2004 TOYOTA PRIUS KEY INSIDE A CAR DISPLAYED MEANING
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by corderoj, May 8, 2016.
  1. corderoj
    corderoj New Member
    PUERTO RICO, USA
    Hi...can someone tell me the reason for a warning light of a key inside a car...the Prius don't start...the light blinks intermittently whenever the key is in the area or inside the key slot. I check the 12 battery and it gives me nearly 13 volts. Someone told me the problem is the cluster...I try to scan the Prius but it reads "NO CONNECTION". Can someone help me???? Thanks.
  2. Stevewoods
    Stevewoods Senior Member
    652
    1,062
    Seattle, WA
    I'm 99 percent certain that the key fob -- your little black box key -- needs a new button battery.
    Does the red light on the actual key fob light up when you press the open button. Lots of threads on here on how to install a new button battery.
    The actual flashing key icon is part of the security system warning.
    Put a new battery in the fob -- a few dollars -- and report back.
    FOB battery replacement - how & when | PriusChat
    BTW, when our FOB battery went out a few years ago, my wife insisted just replacing the battery wasn't good enough, she wanted new FOBs -- two of them -- hmm -- spend several hundred US dollars on new FOBs, or use some Meguiar's Mirror Glaze cleaners on the old ones, put in $7 worth of new button batteries and tell her I replaced them...
    You figure out what I did.
    #2 Stevewoods, May 8, 2016
  3. JC91006
    JC91006 Senior Member
    16,659
    8,509
    Try to reset the car by disconnecting the negative terminal on the battery for a few seconds.
    Even with a dead fob battery, the car should start if you put it in the key slot
    SM-N900P ?
  4. Stevewoods
    652
    1,062
    Seattle, WA
    Hmm, I never ever think about the key slot. In fact, I don't even think I have ever looked at it.
    You are right. Being cheap and lazy, think I would disconnect negative for a few minutes and if that did not do it, still try and replace the FOB battery
  5. JC91006
    16,659
    8,509
    If the car can go into accessory mode, then it's not a key fob problem with the car not starting
  6. corderoj
    corderoj New Member
    PUERTO RICO, USA
    Thank you very much for the information, but I already checked that...I replace the batteries for each key fob set with fresh ones and verify with the voltmeter they are in good shape.
  7. bisco
    51,040
    is the 13v at the 12v battery after the car has been off for a few hours?
