How hard is the hatch supposed to slam shut?
Discussion in 'Gen 3 Prius Main Forum' started by RollinBad, Mar 30, 2016.
  1. RollinBad
    RollinBad Member
    46
    72
    Oside, CA
    newbie to my 2010 prius III here. Just got it about a month ago and I've noticed that when I go to close the hatch, it slams pretty hard. I feel like the struts will hold up the hatch to about 2/3 of the way down then it just drops really hard and slams shut while rattling the spoiler so hard I feel like it's going to fall off. Is this normal, or should I look into maybe replacing the struts? I dont' know anyone else in real life who has a prius so there's no way for me to compare this anomaly. Any insight would be appreciated! Thanks in advance!
  2. Mendel Leisk
    41,355
    That doesn't sound right. Our shocks lost the ability to quickly run the hatch up full height, typically take a bit of "help", but coming down is pretty controlled, the hatch doesn't slam, just fast enough to latch.
    RollinBad likes this.
  3. bisco
    51,854
    you can get aftermarket replacements on line for a reasonable price.
  4. RollinBad
    RollinBad Member
    46
    72
    Oside, CA
    Good to know...thanks! I think I'll try replacing the struts first and see where that gets me. Hopefully will fix the problem; I can't imagine anything else that would be causing this.
    Yea, I'm definitely going to look into it. Seems like a pretty painless fix.
    #4 RollinBad, Mar 30, 2016
  5. bisco
    51,854
    there are a few threads here that you can search.
  6. BZzap!
    BZzap! Senior Member
    1,607
    878
    FYI, you should have to pull the hatch down until gravity overcomes the strut at about the half way position. Even at that you have to assist the hatch with enough momentum to make it latch. In short, your hatch struts are worn out.
  7. JC91006
    JC91006 Senior Member
    16,765
    8,563
    Buy new struts, that'll fix your problem.
  8. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    I have found the following to be of help:
    StrongArms for 3rd gen Prius
    Part # 4686 struts have 140LB of lifting force each.
    Part # 6244 struts have 93LB of lifting force each.
    They both compress to 11.65" but the 4686 extend a bit more 19.65"(4686) vs 19.40"(6244).
    Glee217 and RollinBad like this.
  9. RollinBad
    RollinBad Member
    46
    72
    Oside, CA
    Do you know how this compares to Stabilus? I think those are the ones on my car already (OEM?).
  10. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I had a wagon with failing struts a few years back, and I had re-gassed struts installed quite cheaply - they were still fine 3 or 4 yrs later when I sold the car.
  11. RollinBad
    RollinBad Member
    46
    72
    Oside, CA
    Update on hatch strut issue:
    I replaced the two rear ones and now it works great! No slamming. I have to actually push down a little to get it to close. (y)(y)(y)
    I purchased Stabilus Lift-O-Mat part # SG329044 from Oreilly ~$50
    Thanks everyone!
    Glee217 likes this.
