Prius four with spare tire from dealer
Discussion in 'Gen 4 Prius Main Forum' started by jbkendrick, Jul 13, 2016.
  1. bisco
    51,022
    great link, thanks roadnoise!(y)
    ETP and RoadNoise like this.
  2. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    When I was looking at the car, the lack of a spare was what made me buy a 3. I had a feeling this was going to back fire on Toyota. IMO a can of flat fixer is even worse than run flat tires. Both are horrible. I think the only thing the dealers hear is when cars sit on there lots and don't sell.
    ETP likes this.
  3. bisco
    51,022
    no question about that! but i don't think it's backfiring on toyota, if they can sell another $500. in accessories.:rolleyes:
    ETP likes this.
  4. wjtracy
    wjtracy Senior Member
    11,359
    3,606
    Northern VA (NoVA)
    PriusChat store maybe should sell knock-off inserts.
    Then you can have your cake and eat it too.
    If you want space, you throw in the skinny inset.
    If you want a spare, you throw in the spare insert and a spare.
    Endless possibilities Danny-
    Then there's the fake floor insert for those who miss that Gen 2/3 compartment.
    ...there's the hide-the-beer-from-your-wife floor, etc.
    KimPrius3, ETP and bisco like this.
  5. Mendel Leisk
    40,459
    Just speculating on how the dealership accomplished a 4 with spare:
    They likely took the path of least resistance, swapped parts with a 3. And subsequently they'll fob that 3 off on someone not that up on the levels?
  6. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    Considering that dealers are selling these cars at more than $3k off sticker and still making a profit, this one may have a lot of options -- depending on what it sold the car for.
    #26 ATHiker, Jul 14, 2016
    ETP likes this.
  7. jbkendrick
    jbkendrick Active Member
    232
    197
    Baltimore, MD
    ETP and Mendel Leisk like this.
  8. Mendel Leisk
    40,459
    Are the flaps at the base of rear seatbacks kinda riding up:
    Not sure. And not sure why that would be.
    ETP likes this.
  9. jbkendrick
    232
    197
    Baltimore, MD
    Not sure I would call it riding up, but I think it makes sense if you think about it. The original hatch floor was lower before exchanging the tire repair kit insert with the spare tire insert. It appears that the flaps in the 4 are longer in height than those in a car with a spare tire insert, so they will be even from their base to the base of the folded down seat backs. So when we put in the spare tire insert the rear hatch area is higher and the full flap is not needed and rises above the base of the seat back. That is my thought process anyway, does that sound right?
    ETP, dfine1966 and Mendel Leisk like this.
  10. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Has anyone found a source for the insert and any other parts required for a full size spare, at least for the 15" wheel?
    ETP likes this.
  11. gvp1995
    gvp1995 Active Member
    199
    141
    Three Touring
    Thanks a lot for the pics! It is not as nice and even as in 3, but in my view not worse than 4. The main thing it is possible, and I am sure a lot of people, who want the highest package but were hesitant because of the absence of a spare, will go for it. Hopefully Toyota will listen and add a spare for all models in the future.
    KimPrius3 and jbkendrick like this.
  12. wjtracy
    11,359
    3,606
    Northern VA (NoVA)
    hmm...keep in mind the Prius 4 has 27.4-ft3 EPA cargo vs. closer to 24-ft3 for the Prius 3. I don't think there is 3-ft3 difference in the size of the insert (but I am not sure about that). If there is not 3-ft3 difference in the insert size, then some other measurement (such as seat position or height) might be a little different, to allow claiming 3-ft3 difference.
    #32 wjtracy, Jul 15, 2016
    ETP likes this.
  13. ATHiker
    644
    560
    Massachusetts
    Four Touring
    I believe the pictured foam insert from the 3 may be taller than the one designed for the tire inflator version, such that the rolling tonneau cover can fit hidden under the floorboard and carpet.
    The modified/carved solution won't fit the tonneau cover in a hidden spot underneath, but you get the greater cargo capacity.
  14. HobbsNick
    HobbsNick Member
    107
    156
    Newcastle, U.K.
    Charging for a spare seems a little cheeky, in the UK you can choose to either have the inflation kit or a spare tyre for no extra cost.
    ETP, bisco and Mendel Leisk like this.
  15. wjtracy
    11,359
    3,606
    Northern VA (NoVA)
    Do they change the insert when they do the spare option?
    I have not seen a +spare VDA cargo space quote for EU.
    We have VDA cargo space = 502-liters (17.7-ft3) for the no-spare case.
    ETP likes this.
  16. HobbsNick
    HobbsNick Member
    107
    156
    Newcastle, U.K.
    It's a manufacturer option so the car is built with the inserts that are needed depending on choice. I ended up going for the the inflation kit as I've not had a puncture in 7 years, along with the fact the lease scheme I've gone with covers replacement tyres at not extra cost.
    #36 HobbsNick, Jul 17, 2016
    ETP, KimPrius3 and bisco like this.
  17. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    There's a "Styro Kit"? Tell me more, please. :)
    Wonder if I could get a spare tire insert and change out the inflation kit?!?!?!
    ETP likes this.
  18. Mendel Leisk
    40,459
    If you look under the hatch floor in a spare vs air pump version, there's different Styrofoam configuration, different cut outs.
    ETP likes this.
  19. gnrob
    gnrob Junior Member
    Winston-Salem, NC
    How do you remove the foam insert without doing serious damage? It looks kind of cheap and easily damaged.
    I sure miss my Gen2 hidden cargo bin, so this is a way to get some of that space back.
    Thanks.
    ETP likes this.
  20. ETP
    2,802
    1,170
    Auburdale FL
    This is a story to make a person weep!:cry::cry::cry::cry::cry::cry:
    See the spare tire thread and the new Continental look.
