Is Duracell 12V Battery My Problem? - All Warning Lights Appeared+Shutdown
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by David Brydon, May 29, 2016.
  1. David Brydon
    David Brydon Junior Member
    Mc Gregor, TX
    First time after being parked for hours, Sarah tried to start and got red triangle, Brake and VSC lights.
    Then 10 days later driving at 60 on highway all warning lights came on again, steering and brake worked minimally, gas engine shut off. Limped off road.
    In both cases after it sat, all warning lights went away and back to normal.
    0 codes after second time.
    after first time, codes non start, abs code, transmission codes, some hybrid battery code, nothing conclusive
    Tested battery, seems perfect. Is 3 month old Duracell Ultra Platinum AGM Group 51 Battery. Have driven many problem-free miles til now on it.
    Looked at inverter coolant reservoir. Is very good flow with small waves. Is that turbulent enough?
    I think key fob battery is almost dead. Was in car but not stuck in dashboard. Could that cause a problem?
    Weather only in 80's and driving typically 10-30 miles at a time. Doesn't seem like inverter coolant pump.
    My thought is to get a 12V battery from the Toyota dealer under the guess that the Duracell battery is causing trouble. Maybe too high a voltage?
    Only other potential clue is my son was in the back and said he heard a vibrating sound in vicinity of rear axle like a diesel truck far away, then got quiet when warning lights all came on. But he is not sure it even came from the car.
    Hoping for direction.
    51,844
    sounds more like your hybrid battery is overheating. can you hear the cooling fan in back? it might need cleaning.
  3. JC91006
    JC91006 Senior Member
    16,762
    8,562
    If warning goes away after letting car sit for hours, it's a case of overheating
  4. Stevewoods
    Stevewoods Senior Member
    659
    1,125
    Seattle, WA
  5. David Brydon
    Mc Gregor, TX
    I want to learn to keep this car well. I will check the fan and clean right away. Thank you for the tip.
    The fact that the first incident happened when the car had not been driven all day, but just when Sarah tried to start it in the evening after working all day, and not a hot day, indicated against overheating being involved.
    That's why I was reaching for a 12V battery issue...
    Had brought Prius home on trailer. Just got it off and drove on fairly flat road gently. Outside air 87F. Lots more to diagnose now. HV battery started at 3 bars. Gas engine started right away and ran, charging battery up to 6 bars after about 1 mile. Then Triangle, (!) and VSC lights came on. Pulled in at a friends and parked while I wrote notes and checked for codes. No codes. Headed home. gas engine would not come on, driving by HV battery. Stopped and turned off 5 min. Restart. Triangle the only light on. gas engine comes on and drives home fine. park and turn off. 12V battery shows 12.8V.
    Now I will clean HV battery cooling fan.
    Any ideas?
    #5 David Brydon, May 29, 2016
  6. Sam07prius
    Sam07prius New Member
    New jersey
    Hey guys I was wondering if anybody could help me put I'm new to this site I don't know how to start my own post ... my 07 prius had a lot of warning lights posted up a couple days ago and now the car won't really drive the way it's suppose to and it won't drive up hills at all now and there's a noise that coming from the fan or whatever it is next to the back seat . Does anybody know what's wrong with the car???
  7. JC91006
    16,762
    8,562
    Bad battery
  8. Sam07prius
    New jersey
    Thank you so much for replying I apreciate it . Does this mean I have to replace the hybrid battery because I hear it can cost up to 4000 to replace. Screenshot_2016-05-29-20-26-48.png Screenshot_2016-05-29-20-26-37.png 20160529_201006.jpg 20160529_200959.jpg 20160529_174851.jpg Screenshot_2016-05-29-20-26-48.png Screenshot_2016-05-29-20-26-48.png Screenshot_2016-05-29-20-26-48.png Screenshot_2016-05-29-20-26-48.png Screenshot_2016-05-29-20-26-37.png the Screenshot_2016-05-29-20-26-48.png Screenshot_2016-05-29-20-26-48.png Screenshot_2016-05-29-20-26-37.png 20160529_201006.jpg
    #8 Sam07prius, May 29, 2016
  9. bisco
    51,844
    to both david and sam: you need to check for codes with tech stream. other readers are useless or only partly useful on a prius.
  10. bisco
    51,844
    how are you measuring the 12v?
  11. Sam07prius
    New jersey
    What's tech stream exactly?
  12. bisco
    51,844
    it's toyota software. you can buy it on line, called 'mini vci' and hook it up to an old windows laptop, or you can pay toyota to read them. you get the codes, the description of the problem and a troubleshooting tree.
  13. David Brydon
    Mc Gregor, TX
    Thanks, Bisco. I was wondering about the codes. I will look into getting tech stream.
    I pulled the high voltage battery cooling fan. maybe 2 or 3 slits were completely blocked. 5 or 6 30% blocked, but mostly open and not terribly dirty. Definitely needed cleaning and I'm glad to know luscious garage recommends every 60K to clean it.
    I plugged it back in its place and turned on the 07 Prius. All warning lights gone, engine started fine. No sound from the cooling fan. Does high voltage battery cooling fan run all the time or only certain times?
  14. David Brydon
    Mc Gregor, TX
    I looked at 12V battery voltage on the MDF.
    with engine off it is at 12.8V and drops to 12.5V with headlights on and right back to 12.8 with them off.
    When engine running it says 14.1V.
  15. David Brydon
    Mc Gregor, TX
    Another test drive after cleaned hybrid battery cooling fan. Ambient outside air temp down to 77F. Drove many miles, no problems.
    The hybrid battery cooling fan never came on. Is this because air temp is cool or because it has failed? How can I test?
    Seems like the hybrid battery overheating may be the key. Thanks again.
  16. David Brydon
    Mc Gregor, TX
    I ordered a 64 bit version of mini vci from ebay.
    I found
    prius how test hybrid battery fan
    push power button 2 times without foot on brake. After about 30 seconds I heard clicks and then hybrid battery cooling fan came on. I had already removed the 10mm nuts that hold the fan on the frame, so I loosened the fan and pulled it out of the black duct that goes to battery. I could feel a good flow of air blowing from the fan!
    I also found this thread about adding another cooling fan. Adding an additional fan to the Traction Hybrid Battery? | PriusChat
    SFO and bisco like this.
  17. dolj
    dolj Senior Member
    8,430
    4,285
    Wellington, New Zealand
    Go to the Forum in which you wish to post - this one "Gen 2 Prius Care, Maintenance and Troubleshooting" would be suitable.
    At the top, to the right, you will see a button labelled "Post New Thread". Click on this and a new thread is born.
  18. user456101
    user456101 Junior Member
    Austin, Texas
    I posted what I thought was the solution but then the exact same problems came back on me after driving it for awhile so I am sorry if I got anyone's hopes up.
    #18 user456101, May 30, 2016
  19. bisco
    51,844
    sounds like the 12v is fine. if it continues to be a problem, check it with a voltmeter.
    hopefully, cooling is your issue and you've solved it. the fan runs at 6 speeds based on temp, difficult to hear, so you can't always be sure when it's on unless you place a tissue over the vent. if the battery is overheating, it's usually easy to hear.
  20. David Brydon
    Mc Gregor, TX
