Prime destined to be doa?
Discussion in 'Prime Main Forum (2017-2022)' started by Prius Five Guy, Apr 1, 2016.
  1. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I was just thinking about this. The PiP was slightly slower than the standard Prius due to the extra weight, but with a dual clutch and the ability to utilize both MGs at the same time, the Prime should be slightly faster, even with the extra weight.
  2. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    Don't think I'd go there...I am thinking it's easier and good to recycle lead acid batteries to recover lead. Admittedly there is potential for mismanagement. Lithium might have hard time being better than lead from cost/benefits ratio.
    Absolutely Prime will cannibalize Prius sales in CA if Prime gets green HOV stickers in CA. PHEV already 65% sold just in CA for 2015, and hybrids were 30% sold in CA my guess hybrids approaching 40% just in CA this year. Overall CA is 12% of car sales/population.
    #142 wjtracy, Apr 17, 2016
  3. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    The idea that someone would "throw away" a 200kg package of a 8.8kW battery that could easily salvage for a couple of thousand dollars is ludicrous. Even the Prius' standard NiMH battery is easily salvageable for at least a couple of hundred if not more. We have some enterprising people on PriusChat who are not above replacing a couple of bad cells and making a battery new again. The batteries in hybrids and EVs are like engines, they are made of discrete parts that can be replaced and have been replaced and rebuilt many, many times. As for lead acid batteries, although the lead is easily recyclable in wet cells, in the AGM batteries it is not as easy to get "the lead out". It takes the same sophistication as getting the 10kg or so of the rare earth lanthanum out of the NiMH batteries.
    #143 drash, Apr 17, 2016
    mrlebop likes this.
  4. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    Well lithium metal itself is probably not a big cost...
  5. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    That puts you directly in the crosshairs of those arguing that only offering 4 seats will keep Prius buyers away from Prime.
    What would the problem be with some of the gen-4 Prius overall sales growth hope shifting over to Prime anyway?
  6. hill
    8,790
    even many of my thoughts do that
    #146 hill, Apr 17, 2016
  7. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  8. bisco
    51,839
    funny, i never heard of them.
  9. YBLee
    YBLee Junior Member
    Assonet, MA
    I use 2 seat 10% of the time and 5 0% of the time. What % of us really need 5 seats?
  10. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    None that I can think of. It would be a win-win for Toyota anyways. It's an individual choice for the car buyer and not the car as whole. I've never advocated that the 1st gen Volt was somehow inferior because it failed to seat 5. I will admit one thing though. I had predicted earlier that the next gen Plug-in Prius would get no more than 13 to 15 miles of EV range. I based that on growth of lithium capacity and not that Toyota would actually grow the pack. So now my curiosity is peaked. Just how much room does that larger pack really take up?
  11. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    Reportedly 7-ft3 of the Gen4-no-spare boot space. Gen4 (no spare) boot space reported variously as 17.7-ft3 (EU VDA spec) up to 27.4ft-3 (USA EPA spec).
    In hindsight PiP1 was great for cargo space...not going see that again for a while in a Plug-In car.
    #151 wjtracy, Apr 17, 2016
  12. john1701a
    12,817
    5,303
    58
    That complete avoidance of cargo sacrifice was promoted by many of us.
    I'm quite glad the hump (like C-Max) didn't happen. Prime resembles the 5.2 kWh capacity floor height tradeoff the prototype PHV had.
  13. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    I have this sneaking suspicion that we did NOT see the final production model.
    iPad ? HD
    mrlebop and Redpoint5 like this.
  14. hill
    8,790
    you hoping / thinking maybe 5 seats after all?
    mrlebop likes this.
  15. bisco
    51,839
    idk, when the gen 4 came out, and we saw the loss of storage under the hatch floor, the obvious question was raised: where are the going to put the pip 2 battery. i think we've got the bad news, and it's not going to change.
  16. hill
    8,790
  17. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    ...used 2015 PiPA sounds pretty good deal in a couple years
    Redpoint5 likes this.
  18. Tideland Prius
    16,547
    We might have a dual personality. I suspect it'll be a bit quicker and more fun to drive in EV Drive mode. It'll be a bit slower in HV mode. The Gen 1 Volt felt like that to me. It was great in EV mode but in Mountain mode, it felt gutless compared to the EV mode I was in earlier in the test drive. It basically felt like a Prius lol. I haven't tried the Gen 2 yet.
  19. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    One consideration regarding fun to drive and the Prime is the higher center of gravity (battery in the same place as Gen 2/3, taller, and deeper), and greater polar moment of inertia. While the weight distribution is going to be more neutral (meaning that once the vehicle turns in, there may well be less of a tendency to understeer), turn-in will be more sluggish, and it will have more inherent body roll (Toyota can tune this out, but will they?)
    I'm kinda wishing they had reprofiled the fuel tank, which would have allowed them to push some of the battery forward and down, under the middle rear seat position that they didn't end up using (and maybe even creating a central tunnel of sorts to get more of the battery further forward and down in the chassis). As it is, there's a lot of wasted space in the Prime's packaging.
  20. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    I think you all did a good job with PiP1 feedback.
    Thank you. At that time, it was over my pay grade.
    Is the implication though that Prime was less based on potential buyer feedback?
