Do not use premium fuel on prius!!!
Discussion in 'Gen 3 Prius Technical Discussion' started by Ernesto Chavez, Jun 30, 2016.
  1. Tideland Prius
    16,428
    The manual for the Gen 3 states 0W-20 or 5W-20 (except for 2011-2015 where 0W-20 is recommended). At least in Canada, 0W-20 has been recommended for 2011 (give or take a year) models and newer.
    Why do you even need 0W in NM? 5W-xx should be fine. (like 5W-20). Also, isn't 40 thicker than 20? You've contradicted yourself (but you have good advice about not getting stranded because of thicker oil)
    Do tell. My dealer regularly recommends a fuel injection cleaner service even though it's not part of the official Toyota maintenance schedule.
  2. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Premium causes my exhaust to smell on my bike, and the manual specifies regular 87 octane for the Honda CBR600 F4i. I get no performance improvement from running higher octane, even on the track.
    Premium doesn't have more detergent, either, so the advice to run fuel system cleaner if you run regular is bogus. Top Tier certified fuels will have higher levels of detergent.
    I've never found a fuel injected car to perform better on premium when it was designed to run on regular. With that said, I can tell a very slight difference in performance running premium in my Acura, which specifies 91 octane.
  3. wjtracy
    wjtracy Senior Member
    11,359
    3,606
    Northern VA (NoVA)
  4. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    meaning more wear with thinner oil/
    yep, 40 IS thicker/
    going into albuquerque in the summer means pretty often get stuck in traffic with temperatures higher than a 100 degrees/
    now living in the mountains, temperatures in the winter are often as low as 10s or 20s/
    that's why I use 0w-40 year round//
    m.wynn and orenji like this.
  5. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Not necessarily.
    Thinner oil can get into narrower passages more easily, meaning that sometimes wear, especially startup wear (which is more of an issue on a hybrid, with frequent engine shutdowns), can actually be reduced.
  6. StarCaller
    1,271
    723
  7. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    The 20 is what matters on a hot start, though, not the 0W.
  8. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Amen to that!
  9. Mendel Leisk
    40,467
    I have a hunch that 0W40 would be a little thicker when cold, comparing to 0W20.
    m.wynn likes this.
  10. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    It'll depend on the specific oil. (IIRC, Toyota Genuine Motor Oil 0W20 is light even for a 0W20.)
  11. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    Funny enough, there's a video for that. I am curious why one needs gloves and the other doesn't, but it's dumb silliness if nothing else.
  12. qdllc
    qdllc Senior Member
    1,371
    399
    Well, this runs back to when fuel injection was a new concept. Lots of people complained of lost performance, and running a bottle of fuel system treatment easily restore performance.
    Now, certainly, fuel delivery systems are higher quality and fuels tend to have more detergent additives, but depending on the motor, carbon deposits form and negatively affect plugs and valves. Unless you always use fuel with a system cleaner in it (e.g., Techron), this problem will crop up from time to time.
    Personally, I use B-12 Chemtool. It’s the same stuff as Seafoam but half the cost. It’s a fuel system safe industrial solvent. I put a bottle in the Prius once every 10,000 miles. I use 1/3 to 1/2 of a bottle in the motorcycle depending on use. If it sits over the winter or if I put several hundred miles on while always buying regular gas. Never had a fuel system or performance issue.
  13. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Which part of the world are you from? What is relevant in EU is irrelevant in Singapore.
  14. qdllc
    qdllc Senior Member
    1,371
    399
    United States.
  15. prius_deep
    prius_deep Member
    105
    road
    gen 2:
    Toyota Hybrid System Diagnosis - Course 072; Section 3; 3-4:
    Do not use premium gasoline. It may cause starting problems with the
    Prius. There is no gas mileage benefit when using premium gas!
    Starting may occur many times in a single drive cycle unlike
    conventional vehicles compounding potential "hot soak" issues.
  16. padroo
    padroo Senior Member
    2,763
    2,251
    I have looked at different owners manuals on the Internet from different countries and it seems they use different octane fuels. More research needs to be done.
  17. alanclarkeau
    7,045
    7,589
    Which part of the world are you in? (your profile is ambiguous) - there are members from dozens of countries - your comment is likely not of interest/relevance to 99% of them depending on where your "road" is. This is a Gen 3 Thread, I see you drive a Gen 4, but you mention "gen 2".
    TOYOTA specifies PREMIUM MUST be used for Gen 3 here.
  18. fuzzy1
    10,335
    Don't forget that there are several different octane rating scales. E.g. the EU scale is different than the US scale.
    padroo likes this.
  19. wjtracy
    11,359
    3,606
    Northern VA (NoVA)
    The Bentley Publishers Toyota Prius 2004-2008 Repair and Maintenance Guide also makes the comment about not using Premium gasoline(due to hard starting), but I have never figured out where they got that comment. Nobody here ever reported a starting problem.
    MPG is going to be based on energy content (not octane rating), which energy content is not automatically better for Premium, and is definitely not better for Premium in RFG areas. But some stations in some locations Premium could be better for MPG (eg; Canada where Premium is often E0). .
    #59 wjtracy, Apr 29, 2018
  20. StarCaller
    1,271
    723
    neone got a comparison between australian & us-american fuel octane ratings?
    what's premium in australia might be regular here/
