Blue led dash conversion
Discussion in 'Gen 3 Prius Accessories and Modifications' started by lpe350, Dec 4, 2011.
  1. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Thank You for the seller. I was able to cross reference the same size, but in Red, Yellow Off Red, and Orange. I will be able to see which color I want when the samples I ordered arrive. It's a nice site for LED's
    Was 90 the minimum they would sell, or did you buy alot of spares? :D
  2. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    I work with surface mount componants everyday in a shop set up to do them. I extreamly impressed that you can change these outside of a shop. destroying a board taking off a surface mount componant is very easy.
  3. Philatc
    Philatc Pushing Tin
    137
    46
    Calfornia
    Well 90 is all they had in stock. I figure people near me may want to do this to their cars so I grabed up a bunch. About the board....lets just say I'm extremely careful as to not burn or damage the board in anyway. :D :D Love my baby girl am I want to improve her not break her hehe. I will also say I was afraid of ESD so I picked up what I felt was all the equipment I would need. Tweezers, ESD strap, fine conical tip, thin electrical soldier, magnifier, soldier reel and a board vise if you will. Glad I had all these tools as it helped with the removal and install. I am unsure how many more leds are left for the rest of the car. I can say that there are 58 leds for the nav unit, three for the EV/PWR/ECO, two for the park, 1 3mm led for the power button, 19 PLCC's,7 leds on HVAC pnl. As far as the steering wheel, door pnls IDK....Ill be finding out once my leds come in.
  4. lpe350
    lpe350 Member
    56
    32
    Long Island
    My wife's car had an aftermarket Nav and 50 leds did the job with about 3 to spare. Her car didn't have the bluetooth control so if yours has it, it will be exactly what you need. (if you don't melt any during installation). I got mine from Surface Mount PLCC-2 SMT LEDs. They are a bit pricey, but they don't burn out like the "ebay" ones that I've tried. Regarding the "angle" that someone referred to, the PLCC2 leds are wide angle so you'll have to be way off for the light to not shine to the right place. Good luck with your conversion. :)
    There are 5 in the driver's door window control, and 1 ea for any of the other doors. I used one for the overhead light shining down to the shifter and four each side for the steering wheel controls. There are three for the bluetooth control. One more if you have fog lights and one for the "PWR" button.:D
    I did it the "old school" way... on my kitchen table with a "fine" tip (home made by cutting the tip on a sharp angle) and tweezers borrowed from my wife. No ESD ground strap or special equipment. Just being really careful not to overheat anything.
  5. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    Awesome! Thank you for the info.
  6. Philatc
    Philatc Pushing Tin
    137
    46
    Calfornia
    Took me some time but enjoy the video ask questions, make comments. The Blue Ghost is coming along nicely. :rockon::cool: Prius Mods - YouTube
    2 people like this.
  7. lpe350
    lpe350 Member
    56
    32
    Long Island
    nice, now all you need is your new pwr button.
  8. Philatc
    Philatc Pushing Tin
    137
    46
    Calfornia
    Its enroute eta idk hehe Ill post later
  9. Toasticuss
    Toasticuss Junior Member
    30
    Are there disassembly instructions somewhere for accessing all of these LEDs? I am extremely interested in doing this as well on a 2013 prius.
  10. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    In my past life I was a helicopter crewman in the Navy. In aircraft and ships we use red lighting at night because it doesn't degrade your night vision and allows you to see outside without being blinded by the glare of your instruments.
    So, that's why I decided to roll with red.
    I also replaced the shifter mood light with one of these:
    I am pretty comfortable working with a soldering iron. But I've never ventured into the area of working with surface mount components.
    Wow! This was more difficult than I imagined. This work requires a very steady hand and excellent vision at the very small scale.
    First I started with something easy -- the shifter overhead "mood light".
    This was a pretty straight forward operation. The disassembly, LED replacement, and reassembly were not particularly challenging.
    Next I moved on to the smallest of the surface mount jobs -- the hazard & mode button assembly.
    Here's a look at the circuit board after I removed the OEM LEDs, and made a few other mods.
    Notice that Toyota is using LEDs that have a Cathode lead on three corners (indicated by the "K" pad on the circuit boad). That's a problem for me because the Oznium LEDs simply have a Cathode side and an Anode side. That's why I was forced to bust out the Dremel and etch out the third K pad. That was a problem for EV LED (top left) because that third K pad was also inline with the path to the source voltage. So.. a jumper was necessary.
    Here you can see the finished product. After going through all of this, I buttoned it up and put it in the car. It was completely dark! After rechecking all of my connections with a ohmmeter I thought I'd try reversing the polarity on one of the LEDs. It worked! So ... it turns out that my Oznium LEDs are notched on the Anode, not on the Cathode as I thought was the standard. Yep, just looked it up. It's official.
    (From the Oznium website.)
    That little board with four LEDs took nearly three hours before I could declare success.
    That's why I was nearly ready to quit when I opened up the AC controller module.
    This baby has got 26 LEDs on it. Gawd!
    But I had enough practice by now (and I'd figured out the notch was the Anode) this ended up going very smoothly. After etching out all of the third K terminals, I only needed to add two jumpers. Whew!
    I also got the mirror controller and the fog light switch.
    I could use a tip on getting the Start Button open.
    I got this far, blue cover and chrome ring removed, and I couldn't figure out what was next. The more I pried at the circuit board it just felt wrong.
    bonchang, Gaspeed, sonnyd510 and 7 others like this.
  11. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    sfv41901, Dylan Doxey and Burna J like this.
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Dam @Dylan Doxey ......steeping up the modding game
    Looks freaking awesome, reminded me of my M3
    iPhone ?
  13. andino
    andino Senior Member
    746
    551
    San Jose, CA
    Man this takes me back to my scion days doing this to people's HVAC and clusters. Did you need to replace any resistors to get the brightness to work out? I know if I did anything other than red, I'd have to replace a couple of resistors to get the system back into spec on scions.
  14. Dylan Doxey
    1,389
    3,459
    92
    I did not replace any resistors and I used the same LEDs in all of the replacements. For the case of LEDs which are controlled by the dash brightness control is works out just fine. But for the LEDs which are full intensity all the time (such as the AC on/off indicators) they're just a little too bright at night. But not so much that it bothers me.
    bonchang likes this.
  15. torparts
    torparts Senior Member
    417
    643
    Compton
    mod party at dylan's ...da more da merrier! LOL
    bonchang, sfv41901 and Dylan Doxey like this.
  16. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    Great job! Been wanting to attack this but it's above my modding skills...
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Hey @Dylan Doxey, I have a spare speedo cluster.....wanna take a look at it to see if the can be done on it?
    iPhone ?
    bonchang and Dylan Doxey like this.
  18. Dylan Doxey
    1,389
    3,459
    92
    Awesome. I'm looking forward to checking it out.
  19. Dylan Doxey
    1,389
    3,459
    92
    I was doing some surfing on Oznium today.
    I found these:
    3528 Surface Mount PLCC-4 SMT LEDs | Oznium
    These LEDs have four leads which better match many of the OEM LEDs in the AC module and the Hazard/Modes module. The difference is that with these you don't have to alter the circuit board. (If you're thinking of getting some, choose the "common cathode" option.)
    Then I found these.
    1206 Surface Mount LEDs | Oznium
    I think these will better match the LEDs in my after-market stereo which is still on my TODO list.
    Gaspeed, Burna J and sfv41901 like this.
  20. Dylan Doxey
    1,389
    3,459
    92
    I finished my aftermarket head unit LEDs.
    I installed the smaller 1206 Ozniums.
    I rigged up a 12v power supply so that I could bench test along the way.
    #60 Dylan Doxey, Mar 14, 2016
