Socket Size for Wheel Lug Nuts?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ATHiker, Mar 19, 2016.
  1. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    Anyone know the socket size for the wheel lug nuts?
    My set goes up to 19mm and that is not big enough.
  2. voerman
    voerman Junior Member
    NC
    Four Touring
    You missed it by 2mm. Size is 21mm.
    Lou
    Pulse07 and ATHiker like this.
  3. CR94
    CR94 Senior Member
    2,662
    1,150
    Northwestern S.C.
    A 13/16" (which equals about 20.64mm) socket will also work in most brands, but fits more snugly. I carry in the car a socket set which includes a spark plug wrench of that size, eliminating any need to haul the original lug wrench around everywhere.
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    I carry both a 21mm and a 13/16" and a 25" ½"-breaker-bar (just in case) - well, $20 from Harbor-Freight was too good to miss!
    joelg1988 likes this.
  5. Mendel Leisk
    40,495
    I went with 13/16"; one thing I noticed: it was ok on the lug nuts but just a leetle too snug on the locking nut adapter. I ended up filing it's faces slightly.
  6. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    Sometimes the lugs get raised edges and the 13/16" gets too snug.
  7. CR94
    CR94 Senior Member
    2,662
    1,150
    Northwestern S.C.
    Right. Typically that kind of damage occurs when the lug nuts are assaulted by a cretin at the controls of an impact wrench. Dealership mechanics did that to my Mazda when it was new. They replaced the damaged nuts, eventually.
  8. WilDavis
    2,493
    2,154
    49
    Sounds like "peening" caused by using a socket which is too loose!
  9. mygel
    mygel Junior Member
    46
    24
    Slovakia
    Just want to change tires for winter season, ended up with ordering new wheelnuts because wheelnut for alloy
    comes w flat spacer. and did not fit to steel...size should be 12x1,5mm 21 mm socket i think. Car ready for the change winter wheels balanced and nothingshow must go on.
  10. WilDavis
    2,493
    2,154
    49
    Here's what I bought for my winter steelies!
  11. mygel
    mygel Junior Member
    46
    24
    Slovakia
    I bought the simple black nuts but they sent me golden, now im gonna be like snoop dog w smoking exhaust like old diesel:) i have bought 16” steels they ´ re for toyota urban cruiser the one with 54.1mm inner hub diameter 5x100 for only 90€ 4 all of ´ em. But tires 4 almost 300. I like to be sure on the road;)
  12. WilDavis
    2,493
    2,154
    49
    I don't worry about hub centre-caps for the winter steelies, I spray the hub-centres with Blaster goop
    it prevents corrosion, and stops the wheel discs sticking to the hubs
  13. xliderider
    xliderider Senior Member
    8,038
    3,212
    Honolulu, HI
    The oem lugnuts often have a tapered end that seats into the steel spare tire wheel.
    mygel likes this.
  14. Mendel Leisk
    40,495
    The OEM lug nuts will fit the spare, or any compatible Toyota steel rim, the Corolla steel rims for example. The only issue is they look odd: the dangling washers and all. I've been half-heartedly looking for some closed-end nuts, preferably in chrome, but all the generics are around 35~39 mm height, I guess to be one-size-fits-all? They jut out too much for my taste. A closed end nut roughly 25 mm height, or even less, would work.
    The nuts I currently use are open-ended galvanized, Toyota part number: 90942-01007, but I'm not too thrilled with them. They have no shoulder near the base, so it's very easy when putting them on with a socket, to scuff the rim. Also, being open-ended, and with Toyota's lackluster rust coatings, the tips of the studs are visible, and rust up pretty quick. I've taken to putting a little spritz of oil on each, at time of install, and that seems to sort it out.
    Regarding center caps and Corolla rims (I'm a broken record on this): 2" ABS end caps work pretty good, if you first push on something like a ring of rubber cut off a bicycle inner tube. I left the center openings unprotected for the first two~three years, and it was NOT a pretty sight, again: Toyota does not win any contests for rust protection.
    #14 Mendel Leisk, Oct 19, 2017
    mygel likes this.
  15. WilDavis
    2,493
    2,154
    49
    Doncha just hate it when they do that? ;)
  16. Mendel Leisk
    40,495
    Maybe they'll jingle? :whistle:
  17. WilDavis
    2,493
    2,154
    49
    No, sir! …that jingle-jangle noise would be me spurs (they always do that¹ as I'm riding merrily along!) :D
    ¹ which might explain why I'm still single! :rolleyes:
    mygel and Mendel Leisk like this.
  18. mygel
    mygel Junior Member
    46
    24
    Slovakia
    What about hub covers? When i took off alloy disc, the centre is completely naked afraid of bearing getting dirt:(
  19. mygel
    mygel Junior Member
    46
    24
    Slovakia
    That make sense
  20. mygel
    mygel Junior Member
    46
    24
    Slovakia
    Single with Prius? No way! Just that ship is your buddy...
    WilDavis likes this.
