TRS Retro-Quik rotational alignment
Discussion in 'Gen 3 Prius Accessories and Modifications' started by WAWO, Jun 7, 2016.
  1. WAWO
    WAWO New Member
    Walnut, CA
    I just had my Prius retrofitted using the TRS Retro-Quik with the Morimoto Mini H1 7.0 projectors. Looks like the rotational alignment of the drivers side projector is rotated too far clockwise. Is it possible to fix the rotational alignment without taking the headlight apart again? 20160607_020205.jpg 20160607_015017.jpg Screenshot_2016-06-01-06-53-46.jpg
  2. Danger
    Danger Member
    175
    22
    Frisco
    I think the kit locks into the stock mounting points. So you should be able to use the stock adjustments to make the corrections.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Negative. The only way is to reopen the headlights
