cars out of fuel many times, for fun and sport, but mostly for engineering curiosity and testing. And he reports no additional warning until the Power Steering light comes on, moments after the fuel tank really is empty.
    When Bob reports no other warning, then I am very highly confident that no such warning exists.
  12. bwilson4web
    15,934
    I eventually found that IF you have the power flow display on, the arrows will go away when the car is finally out of gas. This gives enough warning to use the traction battery to reach a safe place. When the "PS" light comes on, too late.
  13. ETC(SS)
    6,841
    I drive at least 20 miles past the "low fuel" warning every tank, and depending on routing and my preference for fat-filled sweet or salty treats, I sometimes drive as much as 50 miles past the "low fuel" warning.
    At 93,000 miles (roughly 190 fill ups) I don't think I've put more than 10 gallons in my tank more than a dozen times and I've never put 11.
    #whenlowfuelisnt
  14. Mendel Leisk
    40,242
    My dad used to check the gas level on our '58 Beetle with a stick. :whistle:
  15. KennyGS
    1,243
    1,044
    Keystone State
    This has now placed an entirely inappropriate image in my mind... :D
  16. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I've run out of fuel twice now in the PiP, and have never pumped the rated fuel capacity into the tank. The car seems to shut off about 0.4 gallons short of the rated capacity. The last time I ran it out of gas, it was very out of gas. After coasting to a stop, I would start the car again and build up speed until it cut out again, coasting as far as I could. Then I would repeat about 4 times until it didn't want to go anymore. I came up 3/4 of a mile short of the gas station and had to buy one of those overpriced fuel cans.
    Seems strange that the standard Prius can take a gallon more than the rated capacity, while the PiP comes up 0.4 gallons short.
  17. Anthony H.
    Anthony H. New Member
    Tucson
    Are your results different because yours is a plug in?
