Those fog light covers
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Frederickdawg, Apr 28, 2016.
  1. xliderider
    xliderider Senior Member
    8,041
    3,213
    Honolulu, HI
    Frederickdawg likes this.
  2. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Tap into parking light positive wire, etc for trigger wire. Fuse box for power.[/QUOTE]
    Just so happens I have a relay harness. Surplus due to me messing with LED work light bars last year on my truck.
    LG-H901 ?
    Paint match is good, bear in mind with metallic paint a wet thicker cost will make it darker and a driver coat lighter. I don't rate their clear coat though. It slightly tints the color. Example using it on a white color base coat will result in a slight yellow tint.
    For a small part like the covers, IRS good. Used the same brand to paint my truck mirror covers. 10k miles later and still no rock chips. So held well.. For a rattle can.
    LG-H901 ?
  3. ETP
    2,802
    1,170
    Auburdale FL
    Gen 2 had the best profile.
  4. xliderider
    8,041
    3,213
    Honolulu, HI
    Not IMO. I like Gen 3. Gen 2 looked slab sided and plain.
    UltraJetRefill likes this.
  5. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
  6. Frederickdawg
    596
    335
    Match was a fluke. Plus bearing in mind it's a small part so the match will be forgiving to the eye. I'm sure if I'd painted the fender things would have been a lot different. Second time I've used duplicolor clear. Holding up well and no rock chips yet. Used it also on my trucks mirror covers a year ago. Same thing, no rock chips about 4/clear coats . only issue with duplicolor perfect match line is the on light colors like white the clear lacquer shows a little tint of yellow.
    LG-H901 ?
    Coast Cruiser likes this.
  7. Coast Cruiser
    2,267
    2,571
    Yeah, it might be hard to find paint in a spray can that matches my white "Blizzard Pearl" color... especially with all the little sparkly things in it.
    (I would have to buy 25 little bottles of Touch-Up paint from the dealer. :ROFLMAO:)
    Did you also spray some clear-coat on other areas of your Prius?
  8. Frederickdawg
    596
    335
  9. UltraJetRefill
    156
    93
    Tucson, AZ
    Resurrecting an old post here, but what paint/color did you use? I'd like to do the same thing. I have a Classic Silver as well.
  10. Frederickdawg
    596
    335
    It's been a while since I did it. But I do know it wasn't original Toyota paint. It was from a spray can I bought from AutoZone I believe.
    SM-N950U ?
    UltraJetRefill and Mendel Leisk like this.
  11. UltraJetRefill
    156
    93
    Tucson, AZ
    Thanks!
  12. Mendel Leisk
    40,507
    @Prius Team (if you're still here?), something to consider for the mid-gen restyle: take a cue from @Frederickdawg, paint that foglight blank body colour.
    krmcg likes this.
  13. krmcg
    2,592
    2,391
    Whittier, CA
    I actually like the black covers on my blizzard pearl Prius. Don't think I would if the colors were reversed.
  14. HopefulGasSipper
    HopefulGasSipper Junior Member
    29
    24
    2018 Prius
    Bump...
    Has anybody done anything with theirs (those black bumper inserts where I think the fog lights go for the touring models) in terms of reflectors or reflective tape, maybe adding additional daytime running lights or trying to add in a fog light circuit?
    Since my 2018 Prius is likely to be handed down to one of my kids, I would like to add something in for their future safety. Of course, in the climate of the time that I'm posting, flamethrowers or rotating blades might be the best accessory to put at the front of the car. So-called peaceful protesters have a habit of attacking people driving their cars on roads... where people shouldn't be standing...
  15. CooCooCaChoo
    CooCooCaChoo Senior Member
    951
    533
    Cow-lee-fornia
    2023 Prius
    Yeah, I was thinking black high visibility tape cut in the shape of the fog light cover:
