For Sale GONE: lsqSTAR 8 Inch Head Unit $100
Discussion in 'Private Sales' started by Dylan Doxey, Mar 20, 2016.
  1. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Pros:
    • MP3 player
      • supports non-english text in ID3 tags
      • random mode is very random
      • displays album art
    • Has GPS navigation
    • Support OEM USB port
    • Support for OEM steering wheel controls
    • Support for OEM backup camera
    • 8" display
    Cons:
    • FM radio reception is poor
    • Can't play MP3s while using Navigation
    • Navigation nags you about the speed limit (when it's active)
    • NoWifi
    What you'll need:
    • Toyota antenna adapter (for model year 2012 to 2015)
    • Toyota USB adapter
    • custom hack for steering wheel controls & reverse signal hookup.
    Overall I like this unit more than the OEM head unit that it replaced.
    I'm selling this guy because I upgraded to an Android unit.
    I originally purchased it on eBay in July 2014. It took me a while to figure out how to get it all hooked up right.
    I used from September of 2014 to March 2016.
    This is a bargain at $100.
    You pay shipping. Or, local pickup, or mod-party meetup?
    #1 Dylan Doxey, Mar 20, 2016
    Mrkevin905 likes this.
  2. JamesKFChiu
    JamesKFChiu Member
    95
    52
    ORANGE
    This is not a good deal, it's a killer deal :O
    Wonder if you can update the Navi Map and how good/accurate is the Navi.
    GLWS
    Dylan Doxey likes this.
  3. tallman
    tallman Junior Member
    60
    wv
  4. Dylan Doxey
    1,389
    3,459
    92
    There's a little SSD card behind the "GPS Card USB" hatch on the lower left. I've never messed around with it. I'm not sure how to updated it or what the capabilities are.
  5. tallman
    60
    wv
    shipping to 25085 paypal ok?
  6. Dylan Doxey
    1,389
    3,459
    92
    I put the box on the bathroom scale. The weight is just under 8lbs.
    According to USPS shipping calculator ...
    PayPal is OK.
  7. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Does it use all the factory plugs?
  8. Dylan Doxey
    1,389
    3,459
    92
    You need an adapter for the factory USB. You also need an adapter to connect the square antenna plug into the round hole. And you need to get creative with the steering wheel controls & the backup sensor. But it's not too tough.
  9. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Does it have built in Wi-Fi access? Is it still for sale?
  10. Dylan Doxey
    1,389
    3,459
    92
    No Wi-Fi.
    Yes, still for sale.
  11. Montgomery
    2,254
    2,242
    Orange County, CA
    I will pass.
  12. roypaik
    roypaik Member
    161
    39
    Orange County
    2020 Prius Prime
    Can you be specific of what extra is needed for this to be plug and play with steering wheel controls, stock back up camera, stock sub, and radio plug.
    Also, if I do not use the navi, will it still nag me about the speed?
  13. Dylan Doxey
    1,389
    3,459
    92
    The Navigation app only nags about the speed limit when it's active.
    If you're model year is 2012 to 2015, you need a Toyota antenna adapter that looks like this.
    (Search B00ACD9RFO on Amazon for an example.)
    You will need a Toyota USB adapter for the USB port in the center console that looks like this:
    (Search B00QF01H2E on Amazon for example.)
    For the steering wheel controls, my solution looks like this:
    This is wired according to this diagram:
    (Note that SWG=Steering Wheel Ground, SW2=Steering Wheel 2, SW1=Steering Wheel 1)
    The RCA plug from the OEM reverse camera just plugs right in. You will also need to stick the stereo reverse signal wire into slot #2 in the above connector.
    And that's it!
    #13 Dylan Doxey, Mar 25, 2016
    sfv41901 likes this.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    If I'm not mistaken, I believe only the 12-15 Prii needs the antenna adaptor. The 10-11 Prii doesn't need it
    iPhone ?
  15. Dylan Doxey
    1,389
    3,459
    92
    Good to know --thx1
  16. Dylan Doxey
    1,389
    3,459
    92
    It's fire sale time! Someone take this off my hands, or else.
    sfv41901 and orenji like this.
  17. sd1810
    sd1810 Active Member
    105
    361
    Socal
    2015 Prius Plug-in
    Ya or else what? o_O
    I saw this deck and it looks good.
  18. Dylan Doxey
    1,389
    3,459
    92
    It's not as good as an Android unit. But it's way better than the vanilla OEM stereo.
    You know how capitalism works -- It's only worth as much as what the market will bear.
  19. TriniTT
    TriniTT New Member
    Birmingham, AL
    2012 Nissan LEAF
    Any idea what brand it is?
  20. Dylan Doxey
    1,389
    3,459
    92
    This hardware has shipped under a few different brand names. Pumpkin is the first that comes to mind. It looks exactly like same hardware as my newer Android unit.
