1. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Never thought I'd ever have an issue with replacing an oil dipstick from the engine bay . I removed the Prius oil dipstick to check level but found it was always difficult to re-insert the dipstick back in.
    What am I doing wrong?
    LG-H901 ?
  2. Mendel Leisk
    41,486
    Steady it mid-way along it's length as you're putting it back in, with the oil rag.
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …you might want to check the prescription for your eye-glasses? :eek::confused:;):) (PS: one of those LED head-lamp thingies might be useful! I love mine!!!)
    Frederickdawg likes this.
  4. Frederickdawg
    596
    335
    Haha for sure, I'm getting short sighted during my approach to middle agedness.
    But joking aside, I removed and tried inserting the dipstick multiple times, but each time there was a lot of restance. In some cases almost wanting to bend the dipstick if I forced it any further.
    LG-H901 ?
  5. bisco
    51,973
    so, are you stuck with a non operating car because of it? how far is it going in? i have found that twisting it back and forth can help, but maybe gen 4 is longer?
    #5 bisco, Apr 26, 2016
  6. WilDavis
    2,493
    2,155
    49
    Yup, I understand your dilema! I notice that the dip-stick on my 2009 Gen II is a bit stiff sometimes, just remember not to force it in, and never, ever try to use the small hole to add oil! (…it's been done before, and I'm sure it will be done again!:eek::eek: :rolleyes:;))
  7. Mendel Leisk
    41,486
    Most dipsticks these days will start to bend if you just push them in unsupported, they're pretty thin. You've gotta reduce their unrestrained length, it's like a tall/skinny column without bracing otherwise.
  8. JC91006
    JC91006 Senior Member
    16,769
    8,567
    This is unusual, maybe try to just push it in and break it.......surely a TSB on the 2016 would be necessary if you actually can break one.
  9. Trollbait
    12,543
    This thread can be so wrong or so right if it were on another site.:whistle:
    In seriousness, the path the dipstick is taking may not be straight, and is curving to reach the oil pan.
    Been awhile since I checked a Toyota's oil level. GM's have a metal bob at the end that is easier to read than holes and crosshatching stamped in the end of the wand, but it seems to result in more resistance in pushing it in.
  10. ETP
    2,802
    1,170
    Auburdale FL
    Try different insert twist directions of the stick angles. Turn the stick at different angles to the dangle. Just don't get tangled in the prangle. Have another car that will only go in one way.
    #10 ETP, Apr 27, 2016
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    turn it so the flat sides of the dipstick are following the curve of the tube so it bends as it goes in.
    Eastside and Trollbait like this.
  12. CR94
    CR94 Senior Member
    2,695
    1,174
    Northwestern S.C.
    Is it bent or otherwise mangled? (It should be close to straight in its relaxed state.) If not, inserting it should be easy, if you follow the above suggestions to support it in the middle to prevent it buckling, and orient it correctly with respect to the curves in the tube.
    My mother's Camry came with the very tip of the dipstick bent sharply, so it would barely fit into the tube. Edges of the tip were also rough, as if something had been gnawing on it. The dealer claimed that was normal. I straightened it with pliers.
  13. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Mine slides very easily back in. Are you making sure to replace the stick the same way it came out?
  14. Frederickdawg
    596
    335
    I figured it out hahah... Silly me, the dipstick tube is slightly bent and I was being way to gentle when attempting to re-insert it.
    LG-H901 ?
    Jon Senum and bisco like this.
  15. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    Don't wipe the oil off of it before you reinsert it, it's all about the lube:p
  16. WilDavis
    2,493
    2,155
    49
    I was always advised to "whip it in, whip it out, wipe it off!" and that advice has held good for me for the past 50+ years! o_O:rolleyes:;)
    priusgto, Frederickdawg and bisco like this.
  17. Frederickdawg
    596
    335
    Lucky you, I'm not even 50 and how can I put it mildly.. Seems to work around 50% of the time.
    LG-H901 ?
  18. bisco
    51,973
    that's because the dipstick is slightly bent, and you're being way too gentle.;)
  19. Former Member 68813
    3,524
    983
    US
    this is a hilarious discussion considering dipstick can have different meanings (according to urbandictionary).
  20. Mendel Leisk
    41,486
    Wait'll you're 64. :(
