Numbers in Console Test for 12v battery of any use?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by woody23, May 1, 2016.
  1. woody23
    woody23 Junior Member
    69
    I've read a lot of conflicting information. I am going to get a multimeter to test myself, but I was curious to get a read out of some sorts.
    I have 2010 Prius IV, owned about 16 months, battery has this number on the top 170610W so I assume it is 6 years old.
    I am interested in the health of the 12V battery because a few months ago my car wouldn't start and I had to get it jumped... I'm not sure what I left on exactly, it had to have been something in the cabin. But the car has run fine since then. I couldn't open the trunk the other day, it was raining, though, and that problem has ceased.
    Did the console test after the car was off for 36 hours, here are the numbers:
    No load: 11v
    Headlights on: 10.8v
    Car on: 13.7v
    Is this useful in confirming I need to get a new battery pretty quickly or was it useless since the car was off for so long?
  2. Former Member 68813
    3,524
    983
    US
    tell me how you get to the console test and i'll tell you my numbers.
  3. Mendel Leisk
    40,467
    All things considered, I'd get on replacing that one asap.
    A healthy 12 volt would be around 12.6. 11.0 and lower is bad, and being that low for protracted time is worse.
  4. Former Member 68813
    3,524
    983
    US
    yes, but those # under console test (whatever that is) could be under load. the numbers you quote are for resting battery without load.
  5. woody23
    69
    Instructions I used:
    1. Foot off Brake Pedal
    2. Push POWER Button twice
    3. Hold in INFO button on right of NAV display while doing next step.
    4. Turn Headlights On and Off three times. - Menu comes up.
    5. Press "Function Check/Settings" on NAV display.
    6. Press "Vehicle Signal" on NAV display.
    Battery Voltage is displayed
    7. Turned on headlights and it adjusted. Turn off headlights.
    8. Place Foot on Brake Pedal and Press POWER button turning on the car. New reading.
    9.. Press POWER button to turn off car.
  6. Former Member 68813
    3,524
    983
    US
    can't do it, don't have Nav. you have to find someone with prius IV to compare or buy a battery load tester.
  7. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    Mine was:
    12.5v
    11.1 full load (all lights on, rear defroster and full fan)
    14.7 powered to ready.
    Car is about 4 years old.
    iPhone ?
  8. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    I'd say that battery is pretty much toast. Sure, it'll work day to day. But just when you need it to last over a weekend it will fail you. Further, being that low on voltage, it is probably sulphating on its own and will fail totally soon.
    If you see 11V, even under a higher load, the battery is not very healthy. Keep in mind the load you are applying is only around 10 Amps with the headlamps on (halogens - less if HID or LED). That's a minor load for a 38 A-Hr battery.
    And 6 years old is too old anyway. At least for an OEM Prius battery. Some last longer, but they are few and far between. ;)
  9. woody23
    69
    Thanks for all the input guys. That is what I was guessing. I will order the yellowtop Optima everyone seems to speak highly of. Toyota dealer quoted me some absurd amount to just install it, I think it was like $70. I'll try to find a good guide and do it myself or find a friend to help me. Only worried about the hydrogen gas.
  10. macman408
    1,179
    367
    I wouldn't put much stock in what the navigation readout of the voltage is. In addition to the fact that there's a decent load on the battery in those conditions, the sensor isn't at all accurate or representative of what your actual battery voltage is. When I measured the voltages in my car when it was only a couple months old, the Navigation system told me the battery was 11.5V, but at the exact same time, my multimeter told me it was 12.17V. (Under no load – all doors closed, all lights off, etc. – it was 12.50V.)
    I'm still on the same 12V battery, 6 years later - almost exactly. My post was 6 years ago tomorrow!
    That said, you'll need a new battery sooner or later, so having it a little sooner probably won't kill you either, and might save you another jump start or two sometime.
    woody23 likes this.
  11. David Beale
    5,963
    1,987
    Edmonton Alberta
    You can use the stock vent tube on the Optima battery. You -may- have to buy a few bits to adapt it but I think it fits without any.
    Check with eLearnaid. They are easy to deal with.
    woody23 likes this.
  12. Mendel Leisk
    40,467
    I got the Optima a few months back, it's an exact fit, including the vent.
    Oh, the height was the slightest bit different, requiring me to add a washer when installing the top bracket.
    The latter' a poor design by Toyota: the typical battery hold down hook bolt system is more accommodating to slight variations.
    woody23 likes this.
  13. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Why? There's little reason to worry about that unless you do something weird.
  14. Mendel Leisk
    40,467
    Just like saying a Hail Mary, I blow across the top of battery before doing any connection or disconnection. That'll dispell the (very insignificant) hydrogen gas.
    Also good to wear safety glasses, at the least. Full face shield even better. I don't do either half the time, but maybe should start.
  15. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Ha! Hydrogen is extremely light stuff. Any traces of hydrogen near the terminals will have rapidly escaped upwards before you blow, unless it's somehow trapped. I'd worry more about acidic gunk bouncing back in my face.
  16. woody23
    69
    So I followed the advice on this thread and got the Optima YellowTop off ebay and I used a multimeter on it to see the charge is at 12.55. Is this good for a brand new battery or should it be closer to 13v brand new?
  17. David Beale
    5,963
    1,987
    Edmonton Alberta
    That's fine. Indicates it still has some "surface charge". If it sits long enough it will settle to about 12.1 or so.
  18. woody23
    69
    Thanks David,
    Should I hook it up to a charger and get it to 13v before installation?
  19. bisco
    51,024
    yes, trickle charge it before installing. it should be around 13, and the car is better at maintaining than charging. if it won't hold 13, send it back. what the build date?
  20. Mendel Leisk
    40,467
    When I put in an Optima about 6 months back, after an initial charging it read about 13.15 volt. A day later it settled to around 12.85. It seems now to hang around 12.6-12.7.
    Use a smart charger, up to 4-4.5 amp. Let it run to completion. You can put it in first, charge in-car, either way will work.
    woody23 and bisco like this.
