Accidentally Delete Trips A and B - 2016 Prius THREE
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JimmyPri, Apr 2, 2016.
Tags:
  1. JimmyPri
    JimmyPri Active Member
    201
    245
    Hilo, Hawaii
    I am just learning the displays. I accidentally deleted both A and B with one touch and I only wanted B. Any thoughts On what I could have done wrong? Thanks.
    #1 JimmyPri, Apr 2, 2016
  2. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Holding the button down for several seconds zeroes the tripmeter being displayed. Is it possible you held the button down when you were on "A", gave it a momentary click which switched to "B", and then held it down again while on "B"? That's all I can think of.
  3. bisco
    51,844
    i've done that.
    unless they've changed it, you can only display the data showing on the screen.
  4. Mendel Leisk
    41,333
    If you're tracking mpg it's a good idea to use the odometer readings, and maybe the trip meters also, but just for insurance. While the trip meters can be accidently reset, or neglected to be reset if someone else does the fillup, the odometer reading is impervious.
    xliderider likes this.
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep! Done that! Happens pretty easy!
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Not sure about the 2016 but my 2010 kept track of last 5 trips I think. It keeps the miles and approximate mpg. No avg mph though.
  7. JimmyPri
    201
    245
    Hilo, Hawaii
    Thanks JohnF. That is what I must have done. I was more careful today so no problems.
  8. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    Right. I had trouble with accidental resets at first, before I learned to be quick on the button to avoid them. It doesn't take long!
