Battery Vent Odor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by campbellmike, Jul 26, 2014.
  1. ive
    ive Member
    104
    43
  2. rogerthat
    rogerthat Active Member
    381
    122
    Georgia
    I took the car in to my Toyota dealer and, of course, they said no unusual smell was evident. Everyone else who I have asked to sniff the car and battery vent identifies the smell. I called the Toyota 1800# to set up a case number as suggested by the dealer. The Toyota rep said that there were no recalls or any other bulletins concerning the smell. He then contacted the dealership that inspected the car and after a few minutes got back to me and said that they would not be able to replace the tubes under the hybrid warranty. This is unfortunate as the problem is clearly due to the use of defective materials.
    I suggest that anyone experiencing this smell call the Toyota 1800 and get a case number issued. Perhaps if enough people do this, Toyota will finally acknowledge the issue and work to resolve it in a fair manner.
  3. frankv64
    frankv64 Junior Member
    Colonia NJ
    I just purchased an 09 Touring and I definitely have the smell. My wife says it smells like horse shit. The rear cargo mat had the smell on it. I removed it but the smell is still there, not as much though as when I first got the car. I have a friend with a 07 Prius that I smelled that same smell but he doesn't think it smells so it's probably some people are more sensitive to it than others.
  4. ive
    ive Member
    104
    43
    Just replace the vent pipes with silicone tubing and the smell disappears
    iPad ?
  5. rogerthat
    381
    122
    Georgia
    Update: I replaced the vent tubes with silicone tubes back in October. The vent tubes that I removed had an incredibly strong pungent odor - obviously the cause of the sickening smell. The good news is that the smell has almost completely disappeared since I replaced the tubes. However, I'm still ticked off that Toyota refuses to acknowledge the problem - my local dealership (Marietta area) made as if I was nuts to suggest that the tubes caused any odor.
  6. ive
    ive Member
    104
    43
    Putting the stinky pipes on the dealership's desk wearing rubber gloves will change their opinion about the cause of the odor with zero persuasion or other means of convincing required.
    iPad ?
    m.wynn and bisco like this.
  7. rogerthat
    381
    122
    Georgia
    Yeah, considered that... but decided against it, just in case they claim I voided the warranty.
  8. Mendel Leisk
    40,466
    Geez, they've really got you there, haven't they.
  9. dolj
    dolj Senior Member
    8,184
    4,167
    Wellington, New Zealand
    They probably have got you anyway when comes to a warranty claim, as the battery will be inspected for tampering before the claim is accepted. Whether it makes a material difference to the acceptance of a claim remains to be seen.
  10. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Boy that's for sure. When I pulled the tubes from our '07 in the fall of 2014, they spent a few weeks living on the auto parts shelf of my garage. The car had 140k miles at the time and I was keeping them in the event the HV battery signed off before 150. The smell in the entire garage became such that they got relocated to a wood pile outside said garage, where you can still get a whiff if you happen to pass by. The '07 has 160k miles now but the tubes just sit there. I have this feeling that they need some sort of haz-mat disposal process to get rid of them in good conscience. So there they sit...
  11. Dovydas
    Dovydas New Member
    DROGHEDA
    Well done man, but tell me please is that 10x14 or 14x10 because quite confusing now for me.
    Thanks
  12. ive
    ive Member
    104
    43
    14mm outer diameter and 10mm inner diameter. 2mm wall thickness.
    Pyho and Mendel Leisk like this.
  13. bisco
    51,023
    nice comeback.;)
  14. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    Gee, and I was having such fun trying to picture the 10 mm OD / 14 ID (n)
    padroo and m.wynn like this.
  15. breezyb
    breezyb New Member
    Orlando
    Four Touring
    I realize this is an old thread... but I just used it to replace my vent tubes and followed all directions perfectly (this is about my 7th DYI repair on my prius, it's got 250,000 miles on it) and now I'm getting the red triangle of doom and the car won't shift to drive. Help!
  16. bisco
    51,023
    did you put the orange safety plug back correctly?
    do you have tech stream?
    m.wynn likes this.
  17. Wello
    Wello New Member
    Europe
    I've been been lurking for long time, just signed up to give props to ive. I did this couple of days ago and the stink is beginning to fade.
    I'm not at all skilled at mechanic work, but with these instructions I was able to do it at our parking lot. I also read the 40+ page thread at priusfreunde, with bad high school German and google translate :)
    It took me about 5 hours and I only used hand tools, including the time it took cutting the silicon tube to size and drilling holes with dremel.
    As always I had some leftover bolts after reassebly, but so far it's been been holding up. First start was intense, but it went well without hickups, no warning lights or such.
    So yeah, It's doable for anyone, no special tools or skills required. Our local dealer quoted 450 euros / $500 for the job. All that's needed is patience and some common sense. And I guess couple of beers don't hurt either...
    bisco and Mendel Leisk like this.
  18. Mendel Leisk
    40,466
    A couple of beers and I'd have a LOT of leftover bolts.
    Raytheeagle and bisco like this.
  19. rogerthat
    381
    122
    Georgia
    This brings back memories - I changed out my vent tubes a few years ago. Two dealerships refused to acknowledge the issue - telling me there was no odd smell.
  20. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    Man you rock!
    I just did it like you did. My car has already a really better smell! No more stable smell.
    A 14x10mm silicon tube bought at the DIY store for 10$, a drill and a marker. Work completed in 30 minutes (not counting the disassembly time until the hybrid battery of course).
    Thank you for the pictures.
    ILuvMyPriusToo likes this.
