Synthetic oil maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cgrigsby, Apr 24, 2016.
  1. cgrigsby
    cgrigsby Junior Member
    Viorginia
    Just wondering if anyone knows how to reset the default maintenance reminder. We want the reminder to be set at 10,000 miles and not sure how to do this. We have the 2012 Prius and are using synthetic oil.
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Can't be done. Maintenance reminder is not just for oil. It's for tire rotations and inspections as well every 5.
  3. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    There is a simple way to reset the reminder every 5,000 miles (if you are doing your own maintenance) but there is no known way to alter the length of the count down.
    (You are showing a 2005 prius and asking about a 2012, so I am confused, but here is the procedure for a 2012, page 403)
    http://www.toyota.com/t3Portal/document/om-s/OM47704U/pdf/OM47704U.pdf
  4. CR94
    CR94 Senior Member
    2,676
    1,159
    Northwestern S.C.
    Just reset it (as per owner's manual), reset it a second time when it goes on 5000 miles later, and it will go on again 10,000 miles after the first reset. That might be more bother than what you're asking for, but not much.
  5. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Just think of the non-oil change 5K interval reminder as a safety inspection. (y)
  6. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    hmm, I wonder if this is a TechStream capability to change the 5000 value or if its permanent
  7. Mendel Leisk
    40,957
    Isn't the first item in the US schedule, every 5000 miles, the driver's floor mat security check? The Canadian schedule doesn't say anything on the subject, we live dangerously up here.
    Bay Stater likes this.
  8. Bay Stater
    534
    771
    Central Mass
    LOL... Mat alignment! It's important to align the left front mat for proper pedal travel...:ROFLMAO:
