New TSB for EGR and gaskets (TSB 00-27-16)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by reedog117, Apr 14, 2016.
  1. reedog117
    reedog117 Junior Member
    Arlington, VA
    I brought my 2010 Prius in to the dealer to have them perform the TSBs for the new engine mount and manifold during my 70k service. Car is covered by the CPO warranty.
    I later received this in my email:
    Anybody know anything about this? Had trouble finding anything while googling around.
    iPhone ?
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I am only aware of one "EGR related" TSB, but I have not checked TIS since January. It is possible that a new TSB has been released since then.
  3. Former Member 68813
    3,524
    983
    US
    lucky you, my dealer fights any TSB by the usual "not duplicated."
    correct me if i'm wrong, but that is a manifold TSB. EGR is TSB-75-13.
  4. Mendel Leisk
    41,340
    OP, so far this thread is the only result, doing a google search for the tsb number. Do you have any links, or could that dealer supply you something, a pdf?
    There is a component at the head of the EGR "stream", connecting to the exhaust manifold, that is prone to completely clog, especially with cars over 100,000 miles. Downstream clogging is moderate too.
  5. reedog117
    Arlington, VA
    I'm picking up the car today -- hopefully I'll have more info on my shop receipt.
  6. reedog117
    Arlington, VA
    I need to scan the TSB itself after work, but it looks like T-SB-0027-16, which judging by the 16 means that the TSB just came out this year. Maybe someone can find an original PDF copy?
  7. Mendel Leisk
    41,340
    I'm drawing a blank. Scan, or even steady cell phone pic would be greatly appreciated. Thanks. :)
  8. reedog117
    Arlington, VA
    Here it is -- T-SB-0027-16 -- or at least the first 5 pages of it :)
  9. Mendel Leisk
    41,340
    Thanks for that!
    Do they do replacement of parts in the subsequent pages? When you get a chance could you post?
  10. reedog117
    Arlington, VA
    They only attached the first 5 pages to my receipt so unfortunately I don't have the rest. I'm guessing though that this first part included with my receipt shows all the part numbers that need to be ordered/invoiced, and that the rest is just installation instructions.
  11. Former Member 68813
    3,524
    983
    US
    thanks for posting. this is confusing. they list new part # for ECU and then say not to replace it, but just to reprogram it.
    BTW, it's covered by 3 years or 36,000 miles warranty. how many 2010-2012 prius cars are still covered? call me cynical, but i believe toyota times the release of their TSB in a way that few people would get a free fix. i saw it with my other toyota cars too.
  12. reedog117
    Arlington, VA
    I think I got lucky since I bought my Prius CPO so I have the 7yr/100k coverage.
    Prius_Angie likes this.
  13. frodoz737
    frodoz737 Top Wrench
    4,694
    2,496
    33
    Interesting. Will check with my Dealership, but I wonder if the condition being reported prior to 3/36 will qualify my vehicle. Looks like you California folks get it some slack though, especially the PIPs.
    #13 frodoz737, Apr 20, 2016
  14. Ginto
    Ginto Junior Member
    28
    Damn I threw that EGR code last week looked it up and cleaned the parts myself. But at 172K I was out of the TSB coverage anyway...
  15. Mendel Leisk
    41,340
    36,000 miles or 3 years is a real cop-out from Toyota. The EGR component directly next to the exhaust manifold is clogging very regularly, based on reports here, somewhere between 100,000 and 150,000 miles.
    The owners that have removed it say cleaning it out is hopeless, end up ordering a new one. It has an interior radiator that is nigh impossible to clean. Plus, removable of the component is very labour intensive, pretty much necessitates draining the coolant, just for starters.
  16. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    Does that "EGR component" (specifically the heat exchanger that's used to cool the recirculating exhaust gas) clog even on engines that haven't yet started guzzling oil? I recall reading of cars with both problems, which may not be coincidental.
  17. Mendel Leisk
    41,340
    No real data (but hey), just seems like EGR clogs as miles go up. And then, if the engine's out, good opportunity
  18. The Critic
    3,193
    2,333
    CA
    You're right, this is a new TSB.
    OP - not having any luck with opening the TSB you posted. I guess I could buy another subscription to TIS and get it.
  19. Mendel Leisk
    41,340
    Here's some jpg snapshots from the pdf, in order, page 1 through 5. There's another 5 pages I believe, but not in that pdf:
  20. Morlince
    Morlince Junior Member
    Missouri
    I have done this, you can find my post on here somewhere with pictures. (on mobile otherwise I would post a link) It takes time, but it's pretty easy and you do not have to drain your coolant. I'm at 150k, I think, miles and only had to do it once.
    VK810 4G ?
