Grill Shutter Operation
Discussion in 'Gen 4 Prius Main Forum' started by RRxing, Mar 15, 2016.
  1. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Does anyone know the details of when/how the grill shutters work?
    Does it just monitor the outside temperature or delta T between the outside temp and engine temp? Or...???
    What is the temperature(s) at which it operates?
    Thanks in advance...
  2. Mendel Leisk
    40,493
    No clue but, but I'd be fairly sure they're closed at every cold start, open at some coolant temperature, and suspect ambient temperature is not a factor. Someone with a camera duct taped to the front bumper and a scangauge monitoring coolant temp could figure it out. Or maybe do it in a driveway, if they set the car in a maintenance mode.
    What the heck is "delta T" by the way? Does that mean "difference"?
  3. bwilson4web
    15,989
    You might be able to measure it with miniVCI.
  4. Trollbait
    12,320
    Correct on the delta and difference.
    Coolant temp and car speed is all it really needs to know. Perhaps whether the radiator fans are running.
  5. RRxing
    2,530
    1,806
    NEPA
    Yes. Differential temperature.
  6. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Not sure in the Gen4 but on my old Chevy Cruze Eco I believe it shuttered at a certain speed to aide in highway mpg? Could the Gen 4 Shutters be similar or more advanced taking into account engine temps, etc...?
  7. Trollbait
    12,320
    That's how they are described as working, but it is a simplfied explanation. Even the shutters on the Cruze Eco took temperatures into account.
    "The air shutter system uses sensors to feel and sense wind and temperature conditions. The sensors are married to electric motors that open and close the shutters automatically. With the shutters closed at high speeds, wind drag is reduced. At lower speeds, the shutters open to maximize engine-cooling air flow. The air shutter system contributes nearly half a mile per gallon in combined city and highway driving." - Active Shutters Helping 2011 Chevrolet Cruze Eco Reach 40 MPG
    pakitt and Blizzard_Persona like this.
  8. bwilson4web
    15,989
    From New Car Features:
    pjm877, RRxing, Mendel Leisk and 2 others like this.
  9. bisco
    51,037
    i'd love to see pics. is this going to improve cold weather performance beyond epa testing?
  10. bwilson4web
    15,989
    The cross-section is in the shadow to the upper left of the structural strut. The hood seal is dangling in front. The barrier was not sharp enough and lighting could have been better . . . should have used a flash:
    In about six months, there should be some pictures on Ebay.
    #10 bwilson4web, Mar 15, 2016
  11. RRxing
    2,530
    1,806
    NEPA
    Thanks, Bob...
  12. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I wanted to shoot a video of the grills closing and opening. So after the car sat outside in freezing conditions, I brought it into the garage, powered it on, and looked at the grills. They remained open. There was nothing I could do to make them close.
    Keep in mind that I was alone and not about to put the car into drive, which made me think that perhaps there is some reliance on the car actually moving.
    Since I didn't have a camera I was comfortable strapping to the front of the car (also, I mentioned the freezing conditions, right?) I didn't have the chance to shoot video at the shutters while the car was moving.
    bisco and Mendel Leisk like this.
  13. Mendel Leisk
    40,493
    One of those inspection cameras would be good, where the lens is at the tip of a cable.
  14. Trollbait
    12,320
    No one got a GoPro?
    I can see not being activated until the car is put into drive, and the warm up sequence starts. Sitting parked, there is no benefit to the shutters being closed; no air flow to block, and the fans may be coming on if the A/C is turned on before the car is driven off.
  15. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Don't stick your finger in there.
  16. bwilson4web
    15,989
    In fact there is a risk of 'cooking' all the parts in the engine compartment. In an ideal world, there would be an 'ambient' temperature sensor that would let the shutters stay open until some target temperature, say 105F (40C) was reached and then close up to retain heat. Heat is the enemy of electronics, even automotive grade.
  17. Trollbait
    12,320
    Cars with an ICE do have an ambient temp sensor in the air intake for calculating the incoming air mass.
    More likely, cars with active grills wait until they are moving before shutting the grill. Even fully shut, there is some air flowing into the radiator. Stopped, you don't want the fans sucking against the shutters if they need to be on.
  18. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    It appears that these active grilles have a 'winter control mode' which deactivates them in a fixed partially open position below 5C (41F) and reactivates them at above 10C (50F), allegedly to prevent freezing malfunction.
    A shame because those are the temperatures below which we would like these grilles to be blocked!
    RCO likes this.
  19. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Is that info generally available somewhere @GreenJuice ?
  20. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    272
    Harrisburg, PA
