1. George Gunther
    George Gunther New Member
    erie,PA
    tips 4 storing 2 months or longer
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Fully charge, insure 12 V is healthy. Disconnect 1 lead on 12V or connect 12V to trickle charger. Leave car unlocked, fix trunk to a ajar position ( otherwise, entry by trunk could be a problem ) and...that's it. OR
    Give it to a trusted friend to drive.
  3. JC91006
    JC91006 Senior Member
    16,733
    8,548
    It would be a good idea to store it with a full tank of fuel.
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    If rodents are an issue at that place and time, you might want to place bait or traps.
    It's best if engine is hot last time you shut it down before storage, to evaporate moisture from engine and oil.
    Don't leave parking brake on if at all possible. Chock a wheel instead.
  5. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Since we're dealing with an "or more" situation, I would compliment the above with the addition of the appropriate amount of fuel stabilizer.
    Additionally, I would "force charge" the HV battery prior to storage.
    goldfinger likes this.
  6. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    What year and how many miles? I've seen threads suggesting storage can finish off an older HV battery.
  7. Mendel Leisk
    40,956
    Wouldn't hurt to bring tires up to max indicated on the sidewall, kinda overkill for two months though.
    S Keith likes this.
  8. bisco
    51,513
    welcome! i've left mine up to 6 weeks without doing anything. two months or more i would follow all the advice above. how old is your 12v?
  9. Kenny94945
    Kenny94945 Active Member
    844
    421
    Sausalito
    2016 Prius v wagon
    Perhaps the OP is questioning as to specifics with a Prius.
    a) I would confirm the tickle charger.
    That's more than likely the most important issue I'd look into.
    b) rodents....I love that thread on this site.
    As with all cars:
    c) fuel tank full...some add a fuel stabilizer such as Sta-Bil, as modern fuel seem to "gum up" over time.
    d) one window down (or trunk as mentioned above) so you can access in case of total electronic failure.
    e) flat spotting of tires...inflate to maximum pressure or better place the vehicle on jack stands.
    f) car covers...use it if you got it.
    Two months...world wide vacation I hope.
    S Keith likes this.
