2003 Prius Won't Start after HV Battery Replacement
Discussion in 'Generation 1 Prius Discussion' started by jmotley, May 18, 2016.
  1. jmotley
    jmotley New Member
    27
    Lafayette
    2003 Prius
    I have a 2003 Prius and replaced one of the failing batteries in my HV battery pack in hope that would fix the car. It now will not start, with the battery reinstalled, and I have a p3030 code being thrown. Also, after sitting for a night, the main display goes black and has 'waves' in it when it does show. When I turn the switch on there's a clicking noise coming from the area around the battery.
    *It may be worth mentioning that I used a power drill to remove/reinstall screws and bolts on the battery pack itself, including the bus-bars.
    Any help I thank you for in advance!
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
  3. jmotley
    jmotley New Member
    27
    Lafayette
    2003 Prius
    12V As in the regular 2 post car battery? Also, I edited my original post to include the fact that I used a drill to remove/reinstall parts on the battery, could that have 'snapped' a high voltage line connection?
  4. S Keith
    799
    329
    AZ
    2003 Prius
    Yes and Yes.
    If you over-torqued the nuts (48 in-lb), any number of bad things can happen including module damage.
  5. jmotley
    jmotley New Member
    27
    Lafayette
    2003 Prius
    Thanks for your help!!!
    The 12V battery has 11.5V, last night it was 12.5V. I left everything connecting hoping that it needed to "sit for an hour" as I saw in another thread on this forum.
    If I damaged one of the connections to the bus-bar, like what happened in the article you linked, then is it possible to replace that tabbed connector piece or is the entire bus-bar required in that case?
  6. S Keith
    799
    329
    AZ
    2003 Prius
    The bus bars are the small copper pieces that join adjacent modules. The issue you have is with the sensing wires as described in the article. You can attempt to repair the connection yourself. First, you have to locate which of the 19 connections is at issue. If you have techstream, you should be able to see which block is the problem Torque Pro for Android with the Gen1 extended PIDs will also get you that information. A more permanent repair is to replace that harness per the article.
    A fully charged healthy 12V battery shouldn't be much below 11.9V when initially loaded. I recommend you charge your 12V to be certain.
    Good luck,
    Steve
  7. usnavystgc
    3,159
    990
    Tucson, AZ
    I would really suspect whether or not the orange safety plug is properly installed. Search the forum for the correct procedure.
    acadiel likes this.
  8. jmotley
    jmotley New Member
    27
    Lafayette
    2003 Prius
    Thanks for the reply, I am pretty sure I did this correctly, and I did a search when I started having problems last night and found the correct procedure for a 2nd gen Prius but couldn't find the same information for a 1st gen.
  9. jmotley
    jmotley New Member
    27
    Lafayette
    2003 Prius
    I am going to charge the battery and hope for the best. Is the p3030 code like the p3006 code at all, in the sense that it could be thrown for some general issue? Or is it specifically in reference to the connections? Thanks again!
  10. S Keith
    799
    329
    AZ
    2003 Prius
    According to that article, it's very specific. Again, with techstream or torque pro, you could confirm it.
  11. jmotley
    jmotley New Member
    27
    Lafayette
    2003 Prius
    By torque pro do you mean the Android app? *Sorry didn't see it in the above post.
    What kind of device do I need to run that software? Will any OBD2 to bluetooth scanner run that software?
    #11 jmotley, May 18, 2016
  12. S Keith
    799
    329
    AZ
    2003 Prius
    Yes. and Yes. I use this one:
    Not sure if it matters as I suspect they're basically all the same cheap chinese clones inside, but these have served me faithfully.
    Note that I have modified the extended PID file available on this site. I edited the descriptions with a "G1-" prefix, so I know it's G1 specific and doesn't overlap with the Gen2 file... which I have edited with a "G2-" prefix...
    Note also that I have had trouble on my own '03 and another with BOTH techstream and this reader. They have both worked periodically. I don't know if it's the connector or what. I just haven't cared enough to dig deeper.
    If you go that route and want to use my CSV file, it's here.
    Again, it's identical to the original with the exception of a "G1-" prefix to every label.
  13. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    I remember finding a burnt wiring harness in a couple of 01 models. You need to check the wiring harness that runs down the side of the battery pack for burnt or broken wires/connectors.
    Also, I've found that most of the 1st gen modules that I've tested are no good any more. When I rebuild a 1st gen pack, I use 38 2nd gen modules. You need to test all your modules or you may be right back in there soon. You could even burn another harness or connector, if that is what it turns out to be in this case.
    S Keith likes this.
  14. S Keith
    799
    329
    AZ
    2003 Prius
    These are excellent points, and not just on Gen1 but Gen2 as well. Just as important as evidence of burning is the presence of corrosion. Inspect the harness connector where it plugs into the ECU for evidence of corrosion on any of the pins. Additionally check the ECU pins for similar corrosion. Presence of corrosion at this interface is believed to be the predecessor to fires at the ECU. I use a 20X jeweler's loupe.
  15. jmotley
    jmotley New Member
    27
    Lafayette
    2003 Prius
    I tried charging the 12V battery up and I'm getting the same result, no attempt to start by the car and funny clicking noise.
    I ordered an OBD2 to USB from Amazon today, it was included in the list of supported models on Torque Pro's website.
  16. jmotley
    jmotley New Member
    27
    Lafayette
    2003 Prius
    The wiring harness wasn't burnt, but there was some buildup on the terminals of some batteries. Unless that is what you're referring to?
  17. S Keith
    799
    329
    AZ
    2003 Prius
    OBD2 to USB? Why?
    Please link.
  18. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    It really sounds like you will need to tear down and re-vist your steps, those module nuts require specific torque, maybe a nut is loose if you are lucky.
  19. jmotley
    jmotley New Member
    27
    Lafayette
    2003 Prius
    I have a hunch that my drill broke one of the tabs that go behind the nuts on the bus-bar, especially since that is what my code indicates. I am going to try the OBD2 tool. I will look at them when I tear down the battery again thought, thanks for the reply.
    added picture of print screen because I can't add links to my posts yet.
    Found those two on the same site, plus it was much cheaper than the OBD2 bluetooth units, it supports Torque pro. Had to buy a USB to Micro-USB adapter for my Android phone.
    Ctrl+f this --> "Working USB Adapters"
  20. S Keith
    799
    329
    AZ
    2003 Prius
    I've just never tried USB on a phone for that interface. It makes me nervous.
