Dashboard Chrome trim ring around the "Power" Button
Discussion in 'Gen 2 Prius Accessories & Modifications' started by bshef, May 21, 2006.
  1. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    The little plastic chrome Trim ring around the power button on the dashboard.........
    On sunny days.......the glare and reflection from this thing is KILLING ME!.......
    Anyone else have this problem?
    Any Suggestions for changing it out or painting or covering it? :blink:
  2. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Can't say that I've ever had that problem.
    But it's possible that replacing it would require removing the dash which would involve potential airbag issues. On the passenger side, that is.
  3. aaf709
    3,862
    2022 Prius Prime
    You might try carefully painting it with a flat black.
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I turned mine upside down, but it's still shiny. Thought about
    painting the rim matte black or something..
    _H*
  5. bgdrewsif
    bgdrewsif New Member
    497
    Phoenix, Arizona (formerly Bowling Green, Ohio)
    I LOVE the chrome... and Ive never had a shine or glare issue from any of the shiny bits and pieces...
  6. qbee42
    3,079
    <div class='quotetop'>QUOTE(bshef @ May 21 2006, 05:35 PM) [snapback]258932[/snapback]</div>
    What's a sunny day? B)
  7. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    <div class='quotetop'>QUOTE(qbee42 @ May 21 2006, 07:55 PM) [snapback]259059[/snapback]</div>
    Sorry Tom.....
    if it's any consolation........your gas is probably $0.40/gal cheaper in Michigan :blink:
  8. Tideland Prius
    16,535
    no problem there. Although my chrome bit is a little loose.
  9. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    This was the first mod I did. The glare was very distracting for me so I took my bottle of touch-up paint and made the ring match my exterior. Now...what does one do about the car ahead of you with glare coming off their rear window?
  10. talonts
    talonts VFAQman
    468
    76
    <div class='quotetop'>QUOTE(bshef @ May 21 2006, 04:35 PM) [snapback]258932[/snapback]</div>
    If you pull the dash panels and remove the switch from the dash, you can remove the chrome part completely from the rest of the switch (it's not fun, but can be done, just pry in the "right" areas), and spraypaint it for a smooth finish.
