Featured GPS use bad for your brain?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Mendel Leisk, May 17, 2016.
  1. Mendel Leisk
    40,495
    I recall coming back from the Tsawassen ferry terminal one time, battling my way through the labyrinth that is Richmond, decided to ask Garmin to get me home, North Coquitlam. Unfortunately, with dated map and road construction, it took me the long way, way east, ended up doubling-back across the Port Mann Bridge. Anyway, something in the news:
    Study suggests reliance on GPS may reduce hippocampus function as we age
    CBC radio "The Current" podcast on the subject, here:
    Home | The Current with Anna Maria Tremonti | CBC Radio
    #1 Mendel Leisk, May 17, 2016
    JohnF likes this.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    I love my GPS, but you still need to keep your eyes on the road signs, and use your common sense.
    WilDavis and Mendel Leisk like this.
  3. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    I was noticing just the other day that my hippocampus was atrophying. Now I know why! Thanks!!
    I will send this, with glee, to a friend who champions GPS usage.
    WilDavis likes this.
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    I've found the mapping app. in my SmartPhone to be pretty good, although it will seeming get confused occasionally, which is why I never totally rely on it, in other words I research any prospective route beforehand, and have even been know to use paper maps as a backup! o_O
  5. bisco
    51,040
    if your hippocampus gets smaller, you won't need rhinoplasty.
    JohnF and Mendel Leisk like this.
  6. breakfast
    breakfast Active Member
    266
    199
    When I started driving, we didn't have any GPS. It must have been...
    RECALCULATING
    Let's see. I just traveled 455 miles and filled up with 8.87 gallons of....
    RECALCULATING
    ....wait, where was I again? ;) :)
    bisco and JohnF like this.
  7. booke02
    391
    415
    Israel
    I recall that for our first overseas road trip (to Portugal) many years ago, before GPS even existed, I spent weeks preparing for the trip and printing off strip maps in the (futile) hope that Lady Navigator would be able to keep me on the right track.
    Today I wouldn't dream of doing such a trip without GPS. We have used it in many countries around the world where it has kept us out of serious trouble. Certainly makes for a calmer atmosphere in the cockpit!
  8. Mendel Leisk
    40,495
    I do like how it "recovers", say when you miss your exit, overshoot.
    breakfast likes this.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    So if I use the GPS for navigating, my brain's ability to navigate will be negatively affected? Isn't that like saying a persons musical playing ability is negatively impacted if they don't play the piano? Who is to say my spatial cognitive senses are not flawed in finding my way from point A to point B? What if arriving at the destination on time robs me from experiencing life? I.e. arriving on time to my take my test or to make a flight?
  10. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    What it is saying is that there are two types of navigation: following a series of directions versus using a spatial sense of where things are in relation to each other. As just one example, my former girlfriend relied totally on her Garmin. As a result, she thought that Boston was on the way from my place in CT to Vermont. Boston is well east of the direct route. She lacked a mental spatial map of where the places were with respect to each other.
    Probably the best tactic is to use both, each supporting the other: for example, if a direction seems wrong, you check it on a map.
    Having a spatial sense of where things are can enrich your experiences: going from A to B you may know that you will pass close to C if you have a spatial sense, you might never know this if you relied totally on a NAV system.
    Strictly speaking GPS just tells you where you are, a NAV system provides the routing (and may record where you have been).
    #10 JohnF, May 17, 2016
  11. Mendel Leisk
    40,495
    Prior to hearing this on the radio today, I've thought it, more than once: that GPS was making me stupid. One, because I'm just "following orders", and two, it leaves me in-the-dark for next time: it takes active effort to make you remember a route.
    JohnF likes this.
  12. Trollbait
    12,321
    Couldn't the same be said about calculators and slide rules before them?
    After using GPS nav for a route a few times, I tend to remember it on my own. I think the Magellan is onto me though. Visiting to a friends new place, it used a different route going there and coming back.
    JohnF and mmmodem like this.
  13. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Yes, in a way. With a slide rule, you knew that you had to figure out where the decimal point went. In essence, you had to have an idea, perhaps through a rough mental calculation, how big a number to expect as a result. With a calculator, you just punch in some numbers and write down the result, and the tendency is to not think whether that result makes sense (maybe you entered the numbers wrong?).
    I think it was Richard Feynman who pointed out that mathematicians develop a "feeling" for numbers as more than just a collection of digits: how big they are, what their properties are (odd or even, a product of two primes for example), etc. And develop mental shortcuts based on that. A very simple example: if you want to deduct 15% from a number, take a tenth of the number (easy), add half of that (also easy), and subtract the resulting sum from the number.
    This doesn't seem all that different from developing a spatial sense of where things are in relation to each other.
    alanclarkeau likes this.
  14. WilDavis
    2,493
    2,154
    49
    I seem to remember something learning something similar to what you're describing back in my early days of learning Mathematics - I think the teacher called it "scaling" and "dimensioning", and said that it should always be done before any calculation was attempted.
  15. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    I find GPS is safer than trying to manhandle a map or street directory while driving, particularly across a part of the city I'm not familiar with. Additionally, a street directory on the passenger's seat requires me to change glasses to see clearly (and in the dark ...).
    You could be right, as with GPS, you have a verrry small map showing, with a street directory, it's a suburb or 2 in view, giving a much broader aspect of the trip.
    But I think deterioration of the brain is more involved than just using GPS. When I went to work, there were many minor mathematical calculations, time, estimates, quotations, composing correspondence which HAD to be perfect, thinking through computer programs etc. And when there were 5 here at home, there was much more thought required with budgeting, help with children's homework, adjusting agendas to fit in everyone's activities. Now, in retirement, life just goes on, doesn't need much fore-thought and planning for one person.
  16. WilDavis
    2,493
    2,154
    49
    You've reminded me of an article I read in the NYT:
    Nuns Offer Clues to Alzheimer's and Aging - NYTimes.com
    (…wow - 15 years ago!) - but an interesting article, food for thought, nothing about GPS, but significant when examined in the context of what seems to be the world's current malaise! o_O :( ;)
    bisco and Mendel Leisk like this.
  17. Former Member 68813
    3,524
    983
    US
    simple, use it or lose it.
  18. bwilson4web
    15,989
    Rand MacNally hates GPS. I tossed our collection out 10 years ago and never looked back.
    #18 bwilson4web, May 17, 2016
  19. bisco
    51,040
    does priuschat count?:)
  20. dipper
    dipper Senior Member
    1,242
    252
    Wait until autonomous dirving, we will be that fat guy in Wall-e.
    Mendel Leisk and Trollbait like this.
