Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. Tideland Prius
    16,431
    In no particular order, here are links to Nutz About Bolts' YouTube videos on various Prius maintenance items.
    1. Day/Night Mode Adjustment for Navigation
    2. Cabin air filter replacement
    3. Engine air filter replacement
    4. Changing the headlight bulbs
    5. Changing the key fob battery
    6. Tire rotation
    7. Resetting the Tire Pressure Monitoring System (TPMS) light
    8. Oil change & maintenance light reset
    9. Oil change (HD version)
    10. Transmission drain and refill
    11. Engine coolant drain and refill
    12. Inverter coolant drain and refill
    13. Spark plugs replacement (HD)
    14. Throttle body cleaning
    15. PCV valve replacement
    16. EGR pipe cleaning
    17. EGR Cooler Removal/Cleaning (See thread for more details)
    18. Brake flush
    19. Front caliper sliding pins - lubing
    20. Rear brakes sliding pins cleaning
    21. Cleaning the HV battery fan
      • 21a. Cleaning the HV battery fan (Prius Plug-In version)
    22. Cleaning and air freshening the AC evaporator
    23. Removing the positive terminal plastic cover inside the fuse box
    24. Cleaning intake manifold
    25. Oil Catch Can Installation
    26. Upper Glovebox Compartment Removal
    27. 12V Battery Replacement
    28. Inverter Water Pump Replacement
    29. Water Pump and Thermostat Replacement
    1.
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    11.
    12.
    13.
    14.
    15.
    16.
    17.
    18.
    19.
    20.
    21.
    21a.
    22.
    23.
    24.
    25.
    26.
    27.
    28.
    29.
    #1 Tideland Prius, Feb 17, 2016
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,506
    1,605
    Bay Area
    Thank you for the Sticky! I appreciate that :D
  3. Tideland Prius
    16,431
    No prob! Feel free to add to this page. I hope the embed will generate views.
  4. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    what is the update on the corolla engine overhaul?
  5. NutzAboutBolts
    1,506
    1,605
    Bay Area
    It's running and smog. We haven't had the time to film yet since we're both busy with our regular schedules and we're only available on Monday to film but sometimes our schedule conflicts so we sometimes skip a week because of it. Thanks for asking though! :D
    Robert Holt and tankyuong like this.
  6. Tideland Prius
    16,431
  7. NutzAboutBolts
    1,506
    1,605
    Bay Area
    Here's one more, its old though.
    maybe I should redo it with better video quality lol
    AltraStache likes this.
  8. myPriusAcct
    myPriusAcct Junior Member
    29
    17
    How about a video for the fuel filter replacement? I have the parts but still not game to try it.
  9. Kcdaniels
    Kcdaniels Junior Member
    Thanks for the video's..very helpful to a new prius owner:)
    Ramirezja likes this.
  10. NutzAboutBolts
    1,506
    1,605
    Bay Area
    We don't have a reason to do it, but it doesn't look too hard. You pop the rear seat and the fuel pump and fuel filter cover is right there on the driver side. Remove it and you'll have access to the fuel pump and fuel filter together.
    no problem :) I'm glad we could help.
    Victrola likes this.
  11. NutzAboutBolts
    1,506
    1,605
    Bay Area
    Edited by Tideland Prius:
    I copied the video to the first post!
    #11 NutzAboutBolts, Feb 29, 2016
  12. Mendel Leisk
    40,481
    Anuder, hybrid battery fan cleaning. Hard to keep up with these guys:
    (Link deleted, up the page now. Maybe always?)
    #12 Mendel Leisk, Feb 29, 2016
    eunique, Rebound and NutzAboutBolts like this.
  13. Tideland Prius
    16,431
    That's been posted! Thanks!
    NutzAboutBolts and Mendel Leisk like this.
  14. la9ers
    la9ers Junior Member
    37
    Keep them videos coming....... Awesome service you do. Will be doing a 100k service myself and need all the hope i can get.
    Thanks!
    NutzAboutBolts likes this.
  15. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    How about a vid of a rear caliper removal.....I've got the bracket swapped out, but I'm having trouble removing emergency brake cable from the caliper housing. Thanks!
    iPhone ?
  16. NutzAboutBolts
    1,506
    1,605
    Bay Area
    I think I'll need techstream at that point... the brake light might light up due to drop in pressure by removing the caliper. I haven't checked yet....
  17. Jimi1976
    242
    124
    Denver, CO
    Wouldn't putting the car in "invalid mode" cover that?
    iPhone ?
  18. NutzAboutBolts
    1,506
    1,605
    Bay Area
    That's the theory but I haven't tried it, I would love to try it, but the Prius is my work horse car as of right now, I wish I have a spare car to work on.
  19. Mendel Leisk
    40,481
    I've had the rear caliper off. There's no need to disconnect the parking brake cable, unless you're actually replacing the caliper.
    I would disconnect the 12 volt cable first. Remove the two bolts going thru the caliper lugs into the pins, then pull the caliper off the pads and back a bit, and tie it out of the way with twine.
    After reassembly, depress the brake pedal a few times before reconnecting the 12 volt. You should be fine.
    One thing: be sure the inner pad pin is between the caliper's spoke pattern, and stays there. You can check by verifying the rear wheels are turning relatively easily.
    AltraStache and Robert Holt like this.
  20. Jimi1976
    242
    124
    Denver, CO
    I need to replace the caliper.
    I believe It is seized.
    iPhone ?
