Missing Roof Molding
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by longjohn931, May 26, 2006.
  1. longjohn931
    longjohn931 New Member
    116
    Orlando, FL.
    Has anyone had a problem with the rubber roof molding strip being blown away during highway driving? (2005 Prius)
    I just noticed that my driver side strip is missing and I find it hard to believe that this strip could be lossended by the wind and blown away. I tend to think that someone needed this strip and helped themselves to mine instead of pucrchasing a replacement from a dealer.
    However, if other owners are missing either side, their may be a problem with the adhesive used to keep them in place.
    Your feed back would be appreciated.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    There's no adhesive, they just push into place. I've taken mine off to treat with 303 Protectant. Both ends fit into a loose clip. Sorry you lost yours.
  3. longjohn931
    116
    Orlando, FL.
    <div class='quotetop'>QUOTE(longjohn931 @ May 26 2006, 08:59 PM) [snapback]261565[/snapback]</div>
    Thanks Bill, maybe the brushless carwash I use periodically had too much pressure one day. I'm off to the dealer today to order a replacement, I'll let everyone know the cost for your reference.
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Yeah, I noticed that I could pop one end of those strips out easily
    by hand when I was washing the car and trying to extract all those
    stupid pine needles... felt like a very weak clip, and I started
    getting paranoid that the strip could work loose and pop off with
    enough air pressure. I had a door strip launch itself off my old
    Subaru into the median one day for similar reasons [the cheezy
    double-sticky tape failed...] hmm, maybe I should figure out a way
    to at least anchor down the front ends better.
    _H*
  5. Bill Merchant
    4,096
    85
    Maybe that's why they pull out so easy: to facilitate cleaning out the pine needles (Doug Fir in my case) that want to turn to mulch under there.
  6. Floyd2
    Floyd2 progressio per sententia
    106
    Netherlands, Europe
    Lost one of mine as well on the highway. A new one cost me $ 73,-.
    I want to glue them firmly into place since they don't seem to have any real purpose. I assume some kind of silicone kit will not damage the paintwork. Any ideas?
  7. nagrath
    nagrath Member
    145
    49
    Putnam County, New York
    2023 Prius Prime
    XSE
    This just happened to me, too. $73 for a strip of plastic? Sheesh! I'm gonna glue that sucker down.
    John
  8. Scott McGregor
    Scott McGregor Junior Member
    Llandrindod Wells UK
  9. grady's momn
    grady's momn Junior Member
    va
    How do I replace them....I do not know which end is the front and are they suppose to click onto the clips?
  10. Nate the Skate
    Nate the Skate New Member
    27
    Houston, TX
    2014 Prius c
    Mine are coming loose every car wash and I'm using my Prius C to Uber. Car has to be clean for good reviews. They snap back easily but not securely, obvs.
    Any recommendations? The car wash people put masking tape on rear wiper. Is this a solution?
  11. Adam Dinitz
    Adam Dinitz New Member
    Chicago
    2016 Prius c
    My 2016 priusC is having this issue as well. My local Toyota dealer and body shop say it's poor design. This happens on the Prius models, Corolla, Rav 4 and more. Anyone open to a class action lawsuit?
  12. bisco
    51,583
    where do i sign?
  13. Adam Dinitz
    Chicago
    2016 Prius c
    I want more people on our side 1st.
  14. bisco
    51,583
    yeah, tough slog
  15. Moses Bruh
    Moses Bruh Member
    97
    29
    i think id just squeeze a dime size amount of 100% silicone caulk at just the front ends of the strip, it will keep it down and if u need to take it out to clean or whatever it wont be hard to break off. You can scrape off what you can of the old silicone with ur hands or some plastic and reapply.
  16. Adam Dinitz
    Chicago
    2016 Prius c
    That does not hold. I had to run a line all the way down both strips. I then have to redo it every few months. Also Toy knows about the issue and does not care. Chevy has the same issue on a few makes.
