Need help identifying noise behind dash
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Truffles, May 19, 2006.
  1. Truffles
    Truffles Junior Member
    56
    Antioch, CA
    Hello,
    I have a 2006 with about 7800 miles. There is a noise that I can't seem to identify that seems more pronounced over the last few days.
    It's coming from behind my dash, right on the other side of my speedometer. It sounds like a pump of some sort is activating. It can happen every couple of minutes and it lasts around 5 seconds. It seems to be more common at slower speeds, but this could be just due to less road noise.
    The only way I can describe it is it sounds like a whirling or winding noise of some sort.
    Thank you
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    the brake pump, hydraulic pressure pump, is on the RH side of the car in a line from the driver seat to the right of the speedo cluster. To find out if it is what is causing the noise stop the car and put it in Park and then step on the brake pedal hard 4 times, is that the noise?
  3. Truffles
    56
    Antioch, CA
    that's it.. thank you. It seems to be cycling on more than before. I'll do some addtional research on the forum.
  4. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    if it's running that often you need to have it checked out. the system is losing pressure way too quickly if it's running every couple minutes. unless you're talking about heavy stop and go traffic with lots and lots of braking.
  5. edselpdx
    edselpdx Member
    191
    Portland, OR
    <div class='quotetop'>QUOTE(galaxee @ May 20 2006, 02:32 PM) [snapback]258577[/snapback]</div>
    Mine has always seemed to run alot. (2005). Almost every time I come to a stop I hear it, and i do mostly city driving with frequent lights. I actually wouldn't worry much unless it seems to interfere with driving or performance.
    sj
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    It's okay if it's running fairly frequently when you're *using*
    the brakes, but not when you're not. Try sitting in one place for
    a while, in Park. If the accumulator keeps leaking down and causing
    the pump to run with no brake usage, then have it checked out.
    The increase in noise over time may simply be the pump "wearing in".
    New accumulator pumps seem to be a bit quieter than ones that have
    been on the road for a while, but this doesn't mean the seasoned ones
    are shot yet.
    _H*
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Yup, I'm with Hobbit and others. If you're hearing it that frequently I'd beconcerned about the accumulator running too often. There was a report on PriusOnline a year or so ago where someone had that problem.
  8. Truffles
    56
    Antioch, CA
    Thank you all..
    I'll have it looked at soon. If anything exciting is found, I'll let you know.
