If the hybrid / traction battery depleats, am I screwed?
Discussion in 'Newbie Forum' started by massarmor, Jun 16, 2016.
  1. massarmor
    massarmor New Member
    If the hybrid / traction battery loses all its energy completely, will I still be able start my car somehow if the car is off?
    What about if the car is on and the battery runs out? What happens and will the gas engine just charge it?
  2. JC91006
    JC91006 Senior Member
    16,762
    8,562
    How does a traction battery lose all of it's energy? You planning on letting the car sit for 10 years?
  3. massarmor
    The energy monitor shows a meter for the traction battery charging and discharging...
    It will never discharge completely until it malfunctions at >150k miles?
    14.4v likes this.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    No. The HV battery pack is used to spin the gas engine via MG1 (like a starter motor) before the fuel is injected and then the gas burns. No HV battery potential, no engine starty-starty.
    Makes no difference. If the car is READY, engine is off, but the battery is dead, the engine will not spin, the engine will not start.
    The gas engine won't do anything because it won't start.
    Now that your questions are answered, these are either very advanced questions if you are doing some very low level manipulations of the car, or just stupid questions from someone that has no idea how the car works.
    So to answer again as if you have no idea what you're asking:
    When the battery gets to its lowest bar on the screen, there is still 40% or more in the battery pack. The engine can start in the high single digit, low tens of percent SOC (8%-12% usually). There are only a couple ways this can happen. If you run out of fuel, you can then continue going on just the battery and it will let you go until the pack gets lower than 40% and usually stops moving around 18% to 20% which is well below normal. Once you stop, you could sit there with the car on for a long time, or reboot it many times, and it is possible the battery could get below the magic start value.
    If this happens then you will require a grid charger. If you go to the dealership they will get an HV charger in and have to charge the pack from the wall to get it above the 20%-40% charge and then the gas engine will be OK. It will also damage the battery by getting it so low.
    Same as above answer, and this can happen if you turn the car on, and put it in neutral and then let it go down for hours and hours. It may not start back up. But again, don't put it in neutral in READY for hours. The car will warn you as well, that it is not charging and don't do this.
    14.4v likes this.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    No it will discharge to 40% (1-bar) anytime the battery is low and charge to 80% (full 8 bars) when the battery is full. The car will attempt to keep it in the 60%-ish range, about 6-bars. Want to see it go through the full swings? Drive up and down a mountain.
    It will charge and discharge more quickly as it ages. Eventually the cells will become unbalanced causing the charge and discharge to happen by just accelerating and braking normally in traffic.and then the lights on the dash look like a Christmas tree, and the battery needs to be repaired/replaced. This could happen at 30K miles, 500K miles, 10 years, or 20 years. Nobody knows and each car is different. In the mountains and in the heat, they die faster. When they sit without being used, they die faster. That's why a 500K miles taxi that's 4 years old works just fine, but a car with 30K miles and 12 years might need a new battery.
    Gale Hawkins and kenoarto like this.
  6. massarmor
    JC91006,
    On page 184 of the manual, it states:
    "In the N position, the hybrid battery (traction battery) does not recharge. Leaving the shift position in the N position for an extended period of time may discharge the hybrid battery (traction battery). The vehicle cannot run if the hybrid battery is discharged."
    Why would it say that the hybrid battery can be discharged if it cannot?
  7. massarmor
    2k1Toaster, that makes a lot more sense. Thank you. Is there ever a time when I need to be careful not to let the hybrid battery deplete when it's not shifted in neutral or when it's not just dying naturally from being old? - or from a disaster like a flood short circuit -
    As long as the car is running normally, out of neutral, the gas engine will always kick in and recharge the battery if it gets too low, correct?
  8. hill
    8,794
    .... The traction pack won't run out - yes, the engine will come on an bring it back up. Over the decades, people have run out of gas & run the traction pack down 'till all the dash lights come on - and even then the dealer can gas it up & do a reset. I call it the 'dummy fee'.
  9. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    Historically, the Gen3 2009+ is better than the Gen2.
    The older Gen2 Prii will deplete HV batt if you run out of gas.
  10. Mendel Leisk
    41,327
    @massarmor I think your concern is battery depletion under normal driving conditions, the state of charge running down say due to protracted lower speeds on level roads?
    This is a normal scenario; once the charge gets down to two bars it'll change behaviour a bit, run the engine more, bring the charge back up.
  11. bisco
    51,843
    but to answer your question directly, yes, you're screwed.:p
  12. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    ...but nobody here to my knowledge has discharged a Gen3 HV batt because the Gen3 logic keeps the HV sufficiently charged in all normal scenarios including running out of gas. Gen2 yes plenty of folks ran the HV battery down in the out-of-gas scenario.
    Yes you are screwed if hypothetically the Gen3 HV batt is discharged, but it is not a likely except lay off neutral eg in car washes. I do my own car washes, so I don't know much about that.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You're welcome.
    And not being driven on when you are out gas.
    And not being used as a whole house power generator.
    No. The car will take care of itself if you take care of the car. Drive it like a normal car and it will reward you well.
    If you are in a flood, an electric powered vehicle is the best in my opinion. Here's the Leaf in the water test:
    Assuming you're vehicle is not buoyant enough to float away the danger to the engine is water getting in there. We use the power of hydraulics all the time because you can't really compress water, so that's bad if it gets in say a compression chamber of some kind, like an engine cylinder.
    Uunless you have one of these:
    But if you are in a flood scenario, don't be driving. You and your entire vehicle can be swept away in as few as a couple inches of fast moving water. Waaaaay less than most people think.
    As for short circuiting, the car will just shut off. The Prius checks before it boots that it is not shorted. If it happens while driving, the dash lights up, the car turns off. This can happen in bad accidents and they have thought about it. The battery is fully isolated from the vehicle whenever it should be.
    And if you have fuel. But otherwise yes.
  14. massarmor
    If I plan to go through a car wash using neutral, or any other situation needing neutral, is it necessary to drive around first and try to get the battery meter higher?
    If I put it in neutral, how much time do I have left if I have 40% (1-bar) before the battery level dips to an unhealthy state?
    And, what should I watch for? eg. air conditioning off, lights off, audio system off...?
    2k1Toaster, when will the prius be like one of those ;) Air-born would be nice too.
  15. Mendel Leisk
    41,327
    One thing you can do: use the washers where the car stays stationary.
    srellim234 likes this.
  16. CR94
    CR94 Senior Member
    2,689
    1,168
    Northwestern S.C.
    Unless you've arrived at the car wash creeping in EV, you're likely to have at least 4 bar segments showing without any extra "driving around." In that case, you have a lot more safe time in neutral than any car wash is likely to require, unless you do something stupid like leaving the air conditioning and headlights on.
    Don't worry too much about far-fetched hypothetical scenarios. The world has enough real problems to worry about.
  17. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    No not necessary. It won't hurt, but it is not required.
    It is generally accepted that a Prius consumes 200W in READY mode, when just sitting there looking pretty. Measurements are taken from numerous people including myself (mine draws a bit more, but I have a bit more in the car...) that use the Prius as a whole home power generator on occasion.
    Your Prius battery is made up of 28 modules. Each module contains 6 NiMH cells with a fully charged voltage of 1.2v per cell and a module capacity of 6500mAh, for a total of 46.8Wh per module, and 1.3kWh total pack capacity. A full 8-bar green battery (bad) is about 81% or 1kWh. When the Prius shows 1-bar, it is at 40%, or 524Wh remaining. The Prius will refuse to start around say 15% to pull a random number, around 200Wh. So with a brand new battery, you could get 2 hours in neutral from full to empty on the display, another hour and a half until it won't start anymore. Of course with a 2009, you might have 20% to 30% capacity left, so divide those numbers by 5. Assuming you roll in with a completely empty battery (40%) with a crap pack at 20% original capacity with no extra load in neutral, you have 18 minutes to dead. Most cars are in the carwash for 2 minutes at a high end one where there are lots of waxes and things and when the guy hops in at the end to park it, it goes back into drive (D) and all is well again.
    All that to say, don't worry about it.
    Electrical draws. Headlights, defroster, air conditioner, thumping 2000W bass subwoofer, that type of thing.
    I would direct that towards Hayashi Telempu Company from Japan. They have done some... unique... things to a Prius.
    Data Daedalus likes this.
  18. FnRedPrius
    FnRedPrius Active Member
    100
    121
    Pilot, NC
    But then again, it is possible to have a dumbass attack and leave the car parked in reverse with the parking brake on and the fob in the car during a 12 hour shift..... Then when you get to the big street the car says "ME NO GO!!!!" Eased to the next driveway parked, shut the car down, then powered back up. 0 bars and Battery empty or depleted message. It finally started the engine and I got going again. Just gonna keep an eye on it.
  19. ChapmanF
    18,076
    Something doesn't make sense ... Reverse isn't Neutral, and doesn't normally prevent the car from charging.
    Data Daedalus and jerrymildred like this.
  20. Ronald Doles
    Ronald Doles Active Member
    230
    280
    Columbus, OH
    2015 Prius v wagon
    We spend our winters with our daughter in Florida and since this is our first Prius, I am a little concerned about it sitting in the garage in Ohio for 3 months. I would expect that a laptop that has been left off for that period of time would be dead and I wonder about the hybrid battery in this car doing the same. Any advice as I didn't see any storage procedure in the Owners Manual.
