Why is my dash displaying all 2's??????????
Discussion in 'Gen 2 Prius Main Forum' started by sorka, May 24, 2016.
  1. sorka
    sorka Active Member
    1,017
    197
    Merced, CA
    2019 Prius
    Looked down on my way to work yesterday and saw this? Anyone know why?
    m.wynn likes this.
  2. wjtracy
    wjtracy Senior Member
    11,359
    3,606
    Northern VA (NoVA)
    That part (combination mater) can go bad and is subject to a special 9 yr warranty. But the "2" failure is not the expected behavior that I know of. Looks like CEL is on so you need to get codes.
  3. prius_power
    prius_power Junior Member
    57
    Ohio
    Wow. Assuming that is not your speed and current mileage, that is one of strangest issues I've heard of. Best guess, may need a new combo meter, but most of them usually go blank when they fail. Your car may still be under the extended warranty for the meter.
  4. sorka
    sorka Active Member
    1,017
    197
    Merced, CA
    2019 Prius
    The clock also shows all 2s.
  5. wjtracy
    11,359
    3,606
    Northern VA (NoVA)
    ...I do not know the answer if the clock gets the time from the meter or what...just brainstorming here
  6. prius_power
    57
    Ohio
    Now I kind of want to try this when my car gets to 111K miles.
  7. bisco
    51,040
    12v battery?
    wjtracy likes this.
  8. wjtracy
    11,359
    3,606
    Northern VA (NoVA)
    Great idea!
  9. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Take care what you wish for! My 2009 Gen II suffered the Combo-meter failure at around 111000 (see threads passim) all fixed under warranty (including loaner for nearly 3 weeks) - Thanks Toyota! :)
  10. sorka
    sorka Active Member
    1,017
    197
    Merced, CA
    2019 Prius
    My combo meter went out about 4 years ago and was replaced under the warranty enhancement. Warranty still good until September 2017 but I don't the newly designed replacement will ever fail.
