wiper/washer problem
Discussion in 'Gen 2 Prius Main Forum' started by brian3nj, Jul 16, 2016.
  1. brian3nj
    brian3nj Junior Member
    New Jersey
    I picked up a 2007 Prius at an auction and I have an issue with the wiper/ washer circuit. The wipers work fine but the washers do not. when i call for either front or rear washer both the front and rear wipers run but neither washer works. I have a 2008 Prius and swapped the control on the steering wheel and no change.
    51,037
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Sounds obvious, but is there any fluid in the reservoir? (…it's happened to me a number of times! :eek::rolleyes:)
    SDunahugh likes this.
